Improve coverage analysis toolset
Fri Mar 16 19:42:15 UTC 2018
Vijay,
On Fri, Mar 16, 2018 at 10:59 AM, Vijay Kumar Banerjee
<vijaykumar9597 at gmail.com> wrote:
> building couverture-qemu from rtems-source-builder (
> https://github.com/cillianodonnell/rtems-source-builder/tree/couverture-build
> gives error building auromake-1.12.6-x86_64-linux-gnu-1 .
> I have attached the error report .
Try to build just the autotools:
source-builder/sb-set-builder devel/autotools
Assuming that fails, report this as a problem in a separate email
thread to focus effort on fixing the right "bug".
> -- vijay
> On 15 March 2018 at 19:17, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
>> On 15 March 2018 at 12:26, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
>> wrote:
>>> It runs with a bunch of errors . I have attached the log file
>> Ok, I'm guessing you didn't set up Couverture-Qemu (special version of
>> qemu designed for generating extra trace data for coverage analysis). That's
>> what those errors are about. I have an RSB build for that.
>> and the instructions for building it are
>> https://devel.rtems.org/wiki/GSoC/2017/coveragetools#BuildingCouverture-QemuwiththeRSB
>> I know what the other problem is too. I have a specific environment
>> variable defined for the path, sorry I can't even remember putting it there,
>> I thought that was automatically generated (probably should be, another
>> thing to add to the list :)... ). So wherever you stuck the export path for
>> where the rsb built the tools, in .bashrc or whatever you're using. Also put
>> something like:
>> export PATH=$HOME/development/rtems/5/bin:$PATH
>> export
>> PATH=$HOME/development/rtems/test/rtems-tools/build/tester/covoar:$PATH
>> or you could just copy covoar into the /bin directory with all the other
>> rsb tools gcc and all that, it'll find it either way.
>>> -- vijay
>>> On 15 March 2018 at 16:58, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>> wrote:
>>>> Looks good. If you run the samples without coverage is everything ok?
>>>> So removing --coverage and tacking on /samples
>>>> $HOME/development/rtems-tools/tester/rtems-test --rtems-bsp=leon3-qemu
>>>> --log=log-leon3.log --rtems-tools=$HOME/development/rtems/5
>>>> --rtems-builddir=$HOME/development/rtems/kernel/leon3
>>>> sparc-rtems5/c/leon3/testsuites/samples
>>>> Do the tests run?
>>>> On 15 March 2018 at 10:53, Vijay Kumar Banerjee
>>>>> I have attached the output of the ls of that directory
>>>>> -- vijay
>>>>> On 15 March 2018 at 15:52, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>> wrote:
>>>>>> On 15 March 2018 at 03:58, Vijay Kumar Banerjee
>>>>>>> hello ,
>>>>>>> as told by Joel , I started this thread to further discuss the
>>>>>>> coverage analysis toolset .
>>>>>>> Current status is , I'm trying to builld and run rtems-test from the
>>>>>>> coverage-merge branch of the previous GSoC student Cillian .
>>>>>>> https://github.com/cillianodonnell/rtems-tools/tree/coverage-merge
>>>>>>> I'm getting an error that says .
>>>>>>>  "Covoar not found !"
>>>>>> It's supposed to find it in rtems-tools/build/tester/covoar/ If it's
>>>>>> in there it should be fine. Can you show me the contents of that directory?
>>>>>> cpod at cpod ~/development/rtems/test/rtems-tools/build/tester/covoar $
>>>>>> ls
>>>>>>> the Covoar appeared in rtems-tools/tester/covoar .
>>>>>>> Vijay
>>>>>>> _______________________________________________
>>>>>>> devel mailing list
>>>>>>> devel at rtems.org
>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
