[PATCH 04/11] score: Test thread priority queue disciplines
Fri Mar 23 16:15:40 UTC 2018
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
Add test sptests/spmutex01, since no existing uni-processor test covered
the thread priority queueing discipline for CORE mutexes.
 testsuites/sptests/spmutex01/Makefile.am   |  19 ++
 testsuites/sptests/spmutex01/init.c        | 269 +++++++++++++++++++++++++++++
 testsuites/sptests/spmutex01/spmutex01.doc |  14 ++
 testsuites/sptests/spmutex01/spmutex01.scn |   2 +
 4 files changed, 304 insertions(+)
 create mode 100644 testsuites/sptests/spmutex01/Makefile.am
 create mode 100644 testsuites/sptests/spmutex01/init.c
 create mode 100644 testsuites/sptests/spmutex01/spmutex01.doc
 create mode 100644 testsuites/sptests/spmutex01/spmutex01.scn
diff --git a/testsuites/sptests/spmutex01/Makefile.am b/testsuites/sptests/spmutex01/Makefile.am
new file mode 100644
index 0000000..d3101a6
--- /dev/null
+++ b/testsuites/sptests/spmutex01/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = spmutex01
+spmutex01_SOURCES = init.c
+dist_rtems_tests_DATA = spmutex01.scn spmutex01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(spmutex01_OBJECTS)
+LINK_LIBS = $(spmutex01_LDLIBS)
+spmutex01$(EXEEXT): $(spmutex01_OBJECTS) $(spmutex01_DEPENDENCIES)
+	@rm -f spmutex01$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/spmutex01/init.c b/testsuites/sptests/spmutex01/init.c
index 0000000..76d62c0
--- /dev/null
+++ b/testsuites/sptests/spmutex01/init.c
@@ -0,0 +1,269 @@
+ * Copyright (c) 2015, 2016 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#ifdef HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include "tmacros.h"
+const char rtems_test_name[] = "SPMUTEX 1";
+#define TASK_COUNT 5
+typedef enum {
+  REQ_WAKE_UP_MASTER = RTEMS_EVENT_0,
+  REQ_WAKE_UP_HELPER = RTEMS_EVENT_1,
+  REQ_MTX_OBTAIN = RTEMS_EVENT_2,
+  REQ_MTX_RELEASE = RTEMS_EVENT_3
+} request_id;
+typedef enum {
+  A_1,
+  A_2_0,
+  A_2_1,
+  M,
+  H,
+  NONE
+} task_id;
+typedef struct {
+  rtems_id mtx;
+  rtems_id tasks[TASK_COUNT];
+  int generation[TASK_COUNT];
+  int expected_generation[TASK_COUNT];
+} test_context;
+static test_context test_instance;
+static void start_task(
+  test_context *ctx,
+  task_id id,
+  rtems_task_entry entry,
+  rtems_task_priority prio
+  rtems_status_code sc;
+  sc = rtems_task_create(
+    rtems_build_name('T', 'A', 'S', 'K'),
+    prio,
+    RTEMS_MINIMUM_STACK_SIZE,
+    RTEMS_DEFAULT_MODES,
+    RTEMS_DEFAULT_ATTRIBUTES,
+    &ctx->tasks[id]
+  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+  sc = rtems_task_start(ctx->tasks[id], entry, id);
+static void send_event(test_context *ctx, task_id id, rtems_event_set events)
+  sc = rtems_event_send(ctx->tasks[id], events);
+static rtems_event_set wait_for_events(void)
+  rtems_event_set events;
+  sc = rtems_event_receive(
+    RTEMS_ALL_EVENTS,
+    RTEMS_EVENT_ANY | RTEMS_WAIT,
+    RTEMS_NO_TIMEOUT,
+    &events
+  return events;
+static void sync_with_helper(test_context *ctx)
+  send_event(ctx, H, REQ_WAKE_UP_HELPER);
+  events = wait_for_events();
+  rtems_test_assert(events == REQ_WAKE_UP_MASTER);
+static void request(test_context *ctx, task_id id, request_id req)
+  send_event(ctx, id, req);
+  sync_with_helper(ctx);
+static void obtain(test_context *ctx)
+  sc = rtems_semaphore_obtain(ctx->mtx, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
+static void release(test_context *ctx)
+  sc = rtems_semaphore_release(ctx->mtx);
+static void check_generations(test_context *ctx, task_id a, task_id b)
+  size_t i;
+  if (a != NONE) {
+    ++ctx->expected_generation[a];
+  if (b != NONE) {
+    ++ctx->expected_generation[b];
+  for (i = 0; i < TASK_COUNT; ++i) {
+    rtems_test_assert(ctx->generation[i] == ctx->expected_generation[i]);
+static void assert_prio(
+  task_id id,
+  rtems_task_priority expected
+  rtems_task_priority actual;
+  sc = rtems_task_set_priority(
+    ctx->tasks[id],
+    RTEMS_CURRENT_PRIORITY,
+    &actual
+  rtems_test_assert(expected == actual);
+static void helper(rtems_task_argument arg)
+  test_context *ctx = &test_instance;
+  while (true) {
+    rtems_event_set events = wait_for_events();
+    rtems_test_assert(events == REQ_WAKE_UP_HELPER);
+    send_event(ctx, M, REQ_WAKE_UP_MASTER);
+static void worker(rtems_task_argument arg)
+  task_id id = arg;
+  while (true) {
+    if ((events & REQ_MTX_OBTAIN) != 0) {
+      obtain(ctx);
+      ++ctx->generation[id];
+    if ((events & REQ_MTX_RELEASE) != 0) {
+      release(ctx);
+static void test(void)
+  ctx->tasks[M] = rtems_task_self();
+  start_task(ctx, A_1, worker, 1);
+  start_task(ctx, A_2_0, worker, 2);
+  start_task(ctx, A_2_1, worker, 2);
+  start_task(ctx, H, helper, 3);
+  sc = rtems_semaphore_create(
+    rtems_build_name(' ', 'M', 'T', 'X'),
+    1,
+    RTEMS_BINARY_SEMAPHORE | RTEMS_PRIORITY | RTEMS_INHERIT_PRIORITY,
+    0,
+    &ctx->mtx
+  obtain(ctx);
+  request(ctx, A_1, REQ_MTX_OBTAIN);
+  check_generations(ctx, NONE, NONE);
+  assert_prio(ctx, M, 1);
+  release(ctx);
+  check_generations(ctx, A_1, NONE);
+  assert_prio(ctx, M, 3);
+  request(ctx, A_1, REQ_MTX_RELEASE);
+  obtain(ctx);
+  request(ctx, A_2_0, REQ_MTX_OBTAIN);
+  request(ctx, A_2_1, REQ_MTX_OBTAIN);
+  release(ctx);
+  assert_prio(ctx, A_1, 1);
+  check_generations(ctx, A_1, A_2_0);
+  request(ctx, A_2_0, REQ_MTX_RELEASE);
+  check_generations(ctx, A_2_0, A_2_1);
+  request(ctx, A_2_1, REQ_MTX_RELEASE);
+  check_generations(ctx, A_2_1, NONE);
+static void Init(rtems_task_argument arg)
+  TEST_BEGIN();
+  test();
+  TEST_END();
+  rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS TASK_COUNT
+#define CONFIGURE_MAXIMUM_SEMAPHORES 1
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_INIT_TASK_PRIORITY 3
+#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/sptests/spmutex01/spmutex01.doc b/testsuites/sptests/spmutex01/spmutex01.doc
index 0000000..7951024
--- /dev/null
+++ b/testsuites/sptests/spmutex01/spmutex01.doc
@@ -0,0 +1,14 @@
+This file describes the directives and concepts tested by this test set.
+test set name: spmutex01
+directives:
+  - rtems_semaphore_create()
+  - rtems_semaphore_obtain()
+  - rtems_semaphore_release()
+concepts:
+  - Ensure that priority inheritance mechanism works.
+  - Ensure that thread priority queueing discipline works.
diff --git a/testsuites/sptests/spmutex01/spmutex01.scn b/testsuites/sptests/spmutex01/spmutex01.scn
index 0000000..9c85619
--- /dev/null
+++ b/testsuites/sptests/spmutex01/spmutex01.scn
@@ -0,0 +1,2 @@
+*** BEGIN OF TEST SPMUTEX 1 ***
+*** END OF TEST SPMUTEX 1 ***
2.7.4
