[PATCH] Added Getentropy() support to beagle BSP
Udit agarwal
dev.madaari at gmail.com
Fri Mar 16 09:31:06 UTC 2018
Thanks for pointing that out, I have rectified the indentation errors.
Here's the patch for atsam:
>From 8e5e17525a76e68bc4d869d0af9700aaa5628483 Mon Sep 17 00:00:00 2001
Date: Fri, 16 Mar 2018 14:54:53 +0530
Subject: [PATCH] arm/atsam: protect TRNG_GetRandData with mutex
c/src/lib/libbsp/arm/atsam/startup/getentropy-trng.c | 7 ++++++-
1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/c/src/lib/libbsp/arm/atsam/startup/getentropy-trng.c
b/c/src/lib/libbsp/arm/atsam/startup/getentropy-trng.c
index 11e24dc..54a1cef 100644
--- a/c/src/lib/libbsp/arm/atsam/startup/getentropy-trng.c
+++ b/c/src/lib/libbsp/arm/atsam/startup/getentropy-trng.c
@@ -17,6 +17,9 @@
#include <rtems/sysinit.h>
+static rtems_mutex atsam_trng_mutex =
+ RTEMS_MUTEX_INITIALIZER("atsam_trng");
static void atsam_trng_enable(void)
PMC_EnablePeripheral(ID_TRNG);
@@ -25,6 +28,8 @@ static void atsam_trng_enable(void)
int getentropy(void *ptr, size_t n)
+ rtems_mutex_lock(&atsam_trng_mutex);
while (n > 0) {
uint32_t random;
size_t copy;
@@ -50,7 +55,7 @@ int getentropy(void *ptr, size_t n)
n -= copy;
ptr += copy;
+ rtems_mutex_unlock(&atsam_trng_mutex);
return 0;
1.9.1
On Thu, Mar 15, 2018 at 7:52 PM, Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Mar 15, 2018 at 7:00 AM, Udit agarwal <dev.madaari at gmail.com>
> wrote:
> > On Thu, Mar 15, 2018 at 2:38 PM, Sebastian Huber
> > <sebastian.huber at embedded-brains.de> wrote:
> >> On 15/03/18 09:20, Udit agarwal wrote:
> >>> Also, will it be ok to keep atsam_trng_mutex even after user has
> finished
> >>> using getentropy() i.e when we don't use destroy(&atsam_trng_mutex) at
> all?
> >> Why do you want to destroy the mutex?
> > Just trying to reduce redundancy, but then i don't think that's a good
> idea.
> > BTW, here's atsam patch, please have a look:
> > From 35313002ea19715c5914c5983a24471b0763aa68 Mon Sep 17 00:00:00 2001
> > From: Udit agarwal <dev.madaari at gmail.com>
> > Date: Thu, 15 Mar 2018 16:21:51 +0530
> > Subject: [PATCH] Added mutex across TRNG_GetRandData
> In the commit message, identify the rtems subsystem. I guess we don't
> have detailed advice on the wiki for this, but here I guess we usually
> would have something like "arm/atsam: protect TRNG_GetRandData with
> mutex"
> > c/src/lib/libbsp/arm/atsam/startup/getentropy-trng.c | 7 +++++++
> > 1 file changed, 7 insertions(+)
> > index 11e24dc..2789970 100644
> > @@ -16,6 +16,9 @@
> > #include <unistd.h>
> > #include <string.h>
> > +#include <rtems/thread.h>
> The second line should be indented 2 more levels (4 spaces).
> https://devel.rtems.org/wiki/Developer/Coding/80_characters_per_line
> > @@ -25,6 +28,9 @@ static void atsam_trng_enable(void)
> The number of indent spaces here look wrong to me. It should be 2.
> > while (n > 0) {
> > uint32_t random;
> > size_t copy;
> > @@ -51,6 +57,7 @@ int getentropy(void *ptr, size_t n)
> > ptr += copy;
> ditto.
> > return 0;
> > 1.9.1
> >> Sebastian Huber, embedded brains GmbH
> >> Address : Dornierstr. 4, D-82178 Puchheim, Germany
> >> Phone : +49 89 189 47 41-16
> >> Fax : +49 89 189 47 41-09
> >> E-Mail : sebastian.huber at embedded-brains.de
> >> PGP : Public key available on request.
> >> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180316/ebb0b4c5/attachment.html>
