RSB build failure
Vidushi Vashishth
reachvidu at gmail.com
Sun Mar 18 03:31:29 UTC 2018
>I have been testing on a range of MacOS versions over the years and I have
not
seen any issues report. If you have seen issues or you know of reports
please
let me know.
I was able to setup the environment successfully yesterday. Though in the
process I had another error which I managed to deal with. PFA the attached
report. Its about the relocation of the libexpat to github. I manually
downloaded the tar file and put it in the required sources folder.
>I have XCode installed with the command line package.
I also have this. I had python packages installed using homebrew too which
weren't in the PATH variable. Adding them to the path solved the issue.
On Sun, Mar 18, 2018 at 8:41 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 17/3/18 9:00 pm, Amaan Cheval wrote:
> >> checking for python...
> > /Library/Frameworks/Python.framework/Versions/2.7/bin/python
> >> checking for python2.7... no
> >> configure: error: python is missing or unusable
> > That looks like the problem (at least on the surface). macOS does come
> with
> > Python built-in, but I don't believe that's good enough for development
> The default Python is fine for use with GDB and the RSB. There is no
> problem
> with the default provided by Apple on MacOS.
> $ uname -a
> Darwin huia 17.4.0 Darwin Kernel Version 17.4.0: Sun Dec 17 09:19:54 PST
> 2017;
> root:xnu-4570.41.2~1/RELEASE_X86_64 x86_64
> $ type python
> python is /usr/bin/python
> $ python --version
> Python 2.7.10
> $ python
> Python 2.7.10 (default, Jul 15 2017, 17:16:57)
> [GCC 4.2.1 Compatible Apple LLVM 9.0.0 (clang-900.0.31)] on darwin
> Type "help", "copyright", "credits" or "license" for more information.
> >>> ^D
> Finally this a recent build result on a Mac Mini I have set up to check
> RTEMS
> builds:
> https://lists.rtems.org/pipermail/build/2018-February/000521.html
> > (vague memories only of issues)
> not
> please
> let me know.
> > - have you installed Python separately too?
> If yo do this or you are using homebrew, mscports or something else then
> you may
> have issues and you will need to look for support with those packaging
> projects.
> I do not have any packages from homebrew or macports so we know the RSB is
> working.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180318/a52f32ec/attachment-0001.html>
RTEMS Tools Project - Source Builder Error Report
Build: error: downloading https://github.com/libexpat/libexpat/releases/download/R_2_1_0/expat-2.1.0.tar.gz: all paths have failed, giving up
Command Line: ../source-builder/sb-set-builder --prefix=/Users/vidushi/development/rtems/5 5/rtems-sparc
Python: 2.7.14 (v2.7.14:84471935ed, Sep 16 2017, 12:01:12) [GCC 4.2.1 (Apple Inc. build 5666) (dot 3)]
git://git.rtems.org/rtems-source-builder.git/origin/4b3e0f8e3d6998b84a2503dd2e11578989b1672b
Darwin Vidushis-MacBook-Air.local 16.7.0 Darwin Kernel Version 16.7.0: Thu Jan 11 22:59:40 PST 2018; root:xnu-3789.73.8~1/RELEASE_X86_64 x86_64
Tail of the build log:
x automake-1.12.6/t/libobj4.sh
x automake-1.12.6/t/check4-w.sh
x automake-1.12.6/t/libtoo10.sh
x automake-1.12.6/t/pr72.sh
x automake-1.12.6/t/dejagnu6.sh
x automake-1.12.6/t/override-html.sh
x automake-1.12.6/t/check-tests-in-builddir.sh
x automake-1.12.6/t/am-missing-prog.sh
x automake-1.12.6/t/aclocal7.sh
x automake-1.12.6/t/cygnus-no-installinfo.sh
x automake-1.12.6/t/pr266.sh
x automake-1.12.6/t/auxdir8.sh
x automake-1.12.6/t/self-check-is_newest.tap
x automake-1.12.6/t/cygnus-dependency-tracking.sh
x automake-1.12.6/t/parallel-tests-interrupt.tap
x automake-1.12.6/t/badline.sh
x automake-1.12.6/t/ar3.sh
x automake-1.12.6/t/location.sh
x automake-1.12.6/t/substtarg.sh
x automake-1.12.6/t/instsh3.sh
x automake-1.12.6/automake.in
x automake-1.12.6/doc/
x automake-1.12.6/doc/amhello/
x automake-1.12.6/doc/amhello/Makefile.am
x automake-1.12.6/doc/amhello/README
x automake-1.12.6/doc/amhello/src/
x automake-1.12.6/doc/amhello/src/Makefile.am
x automake-1.12.6/doc/amhello/src/main.c
x automake-1.12.6/doc/amhello/configure.ac
x automake-1.12.6/doc/automake.info-2
x automake-1.12.6/doc/amhello-1.0.tar.gz
x automake-1.12.6/doc/automake.info-3
x automake-1.12.6/doc/automake-history.info
x automake-1.12.6/doc/fdl.texi
x automake-1.12.6/doc/automake.info-1
x automake-1.12.6/doc/automake.texi
x automake-1.12.6/doc/automake-history.texi
x automake-1.12.6/doc/version.texi
x automake-1.12.6/doc/stamp-vti
x automake-1.12.6/doc/help2man
x automake-1.12.6/aclocal.m4
x automake-1.12.6/NEWS
+ cd automake-1.12.6
+ /bin/chmod -R a+rX,g-w,o-w .
+ /bin/cat /Users/vidushi/development/rtems/rsb/rtems/patches/automake-1.12.6-bugzilla.redhat.com-1239379.diff
+ /usr/bin/patch -p1
patching file automake.in
+ cd /Users/vidushi/development/rtems/rsb/rtems/build/automake-1.12.6-x86_64-apple-darwin16.7.0-1
+ SB_CXC=no
==> clean %{buildroot}: /Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi
+ echo '==> clean %{buildroot}: /Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi'
+ /bin/rm -rf /Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi
+ /bin/mkdir -p /Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi
==> %build:
+ echo '==> %build:'
++ pwd
+ build_top=/Users/vidushi/development/rtems/rsb/rtems/build/automake-1.12.6-x86_64-apple-darwin16.7.0-1
+ export PATH=/Users/vidushi/development/rtems/rsb/rtems/build/tmp/sb-vidushi/Users/vidushi/development/rtems/5/bin:/Users/vidushi/development/rtems/rsb/source-builder:/Users/vidushi/development/rtems/rsb/rtems/build/tmp/sb-vidushi-cxc/5/rtems-autotools-base.bset/Users/vidushi/development/rtems/5/bin:/Users/vidushi/development/rtems/rsb/rtems/build/tmp/sb-vidushi/5/rtems-autotools-base.bset/Users/vidushi/development/rtems/5/bin:/Library/Frameworks/Python.framework/Versions/2.7/bin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/X11/bin
+ PATH=/Users/vidushi/development/rtems/rsb/rtems/build/tmp/sb-vidushi/Users/vidushi/development/rtems/5/bin:/Users/vidushi/development/rtems/rsb/source-builder:/Users/vidushi/development/rtems/rsb/rtems/build/tmp/sb-vidushi-cxc/5/rtems-autotools-base.bset/Users/vidushi/development/rtems/5/bin:/Users/vidushi/development/rtems/rsb/rtems/build/tmp/sb-vidushi/5/rtems-autotools-base.bset/Users/vidushi/development/rtems/5/bin:/Library/Frameworks/Python.framework/Versions/2.7/bin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/X11/bin
+ test no = yes
+ am_prefix=/Users/vidushi/development/rtems/5
+ test x86_64-apple-darwin16.7.0 '!=' x86_64-apple-darwin16.7.0
+ export CFLAGS CFLAGS_FOR_BUILD CC
+ CFLAGS='-O2 -pipe -fbracket-depth=1024 -I/Users/vidushi/development/rtems/rsb/rtems/build/tmp/sb-vidushi/5/rtems-autotools-base.bset/Users/vidushi/development/rtems/5/include '
+ ./configure --build=x86_64-apple-darwin16.7.0 --host=x86_64-apple-darwin16.7.0 --verbose --prefix=/Users/vidushi/development/rtems/5
checking whether make supports nested variables... yes
checking build system type... x86_64-apple-darwin16.7.0
checking host system type... x86_64-apple-darwin16.7.0
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... lib/install-sh -c -d
checking for gawk... no
checking for mawk... no
checking for nawk... no
checking for awk... awk
checking whether make sets $(MAKE)... yes
checking whether ln -s works... yes
checking for perl... /usr/bin/perl
checking whether /usr/bin/perl supports ithreads... yes
checking for tex... no
checking for yacc... yacc
checking for lex... lex
checking whether autoconf is installed... yes
checking whether autoconf works... yes
checking whether autoconf is recent enough... yes
checking whether ln works... yes
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for fgrep... /usr/bin/grep -F
configure: will now look for a sturdy POSIX shell, for our testsuite
checking for sh... /bin/sh
checking for sh5... no
checking for dash... no
checking for ash... no
checking for bash... /bin/bash
checking for zsh... /bin/zsh
checking for ksh... /bin/ksh
checking for pdksh... no
checking whether /bin/sh supports $(cmd)... yes
checking whether /bin/sh supports $((expr))... yes
checking whether /bin/sh supports ${#var}... yes
checking whether /bin/sh supports ${var#glob} and ${var%glob}... yes
checking whether /bin/sh preserves exit traps with "set -e"... yes
checking whether /bin/sh can define exit traps in a shell function... yes
checking whether /bin/sh corrupts stderr with "set -x"... no
checking whether /bin/sh can return early from "dot-sourced" files... yes
checking whether /bin/sh supports alias named like shell builtins... yes
checking whether /bin/sh supports "test -e"... yes
configure: shell /bin/sh is good enough, stop looking
configure: will use /bin/sh as the testsuite shell
configure: will now look for generic compilers
checking for x86_64-apple-darwin16.7.0-cc... no
checking for x86_64-apple-darwin16.7.0-gcc... no
checking for cc... cc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether cc accepts -g... yes
checking for cc option to accept ISO C89... none needed
checking for x86_64-apple-darwin16.7.0-aCC... no
checking for x86_64-apple-darwin16.7.0-FCC... no
checking for x86_64-apple-darwin16.7.0-KCC... no
checking for x86_64-apple-darwin16.7.0-RCC... no
checking for x86_64-apple-darwin16.7.0-xlC_r... no
checking for x86_64-apple-darwin16.7.0-xlC... no
checking for x86_64-apple-darwin16.7.0-c++... no
checking for x86_64-apple-darwin16.7.0-cxx... no
checking for x86_64-apple-darwin16.7.0-cc++... no
checking for x86_64-apple-darwin16.7.0-gpp... no
checking for x86_64-apple-darwin16.7.0-g++... no
checking for aCC... no
checking for FCC... no
checking for KCC... KCC
checking whether the C++ compiler works... no
configure: WARNING: C++ compiler cannot create executables
configure: tests requiring the C++ compiler will be skipped
checking for x86_64-apple-darwin16.7.0-xlf95... no
checking for x86_64-apple-darwin16.7.0-f95... no
checking for x86_64-apple-darwin16.7.0-fort... no
checking for x86_64-apple-darwin16.7.0-ifort... no
checking for x86_64-apple-darwin16.7.0-ifc... no
checking for x86_64-apple-darwin16.7.0-efc... no
checking for x86_64-apple-darwin16.7.0-pgfortran... no
checking for x86_64-apple-darwin16.7.0-pgf95... no
checking for x86_64-apple-darwin16.7.0-lf95... no
checking for x86_64-apple-darwin16.7.0-ftn... no
checking for x86_64-apple-darwin16.7.0-nagfor... no
checking for x86_64-apple-darwin16.7.0-xlf90... no
checking for x86_64-apple-darwin16.7.0-f90... no
checking for x86_64-apple-darwin16.7.0-pgf90... no
checking for x86_64-apple-darwin16.7.0-pghpf... no
checking for x86_64-apple-darwin16.7.0-epcf90... no
checking for x86_64-apple-darwin16.7.0-g95... no
checking for x86_64-apple-darwin16.7.0-gfortran... no
checking for xlf95... no
checking for f95... no
checking for fort... no
checking for ifort... no
checking for ifc... no
checking for efc... no
checking for pgfortran... no
checking for pgf95... no
checking for lf95... no
checking for ftn... no
checking for nagfor... no
checking for xlf90... no
checking for f90... no
checking for pgf90... no
checking for pghpf... no
checking for epcf90... no
checking for g95... no
checking for gfortran... no
checking whether the Fortran compiler works... no
configure: WARNING: Fortran compiler cannot create executables
configure: tests requiring the Fortran compiler will be skipped
checking for x86_64-apple-darwin16.7.0-xlf... no
checking for x86_64-apple-darwin16.7.0-f77... no
checking for x86_64-apple-darwin16.7.0-frt... no
checking for x86_64-apple-darwin16.7.0-pgf77... no
checking for x86_64-apple-darwin16.7.0-cf77... no
checking for x86_64-apple-darwin16.7.0-fort77... no
checking for x86_64-apple-darwin16.7.0-fl32... no
checking for x86_64-apple-darwin16.7.0-af77... no
checking for x86_64-apple-darwin16.7.0-g77... no
checking for xlf... no
checking for f77... no
checking for frt... no
checking for pgf77... no
checking for cf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for g77... no
checking whether the Fortran 77 compiler works... no
configure: WARNING: Fortran 77 compiler cannot create executables
configure: tests requiring the Fortran 77 compiler will be skipped
configure: will now look for GNU compilers
configure: cc is already a GNU C compiler
checking for g++... g++
checking for x86_64-apple-darwin16.7.0-gcj... no
checking for gcj... no
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
config.status: creating t/wrap/aclocal-1.12
config.status: creating t/wrap/automake-1.12
+ make -j 4 all
GEN automake
GEN aclocal
GEN t/ax/shell-no-trail-bslash
GEN runtest
GEN doc/aclocal.1
GEN doc/automake.1
GEN lib/Automake/Config.pm
GEN t/ax/test-defs.sh
GEN doc/aclocal-1.12.1
GEN doc/automake-1.12.1
+ unset CFLAGS_FOR_BUILD
==> %install:
+ echo '==> %install:'
++ pwd
+ export PATH=/Users/vidushi/development/rtems/5/bin:/Users/vidushi/development/rtems/rsb/rtems/build/tmp/sb-vidushi/Users/vidushi/development/rtems/5/bin:/Users/vidushi/development/rtems/rsb/source-builder:/Users/vidushi/development/rtems/rsb/rtems/build/tmp/sb-vidushi-cxc/5/rtems-autotools-base.bset/Users/vidushi/development/rtems/5/bin:/Users/vidushi/development/rtems/rsb/rtems/build/tmp/sb-vidushi/5/rtems-autotools-base.bset/Users/vidushi/development/rtems/5/bin:/Library/Frameworks/Python.framework/Versions/2.7/bin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/X11/bin
+ PATH=/Users/vidushi/development/rtems/5/bin:/Users/vidushi/development/rtems/rsb/rtems/build/tmp/sb-vidushi/Users/vidushi/development/rtems/5/bin:/Users/vidushi/development/rtems/rsb/source-builder:/Users/vidushi/development/rtems/rsb/rtems/build/tmp/sb-vidushi-cxc/5/rtems-autotools-base.bset/Users/vidushi/development/rtems/5/bin:/Users/vidushi/development/rtems/rsb/rtems/build/tmp/sb-vidushi/5/rtems-autotools-base.bset/Users/vidushi/development/rtems/5/bin:/Library/Frameworks/Python.framework/Versions/2.7/bin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/X11/bin
+ test no = yes
+ make DESTDIR=/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi install
lib/install-sh -c -d '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/bin'
/usr/bin/install -c automake aclocal '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/bin'
/Applications/Xcode.app/Contents/Developer/usr/bin/make install-exec-hook
ln '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/bin/automake' '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/bin/automake-1.12'
ln '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/bin/aclocal' '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/bin/aclocal-1.12'
lib/install-sh -c -d '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/automake-1.12/am'
/usr/bin/install -c -m 644 lib/am/check.am lib/am/check2.am lib/am/clean-hdr.am lib/am/clean.am lib/am/compile.am lib/am/configure.am lib/am/data.am lib/am/dejagnu.am lib/am/depend.am lib/am/depend2.am lib/am/distdir.am lib/am/footer.am lib/am/header-vars.am lib/am/header.am lib/am/install.am lib/am/inst-vars.am lib/am/java.am lib/am/lang-compile.am lib/am/lex.am lib/am/library.am lib/am/libs.am lib/am/libtool.am lib/am/lisp.am lib/am/ltlib.am lib/am/ltlibrary.am lib/am/mans-vars.am lib/am/mans.am lib/am/program.am lib/am/progs.am lib/am/python.am lib/am/remake-hdr.am lib/am/scripts.am lib/am/subdirs.am lib/am/tags.am lib/am/texi-vers.am lib/am/texibuild.am lib/am/texinfos.am lib/am/vala.am lib/am/yacc.am '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/automake-1.12/am'
lib/install-sh -c -d '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/aclocal-1.12'
/usr/bin/install -c -m 644 m4/amversion.m4 m4/ar-lib.m4 m4/as.m4 m4/auxdir.m4 m4/ccstdc.m4 m4/cond.m4 m4/cond-if.m4 m4/depend.m4 m4/depout.m4 m4/dmalloc.m4 m4/gcj.m4 m4/header.m4 m4/init.m4 m4/install-sh.m4 m4/lead-dot.m4 m4/lex.m4 m4/lispdir.m4 m4/maintainer.m4 m4/make.m4 m4/minuso.m4 m4/missing.m4 m4/mkdirp.m4 m4/obsol-gt.m4 m4/obsol-lt.m4 m4/obsolete.m4 m4/options.m4 m4/protos.m4 m4/python.m4 m4/runlog.m4 m4/sanity.m4 m4/silent.m4 m4/strip.m4 m4/substnot.m4 m4/tar.m4 m4/upc.m4 m4/vala.m4 '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/aclocal-1.12'
lib/install-sh -c -d '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/doc/automake'
/usr/bin/install -c -m 644 ./doc/amhello-1.0.tar.gz '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/doc/automake'
lib/install-sh -c -d '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/automake-1.12/Automake'
/usr/bin/install -c -m 644 lib/Automake/ChannelDefs.pm lib/Automake/Channels.pm lib/Automake/Condition.pm lib/Automake/Configure_ac.pm lib/Automake/DisjConditions.pm lib/Automake/FileUtils.pm lib/Automake/General.pm lib/Automake/Getopt.pm lib/Automake/Item.pm lib/Automake/ItemDef.pm lib/Automake/Location.pm lib/Automake/Options.pm lib/Automake/Rule.pm lib/Automake/RuleDef.pm lib/Automake/Variable.pm lib/Automake/VarDef.pm lib/Automake/Version.pm lib/Automake/XFile.pm lib/Automake/Wrap.pm '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/automake-1.12/Automake'
lib/install-sh -c -d '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/automake-1.12'
/usr/bin/install -c -m 644 lib/COPYING lib/INSTALL lib/texinfo.tex '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/automake-1.12'
/usr/bin/install -c -m 644 lib/config.guess lib/config.sub lib/install-sh lib/mdate-sh lib/missing lib/mkinstalldirs lib/elisp-comp lib/ylwrap lib/depcomp lib/compile lib/py-compile lib/ar-lib lib/test-driver lib/tap-driver.sh lib/tap-driver.pl '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/automake-1.12'
lib/install-sh -c -d '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/aclocal'
/usr/bin/install -c -m 644 m4/acdir/README '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/aclocal'
lib/install-sh -c -d '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/info'
/usr/bin/install -c -m 644 ./doc/automake.info ./doc/automake.info-1 ./doc/automake.info-2 ./doc/automake.info-3 ./doc/automake-history.info '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/info'
install-info --info-dir='/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/info' '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/info/automake.info'
install-info --info-dir='/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/info' '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/info/automake-history.info'
install-info: warning: no info dir entry in `/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/info/automake-history.info'
lib/install-sh -c -d '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/man/man1'
/usr/bin/install -c -m 644 doc/aclocal.1 doc/automake.1 doc/aclocal-1.12.1 doc/automake-1.12.1 '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/man/man1'
/usr/bin/install -c -m 644 lib/Automake/Config.pm '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/automake-1.12/Automake'
/Applications/Xcode.app/Contents/Developer/usr/bin/make install-data-hook
chmod +x '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/automake-1.12/config.guess'
chmod +x '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/automake-1.12/config.sub'
chmod +x '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/automake-1.12/install-sh'
chmod +x '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/automake-1.12/mdate-sh'
chmod +x '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/automake-1.12/missing'
chmod +x '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/automake-1.12/mkinstalldirs'
chmod +x '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/automake-1.12/elisp-comp'
chmod +x '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/automake-1.12/ylwrap'
chmod +x '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/automake-1.12/depcomp'
chmod +x '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/automake-1.12/compile'
chmod +x '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/automake-1.12/py-compile'
chmod +x '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/automake-1.12/ar-lib'
chmod +x '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/automake-1.12/test-driver'
chmod +x '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/automake-1.12/tap-driver.sh'
chmod +x '/Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/automake-1.12/tap-driver.pl'
==> %clean:
+ echo '==> %clean:'
copy: /Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi => /Users/vidushi/development/rtems/rsb/rtems/build/tmp/sb-vidushi/5/rtems-autotools-base.bset
reporting: tools/rtems-automake-1.12.6-1.cfg -> automake-1.12.6-x86_64-apple-darwin16.7.0-1.txt
making dir: /Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5/share/rtems/rsb
reporting: tools/rtems-automake-1.12.6-1.cfg -> automake-1.12.6-x86_64-apple-darwin16.7.0-1.xml
installing: autoconf-2.69-x86_64-apple-darwin16.7.0-1 -> /Users/vidushi/development/rtems/5
copy: /Users/vidushi/development/rtems/rsb/rtems/build/tmp/autoconf-2.69-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5 => /Users/vidushi/development/rtems/5
installing: automake-1.12.6-x86_64-apple-darwin16.7.0-1 -> /Users/vidushi/development/rtems/5
copy: /Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi/Users/vidushi/development/rtems/5 => /Users/vidushi/development/rtems/5
cleaning: autoconf-2.69-x86_64-apple-darwin16.7.0-1
removing: /Users/vidushi/development/rtems/rsb/rtems/build/tmp/autoconf-2.69-x86_64-apple-darwin16.7.0-1-root-vidushi
removing: /Users/vidushi/development/rtems/rsb/rtems/build/autoconf-2.69-x86_64-apple-darwin16.7.0-1
removing: /Users/vidushi/development/rtems/rsb/rtems/build/tmp/sb-vidushi/5/rtems-autotools-base.bset
cleaning: automake-1.12.6-x86_64-apple-darwin16.7.0-1
removing: /Users/vidushi/development/rtems/rsb/rtems/build/tmp/automake-1.12.6-x86_64-apple-darwin16.7.0-1-root-vidushi
removing: /Users/vidushi/development/rtems/rsb/rtems/build/automake-1.12.6-x86_64-apple-darwin16.7.0-1
Build Set: Time 0:00:16.829158
Build Set: Time 0:00:58.487587
config: devel/expat-2.1.0-1.cfg
package: expat-2.1.0-x86_64-apple-darwin16.7.0-1
script: 1: #!/bin/sh
script: 2: # ___build_pre in as set up in defaults.py
script: 3: # Save the original path away.
script: 4: export SB_ORIG_PATH=${PATH}
script: 5: # Directories
script: 6: SB_PREFIX="/Users/vidushi/development/rtems/5"
script: 7: SB_PREFIX_CLEAN=$(echo "/Users/vidushi/development/rtems/5" | /usr/bin/sed -e 's/^\///')
script: 8: SB_SOURCE_DIR="/Users/vidushi/development/rtems/rsb/rtems/sources"
script: 9: SB_BUILD_DIR="/Users/vidushi/development/rtems/rsb/rtems/build/expat-2.1.0-x86_64-apple-darwin16.7.0-1"
script: 10: # host == build, use build; host != build, host uses host and build uses build
script: 11: SB_HOST_CPPFLAGS=""
script: 12: SB_HOST_CFLAGS="-O2 -pipe "
script: 13: SB_HOST_CXXFLAGS="-O2 -pipe "
script: 14: SB_HOST_LDFLAGS=" -L/Users/vidushi/development/rtems/rsb/rtems/build/tmp/sb-vidushi/5/rtems-sparc/${SB_PREFIX_CLEAN}/lib"
script: 15: SB_BUILD_CFLAGS="-O2 -pipe -fbracket-depth=1024 -I/Users/vidushi/development/rtems/rsb/rtems/build/tmp/sb-vidushi/5/rtems-sparc/${SB_PREFIX_CLEAN}/include"
script: 16: SB_BUILD_CXXFLAGS="-O2 -pipe -fbracket-depth=1024 -I/Users/vidushi/development/rtems/rsb/rtems/build/tmp/sb-vidushi/5/rtems-sparc/${SB_PREFIX_CLEAN}/include"
script: 17: SB_BUILD_LDFLAGS=" -L/Users/vidushi/development/rtems/rsb/rtems/build/tmp/sb-vidushi/5/rtems-sparc/${SB_PREFIX_CLEAN}/lib"
script: 18: SB_CFLAGS="${SB_BUILD_CFLAGS} "
script: 19: SB_CXXFLAGS="${SB_BUILD_CXXFLAGS} "
script: 20: SB_ARCH="x86_64"
script: 21: SB_OS="darwin"
script: 22: export SB_SOURCE_DIR SB_BUILD_DIR SB_ARCH SB_OS
script: 23: export SB_HOST_CPPFLAGS SB_HOST_CFLAGS SB_HOST_CXXFLAGS SB_HOST_LDFLAGS
script: 24: export SB_BUILD_CFLAGS SB_BUILD_CXXFLAGS SB_BUILD_LDFLAGS
script: 25: export SB_CFLAGS SB_CXXFLAGS
script: 26: # Documentation
script: 27: SB_DOC_DIR="/Users/vidushi/development/rtems/5/share/doc"
script: 28: export SB_DOC_DIR
script: 29: # Packages
script: 30: SB_PACKAGE_NAME="expat-2.1.0-x86_64-apple-darwin16.7.0-1"
script: 31: SB_PACKAGE_BUILDNAME="expat-2.1.0-x86_64-apple-darwin16.7.0-1"
script: 32: SB_PACKAGE_VERSION="2.1.0"
script: 33: SB_PACKAGE_RELEASE="1"
script: 34: export SB_PACKAGE_NAME SB_PACKAGE_VERSION SB_PACKAGE_RELEASE
script: 35: # Build directories
script: 36: export SB_PREFIX
script: 37: SB_BUILD_DIR="/Users/vidushi/development/rtems/rsb/rtems/build/expat-2.1.0-x86_64-apple-darwin16.7.0-1"
script: 38: SB_BUILD_ROOT="/Users/vidushi/development/rtems/rsb/rtems/build/tmp/expat-2.1.0-x86_64-apple-darwin16.7.0-1-root-vidushi"
script: 39: SB_BUILD_ROOT_BINDIR="/Users/vidushi/development/rtems/rsb/rtems/build/tmp/expat-2.1.0-x86_64-apple-darwin16.7.0-1-root-vidushi/${SB_PREFIX_CLEAN}/bin"
script: 40: export SB_BUILD_ROOT SB_BUILD_DIR SB_BUILD_ROOT_BINDIR
script: 41: SB_BUILD_CXC_DIR="/Users/vidushi/development/rtems/rsb/rtems/build/expat-2.1.0-x86_64-apple-darwin16.7.0-1-cxc"
script: 42: SB_BUILD_CXC_ROOT="/Users/vidushi/development/rtems/rsb/rtems/build/tmp/expat-2.1.0-x86_64-apple-darwin16.7.0-1-vidushi-cxc"
script: 43: SB_BUILD_CXC_ROOT_BINDIR="/Users/vidushi/development/rtems/rsb/rtems/build/tmp/expat-2.1.0-x86_64-apple-darwin16.7.0-1-vidushi-cxc/${SB_PREFIX_CLEAN}/bin"
script: 44: export SB_BUILD_CXC_ROOT SB_BUILD_CXC_DIR SB_BUILD_CXC_ROOT_BINDIR
script: 45: SB_TMPROOT="/Users/vidushi/development/rtems/rsb/rtems/build/tmp/sb-vidushi/5/rtems-sparc"
script: 46: SB_TMPPREFIX="/Users/vidushi/development/rtems/rsb/rtems/build/tmp/sb-vidushi/5/rtems-sparc/${SB_PREFIX_CLEAN}"
script: 47: SB_TMPBINDIR="/Users/vidushi/development/rtems/rsb/rtems/build/tmp/sb-vidushi/5/rtems-sparc/${SB_PREFIX_CLEAN}/bin"
script: 48: export SB_TMPROOT SB_TMPPREFIX SB_TMPBINDIR
script: 49: SB_TMPCXCROOT="/Users/vidushi/development/rtems/rsb/rtems/build/tmp/sb-vidushi/5/rtems-sparc"
script: 50: SB_TMPCXCPREFIX="/Users/vidushi/development/rtems/rsb/rtems/build/tmp/sb-vidushi-cxc/5/rtems-sparc/${SB_PREFIX_CLEAN}"
script: 51: SB_TMPCXCBINDIR="/Users/vidushi/development/rtems/rsb/rtems/build/tmp/sb-vidushi-cxc/5/rtems-sparc/${SB_PREFIX_CLEAN}/bin"
script: 52: export SB_TMPCXCROOT SB_TMPCXCPREFIX SB_TMPCXCBINDIR
script: 53: # Extra path support
script: 54: SB_EXTRAPATH="/Users/vidushi/development/rtems/rsb/source-builder"
script: 55: # The compiler flags
script: 56:
script: 57:
script: 58: export CFLAGS_FOR_TARGET
script: 59: export CXXFLAGS_FOR_TARGET
script: 60: # Set up the path. Put the CXC path first.
script: 61: if test -n "${SB_TMPBINDIR}" ; then
script: 62: PATH="${SB_TMPBINDIR}:$PATH"
script: 63: fi
script: 64: if test -n "${SB_TMPCXCBINDIR}" ; then
script: 65: PATH="${SB_TMPCXCBINDIR}:$PATH"
script: 66: fi
script: 67: if test -n "${SB_EXTRAPATH}" ; then
script: 68: PATH="${SB_EXTRAPATH}:$PATH"
script: 69: fi
script: 70:
script: 71:
script: 72: export PATH
script: 73: # Default environment set up.
script: 74: LANG=C
script: 75: export LANG
script: 76: unset DISPLAY || :
script: 77: umask 022
script: 78: cd "/Users/vidushi/development/rtems/rsb/rtems/build/expat-2.1.0-x86_64-apple-darwin16.7.0-1"
script: 79: echo "=> expat-2.1.0-x86_64-apple-darwin16.7.0-1:"
script: 80: echo "==> %prep:"
script: 81: build_top=$(pwd)
source setup: expat-2.1.0-x86_64-apple-darwin16.7.0-1: source expat -q -n expat-2.1.0
making dir: /Users/vidushi/development/rtems/rsb/rtems/sources
download: (full) https://github.com/libexpat/libexpat/releases/download/R_2_1_0/expat-2.1.0.tar.gz -> sources/expat-2.1.0.tar.gz
download: https://github.com/libexpat/libexpat/releases/download/R_2_1_0/expat-2.1.0.tar.gz -> sources/expat-2.1.0.tar.gz
download: no ssl context
download: https://github.com/libexpat/libexpat/releases/download/R_2_1_0/expat-2.1.0.tar.gz: error: <urlopen error [SSL: TLSV1_ALERT_PROTOCOL_VERSION] tlsv1 alert protocol version (_ssl.c:661)>
