Improve coverage analysis toolset
Cillian O'Donnell
cpodonnell8 at gmail.com
Thu Mar 15 11:28:43 UTC 2018
Looks good. If you run the samples without coverage is everything ok?
So removing --coverage and tacking on /samples
$HOME/development/rtems-tools/tester/rtems-test --rtems-bsp=leon3-qemu
--log=log-leon3.log --rtems-tools=$HOME/development/rtems/5
--rtems-builddir=$HOME/development/rtems/kernel/leon3 sparc-rtems5/c/leon3/
testsuites/samples
Do the tests run?
On 15 March 2018 at 10:53, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> I have attached the output of the ls of that directory
> -- vijay
> On 15 March 2018 at 15:52, Cillian O'Donnell <cpodonnell8 at gmail.com>
> wrote:
>> On 15 March 2018 at 03:58, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
>> > wrote:
>>> hello ,
>>> as told by Joel , I started this thread to further discuss the coverage
>>> analysis toolset .
>>> Current status is , I'm trying to builld and run rtems-test from the
>>> coverage-merge branch of the previous GSoC student Cillian .
>>> https://github.com/cillianodonnell/rtems-tools/tree/coverage-merge
>>> I'm getting an error that says .
>>> "Covoar not found !"
>> It's supposed to find it in rtems-tools/build/tester/covoar/ If it's in
>> there it should be fine. Can you show me the contents of that directory?
>> cpod at cpod ~/development/rtems/test/rtems-tools/build/tester/covoar $ ls
>>> the Covoar appeared in rtems-tools/tester/covoar .
>>> Vijay
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180315/1fc266b5/attachment-0001.html>
