Improve coverage analysis toolset
Cillian O'Donnell
cpodonnell8 at gmail.com
Thu Mar 15 13:47:57 UTC 2018
On 15 March 2018 at 12:26, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> It runs with a bunch of errors . I have attached the log file
Ok, I'm guessing you didn't set up Couverture-Qemu (special version of qemu
designed for generating extra trace data for coverage analysis). That's
what those errors are about. I have an RSB build for that.
https://github.com/cillianodonnell/rtems-source-builder/tree/couverture-build
and the instructions for building it are
https://devel.rtems.org/wiki/GSoC/2017/coveragetools#BuildingCouverture-QemuwiththeRSB
I know what the other problem is too. I have a specific environment
variable defined for the path, sorry I can't even remember putting it
there, I thought that was automatically generated (probably should be,
another thing to add to the list :)... ). So wherever you stuck the export
path for where the rsb built the tools, in .bashrc or whatever you're
using. Also put something like:
export PATH=$HOME/development/rtems/5/bin:$PATH
export PATH=$HOME/development/rtems/test/rtems-tools/build/tester/covoar:$PATH
or you could just copy covoar into the /bin directory with all the other
rsb tools gcc and all that, it'll find it either way.
> -- vijay
> On 15 March 2018 at 16:58, Cillian O'Donnell <cpodonnell8 at gmail.com>
> wrote:
>> Looks good. If you run the samples without coverage is everything ok?
>> So removing --coverage and tacking on /samples
>> $HOME/development/rtems-tools/tester/rtems-test --rtems-bsp=leon3-qemu
>> --log=log-leon3.log --rtems-tools=$HOME/development/rtems/5
>> --rtems-builddir=$HOME/development/rtems/kernel/leon3
>> sparc-rtems5/c/leon3/testsuites/samples
>> Do the tests run?
>> On 15 March 2018 at 10:53, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
>> > wrote:
>>> I have attached the output of the ls of that directory
>>> -- vijay
>>> On 15 March 2018 at 15:52, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>> wrote:
>>>> On 15 March 2018 at 03:58, Vijay Kumar Banerjee <
>>>> vijaykumar9597 at gmail.com> wrote:
>>>>> hello ,
>>>>> as told by Joel , I started this thread to further discuss the
>>>>> coverage analysis toolset .
>>>>> Current status is , I'm trying to builld and run rtems-test from the
>>>>> coverage-merge branch of the previous GSoC student Cillian .
>>>>> https://github.com/cillianodonnell/rtems-tools/tree/coverage-merge
>>>>> I'm getting an error that says .
>>>>> "Covoar not found !"
>>>> It's supposed to find it in rtems-tools/build/tester/covoar/ If it's
>>>> in there it should be fine. Can you show me the contents of that directory?
>>>> cpod at cpod ~/development/rtems/test/rtems-tools/build/tester/covoar $ ls
>>>>> the Covoar appeared in rtems-tools/tester/covoar .
>>>>> Vijay
>>>>> _______________________________________________
>>>>> devel mailing list
>>>>> devel at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180315/9713cb84/attachment-0001.html>
