Error in Trace-buffering example
Tue Mar 20 02:39:36 UTC 2018
On 19/03/2018 18:41, Vidushi Vashishth wrote:
>>> The -B option should have a full path not a partial one. The $prefix used when
>>> building the BSP is missing.
>> >Did you use a full path? Is there an argument missing to the invocation?
> Adding full path to the -B option works. Turns out $prefix is not required in
> the command.
Excellent.
>>The link provided to our wiki does not have the full path. I am not sure why ...
> The wiki description also does not show the full path for fileio.exe and init.o.
> I made changes to the command to overcome the errors. Should I raise a ticket to
> make the changes?
Please update the wiki and explain the role the path and $prefix has.
> However now on trying to run the trace link command (which follows) I am
> encountering an error:
> Command:
> rtems-tld -C fileio-trace.ini -W fileio-wrapper --
> -B/Users/vidushi/development/rtems/5/sparc-rtems5/erc32/lib/ -specs bsp_specs
> -qrtems -mcpu=cypress -O2 -g -ffunction-sections -fdata-sections -Wall
> -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes
> -Wnested-externs -Wl,--gc-sections -mcpu=cypress -o
> sparc-rtems5/c/erc32/testsuites/samples/fileio/fileio.exe
> sparc-rtems5/c/erc32/testsuites/samples/fileio/init.o
> Error:
> error: /Users/vidushi/development/rtems/kernel/erc32: Invalid RTEMS path>
> According to the wiki documentation the rtems-path in the configuration file
> should be set to the installed BSP.
Yes.
> Following is the [fileio-options] section of my configuration file:
> [fileio-options]
> dump-on-error = true
> ; Tools
> prefix = /Users/vidushi/development/rtems/5
> rtems-path = /Users/vidushi/development/rtems/kernel/erc32
> rtems-bsp = sparc/erc32
> ; Generator options.
> gen-enables = enable
> gen-triggers = enable
> My rtems-path does point to the installed BSP directory. I can't think of a
> reason for this error.
Interesting, I wonder if the changes that have been made with files has broken
the test? The check is here ...
https://git.rtems.org/rtems-tools/tree/rtemstoolkit/rld-rtems.cpp#n52
It takes the path you give it, ie 'path ()', and adds 'lib' and 'pkgconfig' and
does the check:
 /Users/vidushi/development/rtems/kernel/erc32/lib/pkgconfig
Is this path present?
> On an unrelated note I am working on my proposal and would try to submit it by
> end of today. For the past couple of days I have been trying to make the
> trace-buffering example work and am hoping to solve the #2780 ticket. I have
> also been going through the work of previous GSOC interns in the same project
> trying to ascertain if I can carry forward from where they left off. Hence I
> wanted to ask if trying to implement the live-tracing functionality over several
> transport mechanisms would be a viable goal for the proposal? Assuming it wasn't
> finished.
Over TCP at this point in time would be best. I suggest you have a look at the
libdebugger's implementation on how to implement a remote interface that can be
changed with other transports:
https://git.rtems.org/rtems/tree/cpukit/include/rtems/debugger/rtems-debugger-remote.h
https://git.rtems.org/rtems/tree/cpukit/libdebugger/rtems-debugger-remote-tcp.h
https://git.rtems.org/rtems/tree/cpukit/libdebugger/rtems-debugger-remote-tcp.c
> Also, given the paucity of time would you suggest that I finish the proposal
> first or my patch for the aforementioned ticket.
Please get your submission sorted out and then the ticket after that.
