[PATCH] Added Getentropy() support to beagle BSP
Udit agarwal
dev.madaari at gmail.com
Fri Mar 16 10:10:52 UTC 2018
Patch for BBB:
>From a6b3b58a38a6925bf26b6573f36fc652708f9f32 Mon Sep 17 00:00:00 2001
Date: Fri, 16 Mar 2018 15:37:05 +0530
Subject: [PATCH] arm/beagle: add TRNG based getentropy implementation
bsps/arm/include/libcpu/am335x.h | 33 ++++++
c/src/lib/libbsp/arm/beagle/Makefile.am | 4 +-
c/src/lib/libbsp/arm/beagle/dev/bbb_getentropy.c | 130
3 files changed, 166 insertions(+), 1 deletion(-)
create mode 100644 c/src/lib/libbsp/arm/beagle/dev/bbb_getentropy.c
diff --git a/bsps/arm/include/libcpu/am335x.h
b/bsps/arm/include/libcpu/am335x.h
index 367e97c..a6fb8b8 100644
--- a/bsps/arm/include/libcpu/am335x.h
+++ b/bsps/arm/include/libcpu/am335x.h
@@ -14,11 +14,17 @@
* Modified by Ben Gras <beng at shrike-systems.com> to add lots
* of beagleboard/beaglebone definitions, delete lpc32xx specific
* ones, and merge with some other header files.
+ * Modified by Udit agarwal <dev.madaari at gmail.com> to add true random
+ * number generating module definitions and TRNG register structure.
#if !defined(_AM335X_H_)
#define _AM335X_H_
+/* For TRNG register definition */
+#include <stdint.h>
/* Interrupt controller memory map */
#define OMAP3_DM37XX_INTR_BASE 0x48200000 /* INTCPS physical address */
@@ -701,4 +707,31 @@
#define AM335X_CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L4_GCLK
(0x00000020u)
#define AM335X_I2C_INT_STOP_CONDITION AM335X_I2C_IRQSTATUS_BF
+/* TRNG Registers */
+/* TRNG base address */
+#define TRNG_BASE 0x48310000
+/* Mask bits for trng clock status */
+#define AM335X_CLK_TRNG_BIT_MASK (0x30000)
+/* Mask bits for output ready flag */
+#define TRNG_STATUS_RDY (1u << 0)
+/* Mask bits for FRO related error */
+#define TRNG_STATUS_ERR (1u << 1)
+/* Mask bits for clock status */
+#define TRNG_STATUS_CLK (1u << 31)
+/* enable module */
+#define AM335X_TRNG_ENABLE (1 << 10)
+/* TRNG module clock register */
+#define CM_PER_TRNG_CLKCTRL (AM335X_CM_PER_ADDR | (9 << 4))
+/* TRNG register structure */
+typedef struct {
+ uint64_t output; /* 00 */
+ uint32_t status; /* 08 */
+ uint32_t irq_en; /* 0c */
+ uint32_t status_clr; /* 10 */
+ uint32_t control; /* 14 */
+ uint32_t config; /* 18 */
+} am335x_trng_register;
#endif
diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am
b/c/src/lib/libbsp/arm/beagle/Makefile.am
index 8251660..c483dc4 100644
--- a/c/src/lib/libbsp/arm/beagle/Makefile.am
+++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
@@ -40,7 +40,6 @@ libbsp_a_LIBADD =
# Shared
libbsp_a_SOURCES += ../../shared/bootcard.c
-libbsp_a_SOURCES += ../../shared/getentropy-cpucounter.c
libbsp_a_SOURCES += ../../shared/src/bsp-fdt.c
libbsp_a_SOURCES += ../../shared/bspclean.c
libbsp_a_SOURCES += ../../shared/bspgetworkarea.c
@@ -88,6 +87,9 @@ libbsp_a_SOURCES += gpio/bbb-gpio.c
#pwm
libbsp_a_SOURCES += pwm/pwm.c
+#getentropy
+libbsp_a_SOURCES += dev/bbb_getentropy.c
#RTC
libbsp_a_SOURCES += rtc.c
libbsp_a_SOURCES += ../../shared/tod.c
diff --git a/c/src/lib/libbsp/arm/beagle/dev/bbb_getentropy.c
b/c/src/lib/libbsp/arm/beagle/dev/bbb_getentropy.c
new file mode 100644
index 0000000..b3ea681
--- /dev/null
+++ b/c/src/lib/libbsp/arm/beagle/dev/bbb_getentropy.c
@@ -0,0 +1,130 @@
+* @file
+* @ingroup arm_beagle
+* @brief Getentropy implementation on BeagleBone Black BSP
+* Copyright (c) 2018 Udit agarwal <dev.madaari at gmail.com>
+* All rights reserved.
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following conditions
+* are met:
+* 1. Redistributions of source code must retain the above copyright
+* notice, this list of conditions and the following disclaimer.
+* 2. Redistributions in binary form must reproduce the above copyright
+* notice, this list of conditions and the following disclaimer in the
+* documentation and/or other materials provided with the distribution.
+* THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE
+* ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
CONSEQUENTIAL
+* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
STRICT
+* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+* SUCH DAMAGE.
+#include <libcpu/am335x.h>
+#include <unistd.h>
+#include <string.h>
+#include <rtems/sysinit.h>
+#include <rtems/thread.h>
+/* max refill 34 * 256 cycles */
+#define AM335X_TRNG_MAX_REFILL (34 << 16)
+/* min refill 33 * 64 cycles */
+#define AM335X_TRNG_MIN_REFILL (33 << 0)
+/* startup 33 * 256 cycles */
+#define AM335X_TRNG_STARTUP_CYCLES (33 << 16)
+static rtems_mutex am335x_trng_mutex =
+ RTEMS_MUTEX_INITIALIZER("am335x_trng");
+/* maximun and minimum refill cycle sets the number of samples to be taken
+ * from FRO to generate random number */
+static void am335x_trng_enable(volatile am335x_trng_register *trng)
+ trng->control = trng->config = 0;
+ trng->config |= AM335X_TRNG_MIN_REFILL | AM335X_TRNG_MAX_REFILL ;
+ trng->control |= AM335X_TRNG_STARTUP_CYCLES | AM335X_TRNG_ENABLE ;
+static void am335x_trng_clock_enable(void)
+ volatile am335x_trng_register *trng = (am335x_trng_register*) TRNG_BASE;
+ *(volatile uint8_t *) CM_PER_TRNG_CLKCTRL = 2;
+ while(
+ *(volatile uint32_t *) CM_PER_TRNG_CLKCTRL &
+ AM335X_CLK_TRNG_BIT_MASK
+ /* wait */
+ am335x_trng_enable(trng);
+static uint64_t trng_getranddata(volatile am335x_trng_register *trng)
+ uint64_t output = trng->output;
+ return output;
+int getentropy(void *ptr, size_t n)
+ (am335x_trng_register*) TRNG_BASE;
+ /* for mutual exclusion synchronization between multiple
+ * access to TRNG register in different contexts */
+ rtems_mutex_lock(&am335x_trng_mutex);
+ while ( n > 0 )
+ uint64_t random;
+ size_t copy;
+ /* wait untill TRNG becomes ready with next set of random data */
+ while ( ( trng->status & TRNG_STATUS_RDY ) == 0 )
+ /* wait */
+ random = trng_getranddata(trng);
+ /* clear the status flag after reading to generate new random
+ * value */
+ trng->status_clr = TRNG_STATUS_RDY;
+ /* checking for error by masking all bits other then error bit in
+ * status register */
+ if ( ((trng->status & TRNG_STATUS_ERR) >> 1) == 1 )
+ copy = sizeof(random);
+ if ( n < copy )
+ copy = n;
+ memcpy(ptr, &random, copy);
+ n -= copy;
+ ptr = (char*)ptr + copy;
+ rtems_mutex_unlock(&am335x_trng_mutex);
+ return 0;
+RTEMS_SYSINIT_ITEM(
+ am335x_trng_clock_enable,
+ RTEMS_SYSINIT_DEVICE_DRIVERS,
+ RTEMS_SYSINIT_ORDER_LAST
1.9.1
On Fri, Mar 16, 2018 at 3:01 PM, Udit agarwal <dev.madaari at gmail.com> wrote:
> Thanks for pointing that out, I have rectified the indentation errors.
> Here's the patch for atsam:
> From 8e5e17525a76e68bc4d869d0af9700aaa5628483 Mon Sep 17 00:00:00 2001
> From: Udit agarwal <dev.madaari at gmail.com>
> Date: Fri, 16 Mar 2018 14:54:53 +0530
> Subject: [PATCH] arm/atsam: protect TRNG_GetRandData with mutex
> c/src/lib/libbsp/arm/atsam/startup/getentropy-trng.c | 7 ++++++-
> 1 file changed, 6 insertions(+), 1 deletion(-)
> diff --git a/c/src/lib/libbsp/arm/atsam/startup/getentropy-trng.c
> b/c/src/lib/libbsp/arm/atsam/startup/getentropy-trng.c
> index 11e24dc..54a1cef 100644
> --- a/c/src/lib/libbsp/arm/atsam/startup/getentropy-trng.c
> +++ b/c/src/lib/libbsp/arm/atsam/startup/getentropy-trng.c
> @@ -17,6 +17,9 @@
> #include <string.h>
> +static rtems_mutex atsam_trng_mutex =
> + RTEMS_MUTEX_INITIALIZER("atsam_trng");
> static void atsam_trng_enable(void)
> PMC_EnablePeripheral(ID_TRNG);
> @@ -25,6 +28,8 @@ static void atsam_trng_enable(void)
> + rtems_mutex_lock(&atsam_trng_mutex);
> while (n > 0) {
> uint32_t random;
> size_t copy;
> @@ -50,7 +55,7 @@ int getentropy(void *ptr, size_t n)
> n -= copy;
> ptr += copy;
> + rtems_mutex_unlock(&atsam_trng_mutex);
> return 0;
> 1.9.1
> On Thu, Mar 15, 2018 at 7:52 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> On Thu, Mar 15, 2018 at 7:00 AM, Udit agarwal <dev.madaari at gmail.com>
>> wrote:
>> > On Thu, Mar 15, 2018 at 2:38 PM, Sebastian Huber
>> > <sebastian.huber at embedded-brains.de> wrote:
>> >> On 15/03/18 09:20, Udit agarwal wrote:
>> >>> Also, will it be ok to keep atsam_trng_mutex even after user has
>> finished
>> >>> using getentropy() i.e when we don't use destroy(&atsam_trng_mutex)
>> at all?
>> >> Why do you want to destroy the mutex?
>> > Just trying to reduce redundancy, but then i don't think that's a good
>> idea.
>> > BTW, here's atsam patch, please have a look:
>> > From 35313002ea19715c5914c5983a24471b0763aa68 Mon Sep 17 00:00:00 2001
>> > Date: Thu, 15 Mar 2018 16:21:51 +0530
>> > Subject: [PATCH] Added mutex across TRNG_GetRandData
>> In the commit message, identify the rtems subsystem. I guess we don't
>> have detailed advice on the wiki for this, but here I guess we usually
>> would have something like "arm/atsam: protect TRNG_GetRandData with
>> mutex"
>> > c/src/lib/libbsp/arm/atsam/startup/getentropy-trng.c | 7 +++++++
>> > 1 file changed, 7 insertions(+)
>> > index 11e24dc..2789970 100644
>> > @@ -16,6 +16,9 @@
>> > #include <unistd.h>
>> > #include <string.h>
>> The second line should be indented 2 more levels (4 spaces).
>> https://devel.rtems.org/wiki/Developer/Coding/80_characters_per_line
>> > @@ -25,6 +28,9 @@ static void atsam_trng_enable(void)
>> The number of indent spaces here look wrong to me. It should be 2.
>> > while (n > 0) {
>> > uint32_t random;
>> > size_t copy;
>> > @@ -51,6 +57,7 @@ int getentropy(void *ptr, size_t n)
>> > ptr += copy;
>> ditto.
>> > return 0;
>> > 1.9.1
>> >> Sebastian Huber, embedded brains GmbH
>> >> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> >> Phone : +49 89 189 47 41-16
>> >> Fax : +49 89 189 47 41-09
>> >> E-Mail : sebastian.huber at embedded-brains.de
>> >> PGP : Public key available on request.
>> >> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180316/d381d5b7/attachment-0001.html>
