Improve coverage analysis toolset
Joel Sherrill
joel at rtems.org
Sun Mar 25 20:14:09 UTC 2018
I am out and not at a computer. Someone can double check me but I believe
you can replace the PDF you upload.
Unless someone answers soon, just upload it.
--joel
On Mar 25, 2018 2:37 PM, "Vijay Kumar Banerjee" <vijaykumar9597 at gmail.com>
wrote:
> It's the last day before the deadline!
> Please provide a final review of the proposal before submitting.
> Thanks
> -- vijay
> On 24 March 2018 at 21:37, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> wrote:
>> hello mentors and other developers of the community , there are only
>> three days remaining to the GSoC proposal submission deadline.
>> I request the mentors and everyone in the community who has experience in
>> RTEMS, to please go through my proposal for Coverage Analysis tool
>> improvement project , if they have time , and suggest any kind of
>> improvements and changes .
>> here is the link to the proposal
>> https://docs.google.com/document/d/1UjCWE1ojrpDQLQ2fQqxHU0SC
>> rLETlerxD6t0SOcQNLQ/edit?usp=sharing
>> Thank you
>> -- vijay
>> On 22 March 2018 at 04:30, Joel Sherrill <joel at rtems.org> wrote:
>>> Glad you have tests running. Hopefully as Cillian suggested, you can fix
>>> the
>>> remaining issues to see coverage.
>>> We certainly need to get this merged if Chris is OK with it and it
>>> doesn't
>>> break anything else.
>>> I am reviewing proposals now. Seems to be a queue. :)
>>> --joel
>>> On Wed, Mar 21, 2018 at 4:42 AM, Vijay Kumar Banerjee <
>>> vijaykumar9597 at gmail.com> wrote:
>>>> Sir ,
>>>> I have done the changes in the proposal , based on the comments in the
>>>> google doc , please review it and suggest any further changes if required
>>>> Thank you ,
>>>> -- vijay
>>>> P.S : the previous version is in parentheses , I will remove them after
>>>> you review the changes .
>>>> On 18 March 2018 at 16:05, Vijay Kumar Banerjee <
>>>>> Thanks Cillian :)
>>>>> It's great to see it running , I'll do some background reading about
>>>>> RSB, and RTEMS-Tools along with the covoar code . And also work on my
>>>>> python skills.
>>>>> to try rtems-test on a bsp that runs gdb , I tried it on erc32 and
>>>>> that also worked.
>>>>> I'm also waiting for Joel and other mentors' review on my draft
>>>>> proposal, so that I can also work on it and make any changes if needed.
>>>>> Thanks .
>>>>> -- vijay
>>>>> On 18 March 2018 at 14:17, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>> wrote:
>>>>>> On 18 March 2018 at 06:47, Vijay Kumar Banerjee <
>>>>>>> It worked !
>>>>>> That's great! That's the good news then. I was using an old leon3
>>>>>> build and maybe some older Qemu too and I think that's why I didn't see any
>>>>>> issues initially. I was hoping you could see the coverage running and the
>>>>>> reports generated from that but it looks like the full update to the
>>>>>> current master will be necessary to have a look. So until the parsing for
>>>>>> the INI files is added to the coverage.py we won't see the coverage
>>>>>> running. Unfortunately, I'm in the middle of exams until the following
>>>>>> Monday so I won't be able to sink any more time into it until then. You can
>>>>>> still figure out the RSB problem you're having and do some background
>>>>>> reading, brush up on your Python skills, have a read of the covoar code
>>>>>> https://github.com/RTEMS/rtems-tools/blob/master/tester/covo
>>>>>> ar/covoar.cc
>>>>>> just skim through, read the comments, get a sense of the what it's
>>>>>> doing and in what order.
>>>>>>> It's great to see it running ! I have attached the result .
>>>>>>> -- vijay
>>>>>>> On 18 March 2018 at 02:31, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>> wrote:
>>>>>>>> On 17 March 2018 at 20:08, Vijay Kumar Banerjee <
>>>>>>>>> yes it prints hello world
>>>>>>>> Alright I've added an .ini for leon3-qemu to the current
>>>>>>>> rtems-tools. Pull this branch
>>>>>>>> https://github.com/cillianodonnell/rtems-tools/tree/ini-update
>>>>>>>> and try
>>>>>>>> $HOME/development/rtems/test/rtems-tools/tester/rtems-test
>>>>>>>> --rtems-tools=$HOME/development/rtems/5
>>>>>>>> --log=coverage-analysis.log --rtems-bsp=leon3_qemu
>>>>>>>> $HOME/development/rtems/leon3/sparc-rtems5/c/leon3/testsuite
>>>>>>>> s/samples
>>>>>>>>> -- vijay
>>>>>>>>> On 18 March 2018 at 01:31, Cillian O'Donnell <
>>>>>>>>> cpodonnell8 at gmail.com> wrote:
>>>>>>>>>> If you run just one test by itself without rtems-test
>>>>>>>>>> qemu-system-sparc -no-reboot -monitor null -serial stdio
>>>>>>>>>> -nographic -M leon3_generic -kernel $HOME/development/rtems/leon3/
>>>>>>>>>> sparc-rtems5/c/leon3/testsuites/samples/hello/hello.exe
>>>>>>>>>> Does the hello world print out?
>>>>>>>>>> On 17 March 2018 at 14:46, Vijay Kumar Banerjee <
>>>>>>>>>>> I built it manually
>>>>>>>>>>> the environment variable PATH looks like this
>>>>>>>>>>> /home/lunatic/qemu/install/bin:/home/lunatic/development/rte
>>>>>>>>>>> ms/5/bin:/usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/
>>>>>>>>>>> home/lunatic/.local/bin:/home/lunatic/bin
>>>>>>>>>>> I tried to run rtems-test again without --coverage , it gives
>>>>>>>>>>> the same result
>>>>>>>>>>> I have attached the log.
>>>>>>>>>>> -- vijay
>>>>>>>>>>> On 17 March 2018 at 00:55, Cillian O'Donnell <
>>>>>>>>>>>> Yes this is something more than my build, I'll need someone a
>>>>>>>>>>>> bit more expert in the RSB to step in there. In the meantime, lets just
>>>>>>>>>>>> build couverture-qemu manually so we can see is everything else working.
>>>>>>>>>>>> git clone https://github.com/AdaCore/qemu
>>>>>>>>>>>> cd qemu
>>>>>>>>>>>> ./configure --target-list=sparc-softmmu
>>>>>>>>>>>> --prefix=$HOME/qemu/install --disable-docs --disable-virtfs --disable-werror
>>>>>>>>>>>> make
>>>>>>>>>>>> make install
>>>>>>>>>>>> then add the prefix to $PATH in .bashrc as well like before.
>>>>>>>>>>>> export PATH=$HOME/qemu/install/bin:$PATH
>>>>>>>>>>>> Then run rtem-test and see what happens
>>>>>>>>>>>> On 16 March 2018 at 19:13, Vijay Kumar Banerjee <
>>>>>>>>>>>>> the same error comes when I try to build qemu from the
>>>>>>>>>>>>> RTEMS/rtems-source-builder as well
>>>>>>>>>>>>> is the issue coming from my system ? I'm using fedora 27 64bit
>>>>>>>>>>>>> On 17 Mar 2018 12:39 a.m., "Vijay Kumar Banerjee" <
>>>>>>>>>>>>>> yes , the same thing happens
>>>>>>>>>>>>>> On 17 Mar 2018 12:13 a.m., "Cillian O'Donnell" <
>>>>>>>>>>>>>>> If you build regular qemu with the RSB, does the same thing
>>>>>>>>>>>>>>> happen?
>>>>>>>>>>>>>>> Try
>>>>>>>>>>>>>>> ../source-builder/sb-set-builder --log=qemu_log.txt
>>>>>>>>>>>>>>> --prefix=$HOME/development/5 devel/qemu
>>>>>>>>>>>>>>> On 16 March 2018 at 16:48, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>> still the same error
>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>> On 16 March 2018 at 21:39, Cillian O'Donnell <
>>>>>>>>>>>>>>>>> Just checked and the build was failing because one of the
>>>>>>>>>>>>>>>>> patches needed its hash to be updated to sha256. Just pushed that change.
>>>>>>>>>>>>>>>>> The build finishes successfully on my end. Pull that change into
>>>>>>>>>>>>>>>>> couverture-build branch and try it again. I'm not seeing any automake stuff
>>>>>>>>>>>>>>>>> here, so just check that and let me know.
>>>>>>>>>>>>>>>>> On 16 March 2018 at 14:59, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>> building couverture-qemu from rtems-source-builder (
>>>>>>>>>>>>>>>>>> onnell/rtems-source-builder/tree/couverture-build )
>>>>>>>>>>>>>>>>>> gives error building auromake-1.12.6-x86_64-linux-gnu-1 .
>>>>>>>>>>>>>>>>>> I have attached the error report .
>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>> On 15 March 2018 at 19:17, Cillian O'Donnell <
>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 12:26, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>>>> It runs with a bunch of errors . I have attached the
>>>>>>>>>>>>>>>>>>>> log file
>>>>>>>>>>>>>>>>>>> Ok, I'm guessing you didn't set up Couverture-Qemu
>>>>>>>>>>>>>>>>>>> (special version of qemu designed for generating extra trace data for
>>>>>>>>>>>>>>>>>>> coverage analysis). That's what those errors are about. I have an RSB build
>>>>>>>>>>>>>>>>>>> for that.
>>>>>>>>>>>>>>>>>>> and the instructions for building it are
>>>>>>>>>>>>>>>>>>> https://devel.rtems.org/wiki/G
>>>>>>>>>>>>>>>>>>> SoC/2017/coveragetools#BuildingCouverture-QemuwiththeRSB
>>>>>>>>>>>>>>>>>>> I know what the other problem is too. I have a specific
>>>>>>>>>>>>>>>>>>> environment variable defined for the path, sorry I can't even remember
>>>>>>>>>>>>>>>>>>> putting it there, I thought that was automatically generated (probably
>>>>>>>>>>>>>>>>>>> should be, another thing to add to the list :)... ). So wherever you stuck
>>>>>>>>>>>>>>>>>>> the export path for where the rsb built the tools, in .bashrc or whatever
>>>>>>>>>>>>>>>>>>> you're using. Also put something like:
>>>>>>>>>>>>>>>>>>> export PATH=$HOME/development/rtems/5
>>>>>>>>>>>>>>>>>>> /bin:$PATH
>>>>>>>>>>>>>>>>>>> export PATH=$HOME/development/rtems/t
>>>>>>>>>>>>>>>>>>> est/rtems-tools/build/tester/covoar:$PATH
>>>>>>>>>>>>>>>>>>> or you could just copy covoar into the /bin directory
>>>>>>>>>>>>>>>>>>> with all the other rsb tools gcc and all that, it'll find it either way.
>>>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 16:58, Cillian O'Donnell <
>>>>>>>>>>>>>>>>>>>>> Looks good. If you run the samples without coverage is
>>>>>>>>>>>>>>>>>>>>> everything ok?
>>>>>>>>>>>>>>>>>>>>> So removing --coverage and tacking on /samples
>>>>>>>>>>>>>>>>>>>>> $HOME/development/rtems-tools/tester/rtems-test
>>>>>>>>>>>>>>>>>>>>> --rtems-bsp=leon3-qemu --log=log-leon3.log --rtems-tools=$HOME/development/rtems/5
>>>>>>>>>>>>>>>>>>>>> --rtems-builddir=$HOME/development/rtems/kernel/leon3
>>>>>>>>>>>>>>>>>>>>> Do the tests run?
>>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 10:53, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>>>>>> I have attached the output of the ls of that
>>>>>>>>>>>>>>>>>>>>>> directory
>>>>>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 15:52, Cillian O'Donnell <
>>>>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 03:58, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>>>>>>>> hello ,
>>>>>>>>>>>>>>>>>>>>>>>> as told by Joel , I started this thread to further
>>>>>>>>>>>>>>>>>>>>>>>> discuss the coverage analysis toolset .
>>>>>>>>>>>>>>>>>>>>>>>> Current status is , I'm trying to builld and run
>>>>>>>>>>>>>>>>>>>>>>>> rtems-test from the coverage-merge branch of the previous GSoC student
>>>>>>>>>>>>>>>>>>>>>>>> Cillian .
>>>>>>>>>>>>>>>>>>>>>>>> nell/rtems-tools/tree/coverage-merge
>>>>>>>>>>>>>>>>>>>>>>>> I'm getting an error that says .
>>>>>>>>>>>>>>>>>>>>>>>> "Covoar not found !"
>>>>>>>>>>>>>>>>>>>>>>> It's supposed to find it in
>>>>>>>>>>>>>>>>>>>>>>> rtems-tools/build/tester/covoar/ If it's in there
>>>>>>>>>>>>>>>>>>>>>>> it should be fine. Can you show me the contents of that directory?
>>>>>>>>>>>>>>>>>>>>>>> cpod at cpod ~/development/rtems/test/rtems-tools/build/tester/covoar
>>>>>>>>>>>>>>>>>>>>>>> $ ls
>>>>>>>>>>>>>>>>>>>>>>>> the Covoar appeared in rtems-tools/tester/covoar .
>>>>>>>>>>>>>>>>>>>>>>>> Vijay
>>>>>>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>>>>>>> devel mailing list
>>>>>>>>>>>>>>>>>>>>>>>> devel at rtems.org
>>>>>>>>>>>>>>>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180325/eb3ee5f2/attachment-0001.html>
