[PATCH v2 0/3] Fix compiler errors for SMP on i386
Amaan Cheval
amaan.cheval at gmail.com
Tue Mar 13 16:14:12 UTC 2018
See this thread[1] for v1 of the patch. The changes in this version
are similar, except they *still throw a compile-time error* to
indicate the missing i386 support for SMP, while still fixing up the
rest of the problems that prevented compilation, as suggested by Joel
here[2].
[1] https://lists.rtems.org/pipermail/devel/2018-March/020409.html
[2] https://lists.rtems.org/pipermail/devel/2018-March/020438.html
Amaan Cheval (3):
i386/smp: Define CPU_Interrupt_frame as non-void struct
i386/smp: Have ld use incremental build for appstart.o
i386/smp: Export _CPU_SMP_Prepare_start_multitasking as a function
c/src/lib/libbsp/i386/pc386/Makefile.am | 2 +-
c/src/lib/libbsp/i386/shared/smp/smp-imps.c | 5 +++++
cpukit/score/cpu/i386/include/rtems/score/cpu.h | 19 ++++++++++++++++---
3 files changed, 22 insertions(+), 4 deletions(-)
2.13.0
