[PATCH 4/7] bsps/mips: Move libcpu content to bsps
Mon Mar 12 10:25:22 UTC 2018
Update #3285.
 .../mips/shared/irq}/installisrentries.c           |  0
 .../mips/shared/irq}/isr_entries.S                 |  0
 .../mips => bsps/mips/shared}/timer/gettime.S      |  0
 .../libcpu/mips => bsps/mips/shared}/timer/timer.c |  0
 c/src/lib/libbsp/mips/csb350/Makefile.am           |  4 +-
 .../lib/libbsp/mips/csb350/make/custom/csb350.cfg  |  1 -
 c/src/lib/libbsp/mips/hurricane/Makefile.am        |  8 ++--
 .../mips/hurricane/make/custom/hurricane.cfg       |  2 -
 c/src/lib/libbsp/mips/jmr3904/Makefile.am          |  5 ++-
 .../libbsp/mips/jmr3904/make/custom/jmr3904.cfg    |  1 -
 c/src/lib/libbsp/mips/malta/Makefile.am            |  4 +-
 c/src/lib/libbsp/mips/malta/make/custom/malta.cfg  |  1 -
 c/src/lib/libbsp/mips/rbtx4925/Makefile.am         |  7 ++--
 .../libbsp/mips/rbtx4925/make/custom/rbtx4925.cfg  |  2 -
 c/src/lib/libbsp/mips/rbtx4938/Makefile.am         |  8 ++--
 .../libbsp/mips/rbtx4938/make/custom/rbtx4938.cfg  |  2 -
 c/src/lib/libcpu/mips/Makefile.am                  | 48 ----------------------
 c/src/lib/libcpu/mips/configure.ac                 | 40 ------------------
 .../libcpu/mips/shared/interrupts/interruptmask.c  | 20 ---------
 19 files changed, 21 insertions(+), 132 deletions(-)
 rename {c/src/lib/libcpu/mips/shared/interrupts => bsps/mips/shared/irq}/installisrentries.c (100%)
 rename {c/src/lib/libcpu/mips/shared/interrupts => bsps/mips/shared/irq}/isr_entries.S (100%)
 rename {c/src/lib/libcpu/mips => bsps/mips/shared}/timer/gettime.S (100%)
 rename {c/src/lib/libcpu/mips => bsps/mips/shared}/timer/timer.c (100%)
 delete mode 100644 c/src/lib/libcpu/mips/Makefile.am
 delete mode 100644 c/src/lib/libcpu/mips/configure.ac
 delete mode 100644 c/src/lib/libcpu/mips/shared/interrupts/interruptmask.c
diff --git a/c/src/lib/libcpu/mips/shared/interrupts/installisrentries.c b/bsps/mips/shared/irq/installisrentries.c
similarity index 100%
rename from c/src/lib/libcpu/mips/shared/interrupts/installisrentries.c
rename to bsps/mips/shared/irq/installisrentries.c
diff --git a/c/src/lib/libcpu/mips/shared/interrupts/isr_entries.S b/bsps/mips/shared/irq/isr_entries.S
rename from c/src/lib/libcpu/mips/shared/interrupts/isr_entries.S
rename to bsps/mips/shared/irq/isr_entries.S
diff --git a/c/src/lib/libcpu/mips/timer/gettime.S b/bsps/mips/shared/timer/gettime.S
rename from c/src/lib/libcpu/mips/timer/gettime.S
rename to bsps/mips/shared/timer/gettime.S
diff --git a/c/src/lib/libcpu/mips/timer/timer.c b/bsps/mips/shared/timer/timer.c
rename from c/src/lib/libcpu/mips/timer/timer.c
rename to bsps/mips/shared/timer/timer.c
diff --git a/c/src/lib/libbsp/mips/csb350/Makefile.am b/c/src/lib/libbsp/mips/csb350/Makefile.am
index 69c709ce2e..f289195047 100644
--- a/c/src/lib/libbsp/mips/csb350/Makefile.am
+++ b/c/src/lib/libbsp/mips/csb350/Makefile.am
@@ -54,8 +54,8 @@ libbsp_a_SOURCES += network/network.c
 endif
 libbsp_a_SOURCES += ../../../../../../bsps/shared/cache/nocache.c
-libbsp_a_LIBADD = ../../../libcpu/mips/shared/interrupts.rel
+libbsp_a_SOURCES += ../../../../../../bsps/mips/shared/irq/installisrentries.c
+libbsp_a_SOURCES += ../../../../../../bsps/mips/shared/irq/isr_entries.S
 include $(top_srcdir)/../../../../automake/local.am
 include $(srcdir)/../../../../../../bsps/mips/csb350/headers.am
diff --git a/c/src/lib/libbsp/mips/csb350/make/custom/csb350.cfg b/c/src/lib/libbsp/mips/csb350/make/custom/csb350.cfg
index ebadadd1f6..f6d50662b0 100644
--- a/c/src/lib/libbsp/mips/csb350/make/custom/csb350.cfg
+++ b/c/src/lib/libbsp/mips/csb350/make/custom/csb350.cfg
@@ -5,7 +5,6 @@
 include $(RTEMS_ROOT)/make/custom/default.cfg
 RTEMS_CPU=mips
-RTEMS_CPU_MODEL=au1x00
 #  This contains the compiler options necessary to select the CPU model
 #  and (hopefully) optimize for it.
diff --git a/c/src/lib/libbsp/mips/hurricane/Makefile.am b/c/src/lib/libbsp/mips/hurricane/Makefile.am
index a65d2989c2..8746b969eb 100644
--- a/c/src/lib/libbsp/mips/hurricane/Makefile.am
+++ b/c/src/lib/libbsp/mips/hurricane/Makefile.am
@@ -18,6 +18,7 @@ project_lib_DATA = start.$(OBJEXT)
 project_lib_DATA += linkcmds
 noinst_LIBRARIES = libbsp.a
+libbsp_a_CPPFLAGS = $(AM_CPPFLAGS) -DRM52XX
 libbsp_a_SOURCES =
 # startup
@@ -56,9 +57,10 @@ libbsp_a_SOURCES += irq/vectorisrs.c
 libbsp_a_SOURCES += ../shared/irq/interruptmask.c
-libbsp_a_LIBADD = ../../../libcpu/@RTEMS_CPU@/shared/interrupts.rel
-libbsp_a_LIBADD += ../../../libcpu/@RTEMS_CPU@/rm52xx/timer.rel
+libbsp_a_SOURCES += ../../../../../../bsps/mips/shared/timer/timer.c
+libbsp_a_SOURCES += ../../../../../../bsps/mips/shared/timer/gettime.S
 include $(srcdir)/../../../../../../bsps/mips/hurricane/headers.am
diff --git a/c/src/lib/libbsp/mips/hurricane/make/custom/hurricane.cfg b/c/src/lib/libbsp/mips/hurricane/make/custom/hurricane.cfg
index 02d198bfe3..b1c050b966 100644
--- a/c/src/lib/libbsp/mips/hurricane/make/custom/hurricane.cfg
+++ b/c/src/lib/libbsp/mips/hurricane/make/custom/hurricane.cfg
@@ -4,8 +4,6 @@
-RTEMS_CPU_MODEL=rm5231
 CPU_CFLAGS = -mips3 -G0 -EL
diff --git a/c/src/lib/libbsp/mips/jmr3904/Makefile.am b/c/src/lib/libbsp/mips/jmr3904/Makefile.am
index e67e58865f..df52ca3883 100644
--- a/c/src/lib/libbsp/mips/jmr3904/Makefile.am
+++ b/c/src/lib/libbsp/mips/jmr3904/Makefile.am
+libbsp_a_CPPFLAGS = $(AM_CPPFLAGS) -DTX39
 libbsp_a_SOURCES =
 # startup
@@ -48,8 +49,8 @@ libbsp_a_SOURCES += irq/vectorisrs.c
 include $(srcdir)/../../../../../../bsps/mips/jmr3904/headers.am
diff --git a/c/src/lib/libbsp/mips/jmr3904/make/custom/jmr3904.cfg b/c/src/lib/libbsp/mips/jmr3904/make/custom/jmr3904.cfg
index 6b761356da..ed4e6b3be0 100644
--- a/c/src/lib/libbsp/mips/jmr3904/make/custom/jmr3904.cfg
+++ b/c/src/lib/libbsp/mips/jmr3904/make/custom/jmr3904.cfg
@@ -5,7 +5,6 @@
 RTEMS_CPU=mips
-RTEMS_CPU_MODEL=tx3904
 CPU_CFLAGS = -march=r3900 -Wa,-xgot -G0
diff --git a/c/src/lib/libbsp/mips/malta/Makefile.am b/c/src/lib/libbsp/mips/malta/Makefile.am
index 5349907003..ea431d93be 100644
--- a/c/src/lib/libbsp/mips/malta/Makefile.am
+++ b/c/src/lib/libbsp/mips/malta/Makefile.am
@@ -55,8 +55,8 @@ libbsp_a_SOURCES += ../../shared/console_control.c
 libbsp_a_SOURCES += ../../shared/timerstub.c
 # pci
 libbsp_a_SOURCES += pci/pci.c
diff --git a/c/src/lib/libbsp/mips/malta/make/custom/malta.cfg b/c/src/lib/libbsp/mips/malta/make/custom/malta.cfg
index 2bd1eab988..a25abcc911 100644
--- a/c/src/lib/libbsp/mips/malta/make/custom/malta.cfg
+++ b/c/src/lib/libbsp/mips/malta/make/custom/malta.cfg
@@ -5,7 +5,6 @@
 RTEMS_CPU=mips
-RTEMS_CPU_MODEL=mips24kf
diff --git a/c/src/lib/libbsp/mips/rbtx4925/Makefile.am b/c/src/lib/libbsp/mips/rbtx4925/Makefile.am
index 74c8303492..446d0535ed 100644
--- a/c/src/lib/libbsp/mips/rbtx4925/Makefile.am
+++ b/c/src/lib/libbsp/mips/rbtx4925/Makefile.am
@@ -56,9 +56,10 @@ libbsp_a_SOURCES += irq/vectorisrs.c
 libbsp_a_SOURCES += ../shared/irq/interruptmask_TX49.c
-libbsp_a_LIBADD += ../../../libcpu/@RTEMS_CPU@/tx49/timer.rel
 include $(srcdir)/../../../../../../bsps/mips/rbtx4925/headers.am
diff --git a/c/src/lib/libbsp/mips/rbtx4925/make/custom/rbtx4925.cfg b/c/src/lib/libbsp/mips/rbtx4925/make/custom/rbtx4925.cfg
index 37b1e00443..744fdb4240 100644
--- a/c/src/lib/libbsp/mips/rbtx4925/make/custom/rbtx4925.cfg
+++ b/c/src/lib/libbsp/mips/rbtx4925/make/custom/rbtx4925.cfg
@@ -4,8 +4,6 @@
-RTEMS_CPU_MODEL=tx4925
diff --git a/c/src/lib/libbsp/mips/rbtx4938/Makefile.am b/c/src/lib/libbsp/mips/rbtx4938/Makefile.am
index 7d29c80d95..efce115736 100644
--- a/c/src/lib/libbsp/mips/rbtx4938/Makefile.am
+++ b/c/src/lib/libbsp/mips/rbtx4938/Makefile.am
@@ -20,6 +20,7 @@ project_lib_DATA = start.$(OBJEXT)
+libbsp_a_CPPFLAGS = $(AM_CPPFLAGS) -DTX49
 libbsp_a_SOURCES =
 # startup
 include $(srcdir)/../../../../../../bsps/mips/rbtx4938/headers.am
diff --git a/c/src/lib/libbsp/mips/rbtx4938/make/custom/rbtx4938.cfg b/c/src/lib/libbsp/mips/rbtx4938/make/custom/rbtx4938.cfg
index a60a8c6307..42cdf17a04 100644
--- a/c/src/lib/libbsp/mips/rbtx4938/make/custom/rbtx4938.cfg
+++ b/c/src/lib/libbsp/mips/rbtx4938/make/custom/rbtx4938.cfg
@@ -4,8 +4,6 @@
-RTEMS_CPU_MODEL=tx4938
diff --git a/c/src/lib/libcpu/mips/Makefile.am b/c/src/lib/libcpu/mips/Makefile.am
deleted file mode 100644
index 8ae999dd28..0000000000
--- a/c/src/lib/libcpu/mips/Makefile.am
+++ /dev/null
@@ -1,48 +0,0 @@
-ACLOCAL_AMFLAGS = -I ../../../aclocal
-include $(top_srcdir)/../../../automake/compile.am
-EXTRA_DIST =
-noinst_PROGRAMS =
-## interrupts
-if rm52xx
-interrupts_CPPFLAGS = -DRM52XX
-endif
-if tx39
-interrupts_CPPFLAGS = -DTX39
-endif
-if tx49
-interrupts_CPPFLAGS = -DTX49
-endif
-noinst_PROGRAMS += shared/interrupts.rel
-shared_interrupts_rel_SOURCES = shared/interrupts/installisrentries.c \
-    shared/interrupts/isr_entries.S shared/interrupts/isr_entries.h
-shared_interrupts_rel_CPPFLAGS = $(AM_CPPFLAGS) $(interrupts_CPPFLAGS)
-shared_interrupts_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
-if tx39
-endif
-if tx49
-noinst_PROGRAMS += tx49/timer.rel
-tx49_timer_rel_SOURCES = timer/timer.c timer/gettime.S
-tx49_timer_rel_CPPFLAGS = $(AM_CPPFLAGS)
-tx49_timer_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
-endif
-if au1x00
-endif
-if rm52xx
-noinst_PROGRAMS += rm52xx/timer.rel
-rm52xx_timer_rel_SOURCES = timer/timer.c timer/gettime.S
-rm52xx_timer_rel_CPPFLAGS = $(AM_CPPFLAGS)
-rm52xx_timer_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
-endif
-include $(top_srcdir)/../../../automake/local.am
diff --git a/c/src/lib/libcpu/mips/configure.ac b/c/src/lib/libcpu/mips/configure.ac
index 6a9e2665d9..0000000000
--- a/c/src/lib/libcpu/mips/configure.ac
+++ /dev/null
@@ -1,40 +0,0 @@
-## Process this file with autoconf to produce a configure script.
-AC_PREREQ([2.69])
-AC_INIT([rtems-c-src-lib-libcpu-mips],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
-AC_CONFIG_SRCDIR([timer])
-RTEMS_TOP([../../../../..],[../../..])
-RTEMS_SOURCE_TOP
-RTEMS_BUILD_TOP
-RTEMS_CANONICAL_TARGET_CPU
-AM_INIT_AUTOMAKE([no-define foreign subdir-objects 1.12.2])
-AM_MAINTAINER_MODE
-RTEMS_ENV_RTEMSBSP
-RTEMS_PROJECT_ROOT
-RTEMS_PROG_CC_FOR_TARGET
-AM_PROG_CC_C_O
-RTEMS_CANONICALIZE_TOOLS
-RTEMS_PROG_CCAS
-AM_CONDITIONAL(tx39, test "$RTEMS_CPU_MODEL" = "tx3904")
-AM_CONDITIONAL(tx49, test "$RTEMS_CPU_MODEL" = "tx4925" \
-|| test "$RTEMS_CPU_MODEL" = "tx4938" )
-AM_CONDITIONAL(rm52xx, test "$RTEMS_CPU_MODEL" = "rm5231")
-AM_CONDITIONAL(mongoosev, test "$RTEMS_CPU_MODEL" = "mongoosev")
-AM_CONDITIONAL(au1x00, test "$RTEMS_CPU_MODEL" = "au1x00")
-RTEMS_AMPOLISH3
-# Explicitly list all Makefiles here
-AC_CONFIG_FILES([Makefile
-AC_OUTPUT
diff --git a/c/src/lib/libcpu/mips/shared/interrupts/interruptmask.c b/c/src/lib/libcpu/mips/shared/interrupts/interruptmask.c
index 9f2b679a77..0000000000
--- a/c/src/lib/libcpu/mips/shared/interrupts/interruptmask.c
+++ /dev/null
@@ -1,20 +0,0 @@
-#include <rtems.h>
- *  This function returns a mask value which is used to select the bits
- *  in the processor status register that can be set to enable interrupts.
- *  The mask value should not include the 2 software interrupt enable bits.
-uint32_t mips_interrupt_mask( void )
-	uint32_t interrupt_mask;
-#ifdef TX49
-	interrupt_mask = 0x00000400;			/* Toshiba TX49 processors have a non-standard interrupt mask */
-#else
-	interrupt_mask = 0x0000fc00;
-#endif
-	return(interrupt_mask);
2.12.3
