RSB build failure
Vidushi Vashishth
reachvidu at gmail.com
Sun Mar 18 05:08:10 UTC 2018
>Interesting. Please raise a ticket, set the component to rsb and assign to
me. I
will take a look next week. I cannot remember if I deleted the source
tarball on
MacOS and tested this.
Done. The ticket is #3355
Best,
Vidushi
On Sun, Mar 18, 2018 at 9:07 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 18/3/18 2:31 pm, Vidushi Vashishth wrote:
> >>I have been testing on a range of MacOS versions over the years and I
> have not
> > seen any issues report. If you have seen issues or you know of reports
> please
> > let me know.
> > I was able to setup the environment successfully yesterday. Though in the
> > process I had another error which I managed to deal with. PFA the
> attached
> > report. Its about the relocation of the libexpat to github. I manually
> > downloaded the tar file and put it in the required sources folder.
> me. I
> tarball on
> >>I have XCode installed with the command line package.
> > I also have this. I had python packages installed using homebrew too
> which
> > weren't in the PATH variable. Adding them to the path solved the issue.
> Thanks for reporting this. That clears up what was happening.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180318/dfe32840/attachment.html>
