[PATCH 5/7] bsps/arm: Move libcpu content to bsps
Mon Mar 12 10:25:23 UTC 2018
Update #3285.
 .../arm920/mmu.c => bsps/arm/shared/arm920-mmu.c   |  0
 c/src/lib/libbsp/arm/csb336/Makefile.am            |  2 +-
 c/src/lib/libbsp/arm/csb336/make/custom/csb336.cfg |  1 -
 c/src/lib/libbsp/arm/csb337/Makefile.am            |  2 +-
 c/src/lib/libbsp/arm/csb337/make/custom/csb337.cfg |  1 -
 .../lib/libbsp/arm/edb7312/make/custom/edb7312.cfg |  3 +-
 c/src/lib/libbsp/arm/gdbarmsim/Makefile.am         |  5 --
 .../arm/gdbarmsim/make/custom/arm1136jfs.cfg       |  1 -
 .../libbsp/arm/gdbarmsim/make/custom/arm1136js.cfg |  1 -
 .../libbsp/arm/gdbarmsim/make/custom/arm7tdmi.cfg  |  1 -
 .../libbsp/arm/gdbarmsim/make/custom/arm920.cfg    |  1 -
 .../arm/gdbarmsim/make/custom/armcortexa9.cfg      |  1 -
 c/src/lib/libbsp/arm/gumstix/Makefile.am           |  2 +-
 .../lib/libbsp/arm/gumstix/make/custom/gumstix.cfg |  1 -
 c/src/lib/libbsp/arm/smdk2410/Makefile.am          |  2 +-
 .../libbsp/arm/smdk2410/make/custom/smdk2410.cfg   |  1 -
 c/src/lib/libcpu/arm/Makefile.am                   | 19 -------
 c/src/lib/libcpu/arm/configure.ac                  | 32 -----------
 c/src/lib/libcpu/arm/lpc22xx/irq/bsp_irq_asm.S     | 57 -------------------
 c/src/lib/libcpu/arm/lpc22xx/irq/bsp_irq_init.c    | 65 ----------------------
 c/src/lib/libcpu/arm/pxa255/irq/bsp_irq_asm.S      | 31 -----------
 c/src/lib/libcpu/arm/pxa255/irq/bsp_irq_init.c     | 40 -------------
 22 files changed, 5 insertions(+), 264 deletions(-)
 rename c/src/lib/libcpu/arm/shared/arm920/mmu.c => bsps/arm/shared/arm920-mmu.c (100%)
 delete mode 100644 c/src/lib/libcpu/arm/Makefile.am
 delete mode 100644 c/src/lib/libcpu/arm/configure.ac
 delete mode 100644 c/src/lib/libcpu/arm/lpc22xx/irq/bsp_irq_asm.S
 delete mode 100644 c/src/lib/libcpu/arm/lpc22xx/irq/bsp_irq_init.c
 delete mode 100644 c/src/lib/libcpu/arm/pxa255/irq/bsp_irq_asm.S
 delete mode 100644 c/src/lib/libcpu/arm/pxa255/irq/bsp_irq_init.c
diff --git a/c/src/lib/libcpu/arm/shared/arm920/mmu.c b/bsps/arm/shared/arm920-mmu.c
similarity index 100%
rename from c/src/lib/libcpu/arm/shared/arm920/mmu.c
rename to bsps/arm/shared/arm920-mmu.c
diff --git a/c/src/lib/libbsp/arm/csb336/Makefile.am b/c/src/lib/libbsp/arm/csb336/Makefile.am
index 8bc5a44f23..163cecf23f 100644
--- a/c/src/lib/libbsp/arm/csb336/Makefile.am
+++ b/c/src/lib/libbsp/arm/csb336/Makefile.am
@@ -50,7 +50,7 @@ libbsp_a_SOURCES += network/lan91c11x.c
 libbsp_a_SOURCES += network/network.c
 endif
-libbsp_a_LIBADD = ../../../libcpu/@RTEMS_CPU@/shared/arm920.rel
+libbsp_a_SOURCES += ../../../../../../bsps/arm/shared/arm920-mmu.c
 include $(top_srcdir)/../../../../automake/local.am
 include $(srcdir)/../../../../../../bsps/arm/csb336/headers.am
diff --git a/c/src/lib/libbsp/arm/csb336/make/custom/csb336.cfg b/c/src/lib/libbsp/arm/csb336/make/custom/csb336.cfg
index bc2f65cc9c..d38e2e10b8 100644
--- a/c/src/lib/libbsp/arm/csb336/make/custom/csb336.cfg
+++ b/c/src/lib/libbsp/arm/csb336/make/custom/csb336.cfg
@@ -5,7 +5,6 @@
 include $(RTEMS_ROOT)/make/custom/default.cfg
 RTEMS_CPU=arm
-RTEMS_CPU_MODEL=shared
 #  This contains the compiler options necessary to select the CPU model
 #  and (hopefully) optimize for it.
diff --git a/c/src/lib/libbsp/arm/csb337/Makefile.am b/c/src/lib/libbsp/arm/csb337/Makefile.am
index 69780d18a5..3e33db0c1e 100644
--- a/c/src/lib/libbsp/arm/csb337/Makefile.am
+++ b/c/src/lib/libbsp/arm/csb337/Makefile.am
@@ -80,7 +80,7 @@ if HAS_NETWORKING
 endif
 include $(srcdir)/../../../../../../bsps/arm/csb337/headers.am
diff --git a/c/src/lib/libbsp/arm/csb337/make/custom/csb337.cfg b/c/src/lib/libbsp/arm/csb337/make/custom/csb337.cfg
index 56e2d7a116..97d9685c3d 100644
--- a/c/src/lib/libbsp/arm/csb337/make/custom/csb337.cfg
+++ b/c/src/lib/libbsp/arm/csb337/make/custom/csb337.cfg
@@ -5,7 +5,6 @@
 RTEMS_CPU=arm
diff --git a/c/src/lib/libbsp/arm/edb7312/make/custom/edb7312.cfg b/c/src/lib/libbsp/arm/edb7312/make/custom/edb7312.cfg
index 832f47bdde..32dd537872 100644
--- a/c/src/lib/libbsp/arm/edb7312/make/custom/edb7312.cfg
+++ b/c/src/lib/libbsp/arm/edb7312/make/custom/edb7312.cfg
@@ -5,12 +5,11 @@
 RTEMS_CPU=arm
-RTEMS_CPU_MODEL=arm7tdmi
-CPU_CFLAGS = -mcpu=$(RTEMS_CPU_MODEL)
+CPU_CFLAGS = -mcpu=arm7tdmi
 # optimize flag: typically -O2
 CFLAGS_OPTIMIZE_V = -O2 -g
diff --git a/c/src/lib/libbsp/arm/gdbarmsim/Makefile.am b/c/src/lib/libbsp/arm/gdbarmsim/Makefile.am
index 62cbdccb8b..f9a47f4b23 100644
--- a/c/src/lib/libbsp/arm/gdbarmsim/Makefile.am
+++ b/c/src/lib/libbsp/arm/gdbarmsim/Makefile.am
@@ -52,11 +52,6 @@ libbsp_a_SOURCES += ../../shared/src/irq-shell.c
 # Cache
 libbsp_a_SOURCES += ../../../../../../bsps/shared/cache/nocache.c
-#libbsp_a_LIBADD = ../../../libcpu/@RTEMS_CPU@/shared/arm920.rel \
-#    ../../../libcpu/@RTEMS_CPU@/@RTEMS_CPU_MODEL@/clock.rel \
-#    ../../../libcpu/@RTEMS_CPU@/@RTEMS_CPU_MODEL@/timer.rel \
-#    ../../../libcpu/@RTEMS_CPU@/@RTEMS_CPU_MODEL@/irq.rel
 # Shared
 if shared
 libbsp_a_SOURCES += ../shared/arm-cp15-set-exception-handler.c
diff --git a/c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm1136jfs.cfg b/c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm1136jfs.cfg
index a802a8ffdc..be4d5a6484 100644
--- a/c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm1136jfs.cfg
+++ b/c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm1136jfs.cfg
@@ -5,7 +5,6 @@
 RTEMS_CPU=arm
-RTEMS_CPU_MODEL=arm1136
diff --git a/c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm1136js.cfg b/c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm1136js.cfg
index 7ae3e6bb71..83308c39b0 100644
--- a/c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm1136js.cfg
+++ b/c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm1136js.cfg
@@ -5,7 +5,6 @@
 RTEMS_CPU=arm
diff --git a/c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm7tdmi.cfg b/c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm7tdmi.cfg
index 28a2e76460..e992733864 100644
--- a/c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm7tdmi.cfg
+++ b/c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm7tdmi.cfg
@@ -5,7 +5,6 @@
 RTEMS_CPU=arm
diff --git a/c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm920.cfg b/c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm920.cfg
index 72478f8d95..b246d5bb20 100644
--- a/c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm920.cfg
+++ b/c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm920.cfg
@@ -5,7 +5,6 @@
 RTEMS_CPU=arm
-RTEMS_CPU_MODEL=arm920
diff --git a/c/src/lib/libbsp/arm/gdbarmsim/make/custom/armcortexa9.cfg b/c/src/lib/libbsp/arm/gdbarmsim/make/custom/armcortexa9.cfg
index 693eb9f762..6eecf70615 100644
--- a/c/src/lib/libbsp/arm/gdbarmsim/make/custom/armcortexa9.cfg
+++ b/c/src/lib/libbsp/arm/gdbarmsim/make/custom/armcortexa9.cfg
@@ -5,7 +5,6 @@
 RTEMS_CPU=arm
diff --git a/c/src/lib/libbsp/arm/gumstix/Makefile.am b/c/src/lib/libbsp/arm/gumstix/Makefile.am
index cff8663382..abd8f74019 100644
--- a/c/src/lib/libbsp/arm/gumstix/Makefile.am
+++ b/c/src/lib/libbsp/arm/gumstix/Makefile.am
@@ -55,7 +55,7 @@ libbsp_a_SOURCES += rtl8019/rtl8019.c rtl8019/wd80x3.h
 endif
 endif
 include $(srcdir)/../../../../../../bsps/arm/gumstix/headers.am
diff --git a/c/src/lib/libbsp/arm/gumstix/make/custom/gumstix.cfg b/c/src/lib/libbsp/arm/gumstix/make/custom/gumstix.cfg
index d42b44695b..664e42b365 100644
--- a/c/src/lib/libbsp/arm/gumstix/make/custom/gumstix.cfg
+++ b/c/src/lib/libbsp/arm/gumstix/make/custom/gumstix.cfg
@@ -5,7 +5,6 @@
 RTEMS_CPU=arm
diff --git a/c/src/lib/libbsp/arm/smdk2410/Makefile.am b/c/src/lib/libbsp/arm/smdk2410/Makefile.am
index a0922bd77f..0f3fb3f3cc 100644
--- a/c/src/lib/libbsp/arm/smdk2410/Makefile.am
+++ b/c/src/lib/libbsp/arm/smdk2410/Makefile.am
@@ -58,7 +58,7 @@ libbsp_a_SOURCES += smc/smc.h
 # Cache
 libbsp_a_SOURCES += ../../../../../../bsps/arm/shared/cache/cache-cp15.c
 include $(srcdir)/../../../../../../bsps/arm/smdk2410/headers.am
diff --git a/c/src/lib/libbsp/arm/smdk2410/make/custom/smdk2410.cfg b/c/src/lib/libbsp/arm/smdk2410/make/custom/smdk2410.cfg
index fe532ceb4f..b5720cae3f 100644
--- a/c/src/lib/libbsp/arm/smdk2410/make/custom/smdk2410.cfg
+++ b/c/src/lib/libbsp/arm/smdk2410/make/custom/smdk2410.cfg
@@ -5,7 +5,6 @@
 RTEMS_CPU=arm
diff --git a/c/src/lib/libcpu/arm/Makefile.am b/c/src/lib/libcpu/arm/Makefile.am
deleted file mode 100644
index 35b08e2495..0000000000
--- a/c/src/lib/libcpu/arm/Makefile.am
+++ /dev/null
@@ -1,19 +0,0 @@
-ACLOCAL_AMFLAGS = -I ../../../aclocal
-include $(top_srcdir)/../../../automake/compile.am
-EXTRA_DIST =
-noinst_PROGRAMS =
-## shared/include
-if shared
-## shared/arm920
-noinst_PROGRAMS += shared/arm920.rel
-shared_arm920_rel_SOURCES = shared/arm920/mmu.c
-shared_arm920_rel_CPPFLAGS = $(AM_CPPFLAGS) -I$(srcdir)/shared/src
-shared_arm920_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
-endif
-include $(top_srcdir)/../../../automake/local.am
diff --git a/c/src/lib/libcpu/arm/configure.ac b/c/src/lib/libcpu/arm/configure.ac
index a5e3e1cc88..0000000000
--- a/c/src/lib/libcpu/arm/configure.ac
+++ /dev/null
@@ -1,32 +0,0 @@
-## Process this file with autoconf to produce a configure script.
-AC_PREREQ([2.69])
-AC_INIT([rtems-c-src-lib-libcpu-arm],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
-AC_CONFIG_SRCDIR([shared])
-RTEMS_TOP([../../../../..],[../../..])
-RTEMS_SOURCE_TOP
-RTEMS_BUILD_TOP
-RTEMS_CANONICAL_TARGET_CPU
-AM_INIT_AUTOMAKE([no-define foreign subdir-objects 1.12.2])
-AM_MAINTAINER_MODE
-RTEMS_ENV_RTEMSBSP
-RTEMS_PROJECT_ROOT
-RTEMS_PROG_CC_FOR_TARGET
-AM_PROG_CC_C_O
-RTEMS_CANONICALIZE_TOOLS
-RTEMS_PROG_CCAS
-AM_CONDITIONAL(shared, test "$RTEMS_CPU_MODEL" = "arm1136" || \
-		       test "$RTEMS_CPU_MODEL" = "shared")
-RTEMS_AMPOLISH3
-# Explicitly list all Makefiles here
-AC_CONFIG_FILES([Makefile
-AC_OUTPUT
diff --git a/c/src/lib/libcpu/arm/lpc22xx/irq/bsp_irq_asm.S b/c/src/lib/libcpu/arm/lpc22xx/irq/bsp_irq_asm.S
index 4aa7ea4698..0000000000
--- a/c/src/lib/libcpu/arm/lpc22xx/irq/bsp_irq_asm.S
+++ /dev/null
@@ -1,57 +0,0 @@
- *  LPC22XX/LPC21xx Intererrupt handler
- *  Modified by Ray <rayx.cn at gmail.com> 2006 from Jay Monkman's code
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#define __asm__
- * BSP specific interrupt handler for INT or FIQ. In here
- * you do determine which interrupt happened and call its
- * handler.
- * Called from ISR_Handler, It is better to write in C function
-	.globl bsp_interrupt_dispatch
-bsp_interrupt_dispatch :
-#ifdef __thumb__
-    .code 16
-#endif
- * Look at interrupt status register to determine source.
- * From source, determine offset into expanded vector table
- * and load handler address into r0.
-  ldr 	r0, =0xFFFFF030  /* Read the vector number */
-    ldr	r0, [r0]
-#ifdef __thumb__
-    push {lr}
-    ldr	r2, =IRQ_return         /* prepare the return from handler  */
-    mov lr, r2
-#else
-  stmdb	  sp!,{lr}
-  ldr     lr, =IRQ_return         /* prepare the return from handler  */
-#endif
-    /*C code will be called*/
-    mov	pc, r0		/* EXECUTE INT HANDLER */
-     * C code may come back from Thumb if --thumb-interwork flag is False
-     * Add some veneer to make sure that code back to ARM
-IRQ_return:
-#ifdef __thumb__
-    pop {r1}
-    bx  r1
-#else
-    ldmia sp!,{r1}
-    mov pc, r1
-#endif
diff --git a/c/src/lib/libcpu/arm/lpc22xx/irq/bsp_irq_init.c b/c/src/lib/libcpu/arm/lpc22xx/irq/bsp_irq_init.c
index ae933f76d2..0000000000
--- a/c/src/lib/libcpu/arm/lpc22xx/irq/bsp_irq_init.c
+++ /dev/null
@@ -1,65 +0,0 @@
- *  NXP/Philips LPC22XX/LPC21xx Interrupt handler
- *  Ray 2007 <rayx.cn at gmail.com> to support LPC ARM
-#include <irq.h>
-#include <bsp.h>
-#include <lpc22xx.h>
- * Interrupt system initialization. Disable interrupts, clear
- * any that are pending.
-void BSP_rtems_irq_mngt_init(void)
-  long *vectorTable;
-  int i;
-    /* disable all interrupts */
-  VICIntEnClr = 0xFFFFFFFF;
-  vectorTable = (long *) VECTOR_TABLE;
-  /* Initialize the vector table contents with default handler */
-  for (i=0; i<BSP_MAX_INT; i++) {
-      *(vectorTable + i) = (long)(default_int_handler);
-   * Set IRQHandler
-  IRQ_VECTOR_ADDR = 0xE59FF018;           /* LDR PC,[PC,#0x18] instruction */
-   * Set FIQHandler
-  FIQ_VECTOR_ADDR = 0xE59FF018;           /* LDR PC,[PC,#0x18] instruction */
-   * We does not need the next interrupt sources in the moment,
-   * therefore jump to itself.
-  UNDEFINED_INSTRUCTION_VECTOR_ADDR = 0xEAFFFFFE;
-  SOFTWARE_INTERRUPT_VECTOR_ADDR    = 0xEAFFFFFE;
-  PREFETCH_ABORT_VECTOR_ADDR        = 0xEAFFFFFE;
-   * In case we must find an ABORT error,
-   * enable the next lines and set a breakpoint
-   * in ABORTHandler.
-#if 1
-  DATA_ABORT_VECTOR_ADDR = 0xE59FF018;
-#endif
-   * Init the Vectored Interrupt Controller (VIC)
-  VICProtection = 0;
-  VICIntSelect = 0;
-  VICVectAddr = 0;
diff --git a/c/src/lib/libcpu/arm/pxa255/irq/bsp_irq_asm.S b/c/src/lib/libcpu/arm/pxa255/irq/bsp_irq_asm.S
index 5f39aedcc6..0000000000
--- a/c/src/lib/libcpu/arm/pxa255/irq/bsp_irq_asm.S
+++ /dev/null
@@ -1,31 +0,0 @@
- * PXA255 Interrupt handler by Yang Xi <hiyangxi at gmail.com>
- * Copyright (c) 2004 by Jay Monkman <jtm at lopgindog.com>
-#define __asm__
- * and load vector into r0 and handler address into r1.
-	ldr	r0,=0x40d00000
-	ldr	r1,[r0]
-	clz	r0,r1
-	cmp	r0,#32
-	moveq   pc,lr 	/*All zeros*/
-	mov 	r2,#31
-	sub	r0,r2,r0
-	ldr	r2,=IRQ_table
-	add	r2,r2,r0,LSL #2
-	ldr	r1,[r2]
-	mov	pc,r1
diff --git a/c/src/lib/libcpu/arm/pxa255/irq/bsp_irq_init.c b/c/src/lib/libcpu/arm/pxa255/irq/bsp_irq_init.c
index aeabc1f145..0000000000
--- a/c/src/lib/libcpu/arm/pxa255/irq/bsp_irq_init.c
+++ /dev/null
@@ -1,40 +0,0 @@
- * PXA255 interrupt controller by Yang Xi <hiyangxi at gmail.com>
-#include <irq.h>
-#include <bsp.h>
-#include <pxa255.h>
-void dummy_handler(rtems_irq_hdl_param unused)
-  printk("I am dummy handler\n");
-void (*IRQ_table[PRIMARY_IRQS])(rtems_irq_hdl_param param);
-  int i;
-  for (i=0; i<PRIMARY_IRQS; i++) {
-    IRQ_table[i] = dummy_handler;
-  XSCALE_INT_ICMR = 0x0;
-  /* Direct the interrupt to IRQ*/
-  XSCALE_INT_ICLR = 0x0;
2.12.3
