[PATCH 1/2] jffs2: Do not use command line defines
Wed Mar 28 04:57:30 UTC 2018
On 28/03/18 01:01, Chris Johns wrote:
> On 27/03/2018 22:01, Sebastian Huber wrote:
>> Update #3375.
>>   cpukit/libfs/Makefile.am                  | 2 --
>>   cpukit/libfs/src/jffs2/src/build.c        | 2 ++
>>   cpukit/libfs/src/jffs2/src/compat-crc32.c | 2 ++
>>   cpukit/libfs/src/jffs2/src/compr.c        | 2 ++
>>   cpukit/libfs/src/jffs2/src/compr_rtime.c  | 2 ++
>>   cpukit/libfs/src/jffs2/src/compr_rubin.c  | 2 ++
>>   cpukit/libfs/src/jffs2/src/compr_zlib.c   | 2 ++
>>   cpukit/libfs/src/jffs2/src/debug.c        | 2 ++
>>   cpukit/libfs/src/jffs2/src/dir-rtems.c    | 2 ++
>>   cpukit/libfs/src/jffs2/src/erase.c        | 2 ++
>>   cpukit/libfs/src/jffs2/src/flashio.c      | 2 ++
>>   cpukit/libfs/src/jffs2/src/fs-rtems.c     | 2 ++
>>   cpukit/libfs/src/jffs2/src/gc.c           | 2 ++
>>   cpukit/libfs/src/jffs2/src/jffs2-config.h | 2 ++
>>   cpukit/libfs/src/jffs2/src/malloc-rtems.c | 2 ++
>>   cpukit/libfs/src/jffs2/src/nodelist.c     | 2 ++
>>   cpukit/libfs/src/jffs2/src/nodemgmt.c     | 2 ++
>>   cpukit/libfs/src/jffs2/src/read.c         | 2 ++
>>   cpukit/libfs/src/jffs2/src/readinode.c    | 2 ++
>>   cpukit/libfs/src/jffs2/src/scan.c         | 2 ++
>>   cpukit/libfs/src/jffs2/src/write.c        | 2 ++
> Does this change diverge the code from the up stream?
Yes, but this is not a problem. Merge conflicts from upstream are
trivially to resolve in this area.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
