[PATCH 03/11] sptests/spsem05: another test of prio stepdown on sem release
Fri Mar 23 16:15:39 UTC 2018
 testsuites/sptests/Makefile.am         |   2 +-
 testsuites/sptests/configure.ac        |   1 +
 testsuites/sptests/spsem05/Makefile.am |  19 ++++
 testsuites/sptests/spsem05/init.c      | 165 +++++++++++++++++++++++++++++++++
 testsuites/sptests/spsem05/spsem05.doc |  13 +++
 testsuites/sptests/spsem05/spsem05.scn |   2 +
 6 files changed, 201 insertions(+), 1 deletion(-)
 create mode 100644 testsuites/sptests/spsem05/Makefile.am
 create mode 100644 testsuites/sptests/spsem05/init.c
 create mode 100644 testsuites/sptests/spsem05/spsem05.doc
 create mode 100644 testsuites/sptests/spsem05/spsem05.scn
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index a3011ae..50473f2 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -24,7 +24,7 @@ _SUBDIRS = \
     spintrcritical13 spintrcritical14 spintrcritical15 spintrcritical16 \
     spintrcritical17
-_SUBDIRS += spsem01 spsem02 spsem03 spsem04
+_SUBDIRS += spsem01 spsem02 spsem03 spsem04 spsem05
 DIST_SUBDIRS = $(_SUBDIRS) spfatal_support spintrcritical_support
 EXTRA_DIST = spfatal_support/init.c spfatal_support/system.h
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index e410fa8..ccc143e 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -135,6 +135,7 @@ spsem01/Makefile
 spsem02/Makefile
 spsem03/Makefile
 spsem04/Makefile
+spsem05/Makefile
 spsize/Makefile
 spstkalloc/Makefile
 spthreadq01/Makefile
diff --git a/testsuites/sptests/spsem05/Makefile.am b/testsuites/sptests/spsem05/Makefile.am
new file mode 100644
index 0000000..3a8e70c
--- /dev/null
+++ b/testsuites/sptests/spsem05/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = spsem05
+spsem05_SOURCES = init.c
+dist_rtems_tests_DATA = spsem05.scn spsem05.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(spsem05_OBJECTS)
+LINK_LIBS = $(spsem05_LDLIBS)
+spsem05$(EXEEXT): $(spsem05_OBJECTS) $(spsem05_DEPENDENCIES)
+	@rm -f spsem05$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/spsem05/init.c b/testsuites/sptests/spsem05/init.c
index 0000000..33ce6e5
--- /dev/null
+++ b/testsuites/sptests/spsem05/init.c
@@ -0,0 +1,165 @@
+ * Copyright (c) 2017 Gedare Bloom.
+ * Copyright (c) 2014, 2016 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#ifdef HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include "tmacros.h"
+const char rtems_test_name[] = "SPSEM 5";
+typedef struct {
+  rtems_id low;
+  rtems_id midb;
+  rtems_id mida;
+  rtems_id high;
+  rtems_id sem_a;
+  rtems_id sem_b;
+} test_context;
+static test_context test_instance;
+static void assert_prio(rtems_id task_id, rtems_task_priority expected_prio)
+  rtems_status_code sc;
+  rtems_task_priority prio;
+  sc = rtems_task_set_priority(task_id, RTEMS_CURRENT_PRIORITY, &prio);
+  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+  rtems_test_assert(prio == expected_prio);
+static void create_task(rtems_id *id, rtems_task_priority prio)
+  sc = rtems_task_create(
+    rtems_build_name('T', 'A', 'S', 'K'),
+    prio,
+    RTEMS_MINIMUM_STACK_SIZE,
+    RTEMS_DEFAULT_MODES,
+    RTEMS_DEFAULT_ATTRIBUTES,
+    id
+static void start_task(rtems_id id, rtems_task_entry entry)
+  sc = rtems_task_start(id, entry, 0);
+static void create_sema(rtems_id *id)
+  sc = rtems_semaphore_create(
+    rtems_build_name('S', 'E', 'M', 'A'),
+    1,
+    RTEMS_BINARY_SEMAPHORE | RTEMS_INHERIT_PRIORITY | RTEMS_PRIORITY,
+    0,
+    id
+static void obtain_sema(rtems_id id)
+  sc = rtems_semaphore_obtain(id, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+static void release_sema(rtems_id id)
+  sc = rtems_semaphore_release(id);
+static void midb_task(rtems_task_argument arg)
+  test_context *ctx = &test_instance;
+  obtain_sema(ctx->sem_a);
+  rtems_test_assert(0);
+static void mida_task(rtems_task_argument arg)
+  obtain_sema(ctx->sem_b);
+static void high_task(rtems_task_argument arg)
+  printf("*** END OF TEST SPSEM 5 ***\n");
+  rtems_test_exit(0);
+static void Init(rtems_task_argument arg)
+  printf("*** BEGIN OF TEST SPSEM 5 ***\n");
+  ctx->low = rtems_task_self();
+  create_task(&ctx->midb, 3);
+  create_task(&ctx->mida, 2);
+  create_task(&ctx->high, 1);
+  create_sema(&ctx->sem_a);
+  create_sema(&ctx->sem_b);
+  start_task(ctx->midb, midb_task);
+  start_task(ctx->mida, mida_task);
+  start_task(ctx->high, high_task);
+  release_sema(ctx->sem_b);
+  release_sema(ctx->sem_a);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 4
+#define CONFIGURE_MAXIMUM_SEMAPHORES 2
+#define CONFIGURE_INIT_TASK_PRIORITY 4
+#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/sptests/spsem05/spsem05.doc b/testsuites/sptests/spsem05/spsem05.doc
index 0000000..dfc0b13
--- /dev/null
+++ b/testsuites/sptests/spsem05/spsem05.doc
@@ -0,0 +1,13 @@
+This file describes the directives and concepts tested by this test set.
+test set name: spsem05
+directives:
+  - rtems_semaphore_obtain()
+  - rtems_semaphore_release()
+concepts:
+  - Demonstrate that the priority inheritance protocol works with or without
+    stepping down of priority on semaphore release.
diff --git a/testsuites/sptests/spsem05/spsem05.scn b/testsuites/sptests/spsem05/spsem05.scn
index 0000000..4026efb
--- /dev/null
+++ b/testsuites/sptests/spsem05/spsem05.scn
@@ -0,0 +1,2 @@
+*** BEGIN OF TEST SPSEM 5 ***
+*** END OF TEST SPSEM 5 ***
2.7.4
