RSB build failure
Vidushi Vashishth
reachvidu at gmail.com
Sat Mar 17 13:11:32 UTC 2018
So it was a problem with the path variable.
Fixed it. The setup worked. Thanks!
On Sat, Mar 17, 2018 at 3:33 PM, Aditya Upadhyay <aadit0402 at gmail.com>
wrote:
> install python-dev... Will solve the issue. If you are using ubuntu..
> sudo apt-get install python-dev.
> On Sat, Mar 17, 2018, 3:30 PM Amaan Cheval <amaan.cheval at gmail.com> wrote:
>> Hi!
>> > checking for python...
>> /Library/Frameworks/Python.framework/Versions/2.7/bin/python
>> > checking for python2.7... no
>> > configure: error: python is missing or unusable
>> That looks like the problem (at least on the surface). macOS does come
>> with
>> Python built-in, but I don't believe that's good enough for development
>> (vague memories only of issues) - have you installed Python separately
>> too?
>> If so, could you confirm that you have the python2.7 binary in your PATH
>> variable too?
>> On Sat, Mar 17, 2018 at 3:24 PM Vidushi Vashishth <reachvidu at gmail.com>
>> wrote:
>> > Hello!
>> > I was trying to set up the sparc/erc32 bsp on a new system and was
>> following the quickstart on the user manual. Though I have successfully
>> done this before, this time its throwing an error. PFA the rsb log file
>> with the error report. I was doing this to run the trace buffering
>> examples.
>> > Why is the shell command /bin/sh -ex failing?
>> > Regards,
>> > Vidushi
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180317/5c4b08de/attachment.html>
