Improve coverage analysis toolset
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Thu Mar 15 12:26:45 UTC 2018
It runs with a bunch of errors . I have attached the log file
-- vijay
On 15 March 2018 at 16:58, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
> Looks good. If you run the samples without coverage is everything ok?
> So removing --coverage and tacking on /samples
> $HOME/development/rtems-tools/tester/rtems-test --rtems-bsp=leon3-qemu
> --log=log-leon3.log --rtems-tools=$HOME/development/rtems/5
> --rtems-builddir=$HOME/development/rtems/kernel/leon3
> sparc-rtems5/c/leon3/testsuites/samples
> Do the tests run?
> On 15 March 2018 at 10:53, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> wrote:
>> I have attached the output of the ls of that directory
>> -- vijay
>> On 15 March 2018 at 15:52, Cillian O'Donnell <cpodonnell8 at gmail.com>
>> wrote:
>>> On 15 March 2018 at 03:58, Vijay Kumar Banerjee <
>>> vijaykumar9597 at gmail.com> wrote:
>>>> hello ,
>>>> as told by Joel , I started this thread to further discuss the coverage
>>>> analysis toolset .
>>>> Current status is , I'm trying to builld and run rtems-test from the
>>>> coverage-merge branch of the previous GSoC student Cillian .
>>>> https://github.com/cillianodonnell/rtems-tools/tree/coverage-merge
>>>> I'm getting an error that says .
>>>> "Covoar not found !"
>>> It's supposed to find it in rtems-tools/build/tester/covoar/ If it's in
>>> there it should be fine. Can you show me the contents of that directory?
>>> cpod at cpod ~/development/rtems/test/rtems-tools/build/tester/covoar $ ls
>>>> the Covoar appeared in rtems-tools/tester/covoar .
>>>> Vijay
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180315/544198ff/attachment.html>
Type: text/x-log
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180315/544198ff/attachment.bin>
