Improve coverage analysis toolset
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Mon Mar 26 04:00:32 UTC 2018
1. Yes , I plan to work on identifying the discrepancies between what
covoar reports directly and what the gcov reports based on its gcov output.
2. I understand this point that the scripting that generates symbol set
file, needs to be modified accordingly
3. I have planned to make a note and understand the requirements, changes
needed and the desired type of output during the community bonding period,
so that I have a clear picture of the objective before I start working on
it.
The plan is to work on gcov after the existing work is merged.
Have I planned too much to work on during the summer? Should I modify my
plan in some way? Please suggest .
Thanks
-- vijay
On 26 March 2018 at 03:49, Joel Sherrill <joel at rtems.org> wrote:
> Just a couple of questions and planning issues. The planning issues
> are because the requirements for some of the work are likely not solid
> on our side.
> 1. Do you plan to work on identifying the discrepancies between
> what covoar reports directly and what gcov reports based on its
> gcov file output? I ask because I lined up someone from the GCC
> community who should be able to tell us what is not right once
> we have specific cases.
> 2. My recollection is that the symbol set file is generated from
> the RTEMS libraries under test. The scripting that generates this
> file will have to change also. The set of symbols changes as
> RTEMS evolves.
> 3. Chris has had ideas on changing the output from directly
> producing ascii and html to something else. It is on he and I
> to give you input on the actual format.
> Personally getting all existing work merged and it in a state
> where we can produce coverage reports again is really a
> critical thing. The previous work changed it from being
> a standalone shell script that drove things to part of the RSB
> and make it possible to have the reports based on subdirectories
> rather than one large report.
> I don't 'think this changes your plan except that the plan seems to
> put gcov as bonus work. It isn't discussed as work during the
> summer.It would be nice to get gcov correctness done earlier
> because that might be the best way to nice reports. For
> example, running lcov on the .gcov files produced by covoar
> might be an option.
> --joel
> On Sun, Mar 25, 2018 at 3:16 PM, Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
>> submitted !
>> If you find time , please give final review as well.
>> Thanks
>> On 26 Mar 2018 1:44 a.m., "Joel Sherrill" <joel at rtems.org> wrote:
>>> I am out and not at a computer. Someone can double check me but I
>>> believe you can replace the PDF you upload.
>>> Unless someone answers soon, just upload it.
>>> --joel
>>> On Mar 25, 2018 2:37 PM, "Vijay Kumar Banerjee" <
>>>> It's the last day before the deadline!
>>>> Please provide a final review of the proposal before submitting.
>>>> Thanks
>>>> -- vijay
>>>> On 24 March 2018 at 21:37, Vijay Kumar Banerjee <
>>>>> hello mentors and other developers of the community , there are only
>>>>> three days remaining to the GSoC proposal submission deadline.
>>>>> I request the mentors and everyone in the community who has experience
>>>>> in RTEMS, to please go through my proposal for Coverage Analysis tool
>>>>> improvement project , if they have time , and suggest any kind of
>>>>> improvements and changes .
>>>>> here is the link to the proposal
>>>>> https://docs.google.com/document/d/1UjCWE1ojrpDQLQ2fQqxHU0SC
>>>>> rLETlerxD6t0SOcQNLQ/edit?usp=sharing
>>>>> Thank you
>>>>> -- vijay
>>>>> On 22 March 2018 at 04:30, Joel Sherrill <joel at rtems.org> wrote:
>>>>>> Glad you have tests running. Hopefully as Cillian suggested, you can
>>>>>> fix the
>>>>>> remaining issues to see coverage.
>>>>>> We certainly need to get this merged if Chris is OK with it and it
>>>>>> doesn't
>>>>>> break anything else.
>>>>>> I am reviewing proposals now. Seems to be a queue. :)
>>>>>> --joel
>>>>>> On Wed, Mar 21, 2018 at 4:42 AM, Vijay Kumar Banerjee <
>>>>>>> Sir ,
>>>>>>> I have done the changes in the proposal , based on the comments in
>>>>>>> the google doc , please review it and suggest any further changes if
>>>>>>> required
>>>>>>> Thank you ,
>>>>>>> -- vijay
>>>>>>> P.S : the previous version is in parentheses , I will remove them
>>>>>>> after you review the changes .
>>>>>>> On 18 March 2018 at 16:05, Vijay Kumar Banerjee <
>>>>>>>> Thanks Cillian :)
>>>>>>>> It's great to see it running , I'll do some background reading
>>>>>>>> about RSB, and RTEMS-Tools along with the covoar code . And also work on my
>>>>>>>> python skills.
>>>>>>>> to try rtems-test on a bsp that runs gdb , I tried it on erc32 and
>>>>>>>> that also worked.
>>>>>>>> I'm also waiting for Joel and other mentors' review on my draft
>>>>>>>> proposal, so that I can also work on it and make any changes if needed.
>>>>>>>> Thanks .
>>>>>>>> -- vijay
>>>>>>>> On 18 March 2018 at 14:17, Cillian O'Donnell <cpodonnell8 at gmail.com
>>>>>>>> > wrote:
>>>>>>>>> On 18 March 2018 at 06:47, Vijay Kumar Banerjee <
>>>>>>>>>> It worked !
>>>>>>>>> That's great! That's the good news then. I was using an old leon3
>>>>>>>>> build and maybe some older Qemu too and I think that's why I didn't see any
>>>>>>>>> issues initially. I was hoping you could see the coverage running and the
>>>>>>>>> reports generated from that but it looks like the full update to the
>>>>>>>>> current master will be necessary to have a look. So until the parsing for
>>>>>>>>> the INI files is added to the coverage.py we won't see the coverage
>>>>>>>>> running. Unfortunately, I'm in the middle of exams until the following
>>>>>>>>> Monday so I won't be able to sink any more time into it until then. You can
>>>>>>>>> still figure out the RSB problem you're having and do some background
>>>>>>>>> reading, brush up on your Python skills, have a read of the covoar code
>>>>>>>>> https://github.com/RTEMS/rtems-tools/blob/master/tester/covo
>>>>>>>>> ar/covoar.cc
>>>>>>>>> just skim through, read the comments, get a sense of the what it's
>>>>>>>>> doing and in what order.
>>>>>>>>>> It's great to see it running ! I have attached the result .
>>>>>>>>>> -- vijay
>>>>>>>>>> On 18 March 2018 at 02:31, Cillian O'Donnell <
>>>>>>>>>> cpodonnell8 at gmail.com> wrote:
>>>>>>>>>>> On 17 March 2018 at 20:08, Vijay Kumar Banerjee <
>>>>>>>>>>>> yes it prints hello world
>>>>>>>>>>> Alright I've added an .ini for leon3-qemu to the current
>>>>>>>>>>> rtems-tools. Pull this branch
>>>>>>>>>>> https://github.com/cillianodonnell/rtems-tools/tree/ini-update
>>>>>>>>>>> and try
>>>>>>>>>>> $HOME/development/rtems/test/rtems-tools/tester/rtems-test
>>>>>>>>>>> --rtems-tools=$HOME/development/rtems/5
>>>>>>>>>>> --log=coverage-analysis.log --rtems-bsp=leon3_qemu
>>>>>>>>>>> $HOME/development/rtems/leon3/sparc-rtems5/c/leon3/testsuite
>>>>>>>>>>> s/samples
>>>>>>>>>>>> -- vijay
>>>>>>>>>>>> On 18 March 2018 at 01:31, Cillian O'Donnell <
>>>>>>>>>>>>> If you run just one test by itself without rtems-test
>>>>>>>>>>>>> qemu-system-sparc -no-reboot -monitor null -serial stdio
>>>>>>>>>>>>> -nographic -M leon3_generic -kernel $HOME/development/rtems/leon3/
>>>>>>>>>>>>> sparc-rtems5/c/leon3/testsuites/samples/hello/hello.exe
>>>>>>>>>>>>> Does the hello world print out?
>>>>>>>>>>>>> On 17 March 2018 at 14:46, Vijay Kumar Banerjee <
>>>>>>>>>>>>>> I built it manually
>>>>>>>>>>>>>> the environment variable PATH looks like this
>>>>>>>>>>>>>> /home/lunatic/qemu/install/bin:/home/lunatic/development/rte
>>>>>>>>>>>>>> ms/5/bin:/usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/
>>>>>>>>>>>>>> home/lunatic/.local/bin:/home/lunatic/bin
>>>>>>>>>>>>>> I tried to run rtems-test again without --coverage , it gives
>>>>>>>>>>>>>> the same result
>>>>>>>>>>>>>> I have attached the log.
>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>> On 17 March 2018 at 00:55, Cillian O'Donnell <
>>>>>>>>>>>>>>> Yes this is something more than my build, I'll need someone
>>>>>>>>>>>>>>> a bit more expert in the RSB to step in there. In the meantime, lets just
>>>>>>>>>>>>>>> build couverture-qemu manually so we can see is everything else working.
>>>>>>>>>>>>>>> git clone https://github.com/AdaCore/qemu
>>>>>>>>>>>>>>> cd qemu
>>>>>>>>>>>>>>> ./configure --target-list=sparc-softmmu
>>>>>>>>>>>>>>> --prefix=$HOME/qemu/install --disable-docs --disable-virtfs --disable-werror
>>>>>>>>>>>>>>> make
>>>>>>>>>>>>>>> make install
>>>>>>>>>>>>>>> then add the prefix to $PATH in .bashrc as well like before.
>>>>>>>>>>>>>>> export PATH=$HOME/qemu/install/bin:$PATH
>>>>>>>>>>>>>>> Then run rtem-test and see what happens
>>>>>>>>>>>>>>> On 16 March 2018 at 19:13, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>> the same error comes when I try to build qemu from the
>>>>>>>>>>>>>>>> RTEMS/rtems-source-builder as well
>>>>>>>>>>>>>>>> is the issue coming from my system ? I'm using fedora 27
>>>>>>>>>>>>>>>> 64bit
>>>>>>>>>>>>>>>> On 17 Mar 2018 12:39 a.m., "Vijay Kumar Banerjee" <
>>>>>>>>>>>>>>>>> yes , the same thing happens
>>>>>>>>>>>>>>>>> On 17 Mar 2018 12:13 a.m., "Cillian O'Donnell" <
>>>>>>>>>>>>>>>>>> If you build regular qemu with the RSB, does the same
>>>>>>>>>>>>>>>>>> thing happen?
>>>>>>>>>>>>>>>>>> Try
>>>>>>>>>>>>>>>>>> ../source-builder/sb-set-builder --log=qemu_log.txt
>>>>>>>>>>>>>>>>>> --prefix=$HOME/development/5 devel/qemu
>>>>>>>>>>>>>>>>>> On 16 March 2018 at 16:48, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>>> still the same error
>>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>>> On 16 March 2018 at 21:39, Cillian O'Donnell <
>>>>>>>>>>>>>>>>>>>> Just checked and the build was failing because one of
>>>>>>>>>>>>>>>>>>>> the patches needed its hash to be updated to sha256. Just pushed that
>>>>>>>>>>>>>>>>>>>> change. The build finishes successfully on my end. Pull that change into
>>>>>>>>>>>>>>>>>>>> couverture-build branch and try it again. I'm not seeing any automake stuff
>>>>>>>>>>>>>>>>>>>> here, so just check that and let me know.
>>>>>>>>>>>>>>>>>>>> On 16 March 2018 at 14:59, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>>>>> building couverture-qemu from rtems-source-builder (
>>>>>>>>>>>>>>>>>>>>> onnell/rtems-source-builder/tree/couverture-build )
>>>>>>>>>>>>>>>>>>>>> gives error building auromake-1.12.6-x86_64-linux-gnu-1
>>>>>>>>>>>>>>>>>>>>> I have attached the error report .
>>>>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 19:17, Cillian O'Donnell <
>>>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 12:26, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>>>>>>> It runs with a bunch of errors . I have attached the
>>>>>>>>>>>>>>>>>>>>>>> log file
>>>>>>>>>>>>>>>>>>>>>> Ok, I'm guessing you didn't set up Couverture-Qemu
>>>>>>>>>>>>>>>>>>>>>> (special version of qemu designed for generating extra trace data for
>>>>>>>>>>>>>>>>>>>>>> coverage analysis). That's what those errors are about. I have an RSB build
>>>>>>>>>>>>>>>>>>>>>> for that.
>>>>>>>>>>>>>>>>>>>>>> and the instructions for building it are
>>>>>>>>>>>>>>>>>>>>>> https://devel.rtems.org/wiki/G
>>>>>>>>>>>>>>>>>>>>>> SoC/2017/coveragetools#Buildin
>>>>>>>>>>>>>>>>>>>>>> gCouverture-QemuwiththeRSB
>>>>>>>>>>>>>>>>>>>>>> I know what the other problem is too. I have a
>>>>>>>>>>>>>>>>>>>>>> specific environment variable defined for the path, sorry I can't even
>>>>>>>>>>>>>>>>>>>>>> remember putting it there, I thought that was automatically generated
>>>>>>>>>>>>>>>>>>>>>> (probably should be, another thing to add to the list :)... ). So wherever
>>>>>>>>>>>>>>>>>>>>>> you stuck the export path for where the rsb built the tools, in .bashrc or
>>>>>>>>>>>>>>>>>>>>>> whatever you're using. Also put something like:
>>>>>>>>>>>>>>>>>>>>>> export PATH=$HOME/development/rtems/5
>>>>>>>>>>>>>>>>>>>>>> /bin:$PATH
>>>>>>>>>>>>>>>>>>>>>> export PATH=$HOME/development/rtems/t
>>>>>>>>>>>>>>>>>>>>>> est/rtems-tools/build/tester/covoar:$PATH
>>>>>>>>>>>>>>>>>>>>>> or you could just copy covoar into the /bin directory
>>>>>>>>>>>>>>>>>>>>>> with all the other rsb tools gcc and all that, it'll find it either way.
>>>>>>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 16:58, Cillian O'Donnell <
>>>>>>>>>>>>>>>>>>>>>>>> Looks good. If you run the samples without coverage
>>>>>>>>>>>>>>>>>>>>>>>> is everything ok?
>>>>>>>>>>>>>>>>>>>>>>>> So removing --coverage and tacking on /samples
>>>>>>>>>>>>>>>>>>>>>>>> $HOME/development/rtems-tools/tester/rtems-test
>>>>>>>>>>>>>>>>>>>>>>>> --rtems-bsp=leon3-qemu --log=log-leon3.log --rtems-tools=$HOME/development/rtems/5
>>>>>>>>>>>>>>>>>>>>>>>> --rtems-builddir=$HOME/development/rtems/kernel/leon3
>>>>>>>>>>>>>>>>>>>>>>>> Do the tests run?
>>>>>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 10:53, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>>>>>>>>> I have attached the output of the ls of that
>>>>>>>>>>>>>>>>>>>>>>>>> directory
>>>>>>>>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 15:52, Cillian O'Donnell <
>>>>>>>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 03:58, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>>>>>>>>>>> hello ,
>>>>>>>>>>>>>>>>>>>>>>>>>>> as told by Joel , I started this thread to
>>>>>>>>>>>>>>>>>>>>>>>>>>> further discuss the coverage analysis toolset .
>>>>>>>>>>>>>>>>>>>>>>>>>>> Current status is , I'm trying to builld and run
>>>>>>>>>>>>>>>>>>>>>>>>>>> rtems-test from the coverage-merge branch of the previous GSoC student
>>>>>>>>>>>>>>>>>>>>>>>>>>> Cillian .
>>>>>>>>>>>>>>>>>>>>>>>>>>> nell/rtems-tools/tree/coverage-merge
>>>>>>>>>>>>>>>>>>>>>>>>>>> I'm getting an error that says .
>>>>>>>>>>>>>>>>>>>>>>>>>>> "Covoar not found !"
>>>>>>>>>>>>>>>>>>>>>>>>>> It's supposed to find it in
>>>>>>>>>>>>>>>>>>>>>>>>>> rtems-tools/build/tester/covoar/ If it's in
>>>>>>>>>>>>>>>>>>>>>>>>>> there it should be fine. Can you show me the contents of that directory?
>>>>>>>>>>>>>>>>>>>>>>>>>> cpod at cpod ~/development/rtems/test/rtems-tools/build/tester/covoar
>>>>>>>>>>>>>>>>>>>>>>>>>> $ ls
>>>>>>>>>>>>>>>>>>>>>>>>>>> the Covoar appeared in
>>>>>>>>>>>>>>>>>>>>>>>>>>> rtems-tools/tester/covoar .
>>>>>>>>>>>>>>>>>>>>>>>>>>> Vijay
>>>>>>>>>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>>>>>>>>>> devel mailing list
>>>>>>>>>>>>>>>>>>>>>>>>>>> devel at rtems.org
>>>>>>>>>>>>>>>>>>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180326/b05e4a97/attachment-0001.html>
