Improve coverage analysis toolset
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sun Mar 25 20:16:54 UTC 2018
submitted !
If you find time , please give final review as well.
Thanks
On 26 Mar 2018 1:44 a.m., "Joel Sherrill" <joel at rtems.org> wrote:
> I am out and not at a computer. Someone can double check me but I believe
> you can replace the PDF you upload.
> Unless someone answers soon, just upload it.
> --joel
> On Mar 25, 2018 2:37 PM, "Vijay Kumar Banerjee" <vijaykumar9597 at gmail.com>
> wrote:
>> It's the last day before the deadline!
>> Please provide a final review of the proposal before submitting.
>> Thanks
>> -- vijay
>> On 24 March 2018 at 21:37, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
>> > wrote:
>>> hello mentors and other developers of the community , there are only
>>> three days remaining to the GSoC proposal submission deadline.
>>> I request the mentors and everyone in the community who has experience
>>> in RTEMS, to please go through my proposal for Coverage Analysis tool
>>> improvement project , if they have time , and suggest any kind of
>>> improvements and changes .
>>> here is the link to the proposal
>>> https://docs.google.com/document/d/1UjCWE1ojrpDQLQ2fQqxHU0SC
>>> rLETlerxD6t0SOcQNLQ/edit?usp=sharing
>>> Thank you
>>> -- vijay
>>> On 22 March 2018 at 04:30, Joel Sherrill <joel at rtems.org> wrote:
>>>> Glad you have tests running. Hopefully as Cillian suggested, you can
>>>> fix the
>>>> remaining issues to see coverage.
>>>> We certainly need to get this merged if Chris is OK with it and it
>>>> doesn't
>>>> break anything else.
>>>> I am reviewing proposals now. Seems to be a queue. :)
>>>> --joel
>>>> On Wed, Mar 21, 2018 at 4:42 AM, Vijay Kumar Banerjee <
>>>> vijaykumar9597 at gmail.com> wrote:
>>>>> Sir ,
>>>>> I have done the changes in the proposal , based on the comments in the
>>>>> google doc , please review it and suggest any further changes if required
>>>>> Thank you ,
>>>>> -- vijay
>>>>> P.S : the previous version is in parentheses , I will remove them
>>>>> after you review the changes .
>>>>> On 18 March 2018 at 16:05, Vijay Kumar Banerjee <
>>>>>> Thanks Cillian :)
>>>>>> It's great to see it running , I'll do some background reading about
>>>>>> RSB, and RTEMS-Tools along with the covoar code . And also work on my
>>>>>> python skills.
>>>>>> to try rtems-test on a bsp that runs gdb , I tried it on erc32 and
>>>>>> that also worked.
>>>>>> I'm also waiting for Joel and other mentors' review on my draft
>>>>>> proposal, so that I can also work on it and make any changes if needed.
>>>>>> Thanks .
>>>>>> -- vijay
>>>>>> On 18 March 2018 at 14:17, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>> wrote:
>>>>>>> On 18 March 2018 at 06:47, Vijay Kumar Banerjee <
>>>>>>>> It worked !
>>>>>>> That's great! That's the good news then. I was using an old leon3
>>>>>>> build and maybe some older Qemu too and I think that's why I didn't see any
>>>>>>> issues initially. I was hoping you could see the coverage running and the
>>>>>>> reports generated from that but it looks like the full update to the
>>>>>>> current master will be necessary to have a look. So until the parsing for
>>>>>>> the INI files is added to the coverage.py we won't see the coverage
>>>>>>> running. Unfortunately, I'm in the middle of exams until the following
>>>>>>> Monday so I won't be able to sink any more time into it until then. You can
>>>>>>> still figure out the RSB problem you're having and do some background
>>>>>>> reading, brush up on your Python skills, have a read of the covoar code
>>>>>>> https://github.com/RTEMS/rtems-tools/blob/master/tester/covo
>>>>>>> ar/covoar.cc
>>>>>>> just skim through, read the comments, get a sense of the what it's
>>>>>>> doing and in what order.
>>>>>>>> It's great to see it running ! I have attached the result .
>>>>>>>> -- vijay
>>>>>>>> On 18 March 2018 at 02:31, Cillian O'Donnell <cpodonnell8 at gmail.com
>>>>>>>> > wrote:
>>>>>>>>> On 17 March 2018 at 20:08, Vijay Kumar Banerjee <
>>>>>>>>>> yes it prints hello world
>>>>>>>>> Alright I've added an .ini for leon3-qemu to the current
>>>>>>>>> rtems-tools. Pull this branch
>>>>>>>>> https://github.com/cillianodonnell/rtems-tools/tree/ini-update
>>>>>>>>> and try
>>>>>>>>> $HOME/development/rtems/test/rtems-tools/tester/rtems-test
>>>>>>>>> --rtems-tools=$HOME/development/rtems/5
>>>>>>>>> --log=coverage-analysis.log --rtems-bsp=leon3_qemu
>>>>>>>>> $HOME/development/rtems/leon3/sparc-rtems5/c/leon3/testsuite
>>>>>>>>> s/samples
>>>>>>>>>> -- vijay
>>>>>>>>>> On 18 March 2018 at 01:31, Cillian O'Donnell <
>>>>>>>>>> cpodonnell8 at gmail.com> wrote:
>>>>>>>>>>> If you run just one test by itself without rtems-test
>>>>>>>>>>> qemu-system-sparc -no-reboot -monitor null -serial stdio
>>>>>>>>>>> -nographic -M leon3_generic -kernel $HOME/development/rtems/leon3/
>>>>>>>>>>> sparc-rtems5/c/leon3/testsuites/samples/hello/hello.exe
>>>>>>>>>>> Does the hello world print out?
>>>>>>>>>>> On 17 March 2018 at 14:46, Vijay Kumar Banerjee <
>>>>>>>>>>>> I built it manually
>>>>>>>>>>>> the environment variable PATH looks like this
>>>>>>>>>>>> /home/lunatic/qemu/install/bin:/home/lunatic/development/rte
>>>>>>>>>>>> ms/5/bin:/usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/
>>>>>>>>>>>> home/lunatic/.local/bin:/home/lunatic/bin
>>>>>>>>>>>> I tried to run rtems-test again without --coverage , it gives
>>>>>>>>>>>> the same result
>>>>>>>>>>>> I have attached the log.
>>>>>>>>>>>> -- vijay
>>>>>>>>>>>> On 17 March 2018 at 00:55, Cillian O'Donnell <
>>>>>>>>>>>>> Yes this is something more than my build, I'll need someone a
>>>>>>>>>>>>> bit more expert in the RSB to step in there. In the meantime, lets just
>>>>>>>>>>>>> build couverture-qemu manually so we can see is everything else working.
>>>>>>>>>>>>> git clone https://github.com/AdaCore/qemu
>>>>>>>>>>>>> cd qemu
>>>>>>>>>>>>> ./configure --target-list=sparc-softmmu
>>>>>>>>>>>>> --prefix=$HOME/qemu/install --disable-docs --disable-virtfs --disable-werror
>>>>>>>>>>>>> make
>>>>>>>>>>>>> make install
>>>>>>>>>>>>> then add the prefix to $PATH in .bashrc as well like before.
>>>>>>>>>>>>> export PATH=$HOME/qemu/install/bin:$PATH
>>>>>>>>>>>>> Then run rtem-test and see what happens
>>>>>>>>>>>>> On 16 March 2018 at 19:13, Vijay Kumar Banerjee <
>>>>>>>>>>>>>> the same error comes when I try to build qemu from the
>>>>>>>>>>>>>> RTEMS/rtems-source-builder as well
>>>>>>>>>>>>>> is the issue coming from my system ? I'm using fedora 27 64bit
>>>>>>>>>>>>>> On 17 Mar 2018 12:39 a.m., "Vijay Kumar Banerjee" <
>>>>>>>>>>>>>>> yes , the same thing happens
>>>>>>>>>>>>>>> On 17 Mar 2018 12:13 a.m., "Cillian O'Donnell" <
>>>>>>>>>>>>>>>> If you build regular qemu with the RSB, does the same thing
>>>>>>>>>>>>>>>> happen?
>>>>>>>>>>>>>>>> Try
>>>>>>>>>>>>>>>> ../source-builder/sb-set-builder --log=qemu_log.txt
>>>>>>>>>>>>>>>> --prefix=$HOME/development/5 devel/qemu
>>>>>>>>>>>>>>>> On 16 March 2018 at 16:48, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>> still the same error
>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>> On 16 March 2018 at 21:39, Cillian O'Donnell <
>>>>>>>>>>>>>>>>>> Just checked and the build was failing because one of the
>>>>>>>>>>>>>>>>>> patches needed its hash to be updated to sha256. Just pushed that change.
>>>>>>>>>>>>>>>>>> The build finishes successfully on my end. Pull that change into
>>>>>>>>>>>>>>>>>> couverture-build branch and try it again. I'm not seeing any automake stuff
>>>>>>>>>>>>>>>>>> here, so just check that and let me know.
>>>>>>>>>>>>>>>>>> On 16 March 2018 at 14:59, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>>> building couverture-qemu from rtems-source-builder (
>>>>>>>>>>>>>>>>>>> onnell/rtems-source-builder/tree/couverture-build )
>>>>>>>>>>>>>>>>>>> gives error building auromake-1.12.6-x86_64-linux-gnu-1
>>>>>>>>>>>>>>>>>>> I have attached the error report .
>>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 19:17, Cillian O'Donnell <
>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 12:26, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>>>>> It runs with a bunch of errors . I have attached the
>>>>>>>>>>>>>>>>>>>>> log file
>>>>>>>>>>>>>>>>>>>> Ok, I'm guessing you didn't set up Couverture-Qemu
>>>>>>>>>>>>>>>>>>>> (special version of qemu designed for generating extra trace data for
>>>>>>>>>>>>>>>>>>>> coverage analysis). That's what those errors are about. I have an RSB build
>>>>>>>>>>>>>>>>>>>> for that.
>>>>>>>>>>>>>>>>>>>> and the instructions for building it are
>>>>>>>>>>>>>>>>>>>> https://devel.rtems.org/wiki/G
>>>>>>>>>>>>>>>>>>>> SoC/2017/coveragetools#Buildin
>>>>>>>>>>>>>>>>>>>> gCouverture-QemuwiththeRSB
>>>>>>>>>>>>>>>>>>>> I know what the other problem is too. I have a specific
>>>>>>>>>>>>>>>>>>>> environment variable defined for the path, sorry I can't even remember
>>>>>>>>>>>>>>>>>>>> putting it there, I thought that was automatically generated (probably
>>>>>>>>>>>>>>>>>>>> should be, another thing to add to the list :)... ). So wherever you stuck
>>>>>>>>>>>>>>>>>>>> the export path for where the rsb built the tools, in .bashrc or whatever
>>>>>>>>>>>>>>>>>>>> you're using. Also put something like:
>>>>>>>>>>>>>>>>>>>> export PATH=$HOME/development/rtems/5
>>>>>>>>>>>>>>>>>>>> /bin:$PATH
>>>>>>>>>>>>>>>>>>>> export PATH=$HOME/development/rtems/t
>>>>>>>>>>>>>>>>>>>> est/rtems-tools/build/tester/covoar:$PATH
>>>>>>>>>>>>>>>>>>>> or you could just copy covoar into the /bin directory
>>>>>>>>>>>>>>>>>>>> with all the other rsb tools gcc and all that, it'll find it either way.
>>>>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 16:58, Cillian O'Donnell <
>>>>>>>>>>>>>>>>>>>>>> Looks good. If you run the samples without coverage
>>>>>>>>>>>>>>>>>>>>>> is everything ok?
>>>>>>>>>>>>>>>>>>>>>> So removing --coverage and tacking on /samples
>>>>>>>>>>>>>>>>>>>>>> $HOME/development/rtems-tools/tester/rtems-test
>>>>>>>>>>>>>>>>>>>>>> --rtems-bsp=leon3-qemu --log=log-leon3.log --rtems-tools=$HOME/development/rtems/5
>>>>>>>>>>>>>>>>>>>>>> --rtems-builddir=$HOME/development/rtems/kernel/leon3
>>>>>>>>>>>>>>>>>>>>>> Do the tests run?
>>>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 10:53, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>>>>>>> I have attached the output of the ls of that
>>>>>>>>>>>>>>>>>>>>>>> directory
>>>>>>>>>>>>>>>>>>>>>>> -- vijay
>>>>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 15:52, Cillian O'Donnell <
>>>>>>>>>>>>>>>>>>>>>>>> On 15 March 2018 at 03:58, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>>>>>>>>>>>> hello ,
>>>>>>>>>>>>>>>>>>>>>>>>> as told by Joel , I started this thread to further
>>>>>>>>>>>>>>>>>>>>>>>>> discuss the coverage analysis toolset .
>>>>>>>>>>>>>>>>>>>>>>>>> Current status is , I'm trying to builld and run
>>>>>>>>>>>>>>>>>>>>>>>>> rtems-test from the coverage-merge branch of the previous GSoC student
>>>>>>>>>>>>>>>>>>>>>>>>> Cillian .
>>>>>>>>>>>>>>>>>>>>>>>>> nell/rtems-tools/tree/coverage-merge
>>>>>>>>>>>>>>>>>>>>>>>>> I'm getting an error that says .
>>>>>>>>>>>>>>>>>>>>>>>>> "Covoar not found !"
>>>>>>>>>>>>>>>>>>>>>>>> It's supposed to find it in
>>>>>>>>>>>>>>>>>>>>>>>> rtems-tools/build/tester/covoar/ If it's in there
>>>>>>>>>>>>>>>>>>>>>>>> it should be fine. Can you show me the contents of that directory?
>>>>>>>>>>>>>>>>>>>>>>>> cpod at cpod ~/development/rtems/test/rtems-tools/build/tester/covoar
>>>>>>>>>>>>>>>>>>>>>>>> $ ls
>>>>>>>>>>>>>>>>>>>>>>>>> the Covoar appeared in rtems-tools/tester/covoar .
>>>>>>>>>>>>>>>>>>>>>>>>> Vijay
>>>>>>>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>>>>>>>> devel mailing list
>>>>>>>>>>>>>>>>>>>>>>>>> devel at rtems.org
>>>>>>>>>>>>>>>>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180326/0515f6e9/attachment-0001.html>
