[PATCH 1/3] i386/smp: Define unused CPU_Interrupt_frame to fix compiler error
Amaan Cheval amaan.cheval at gmail.com
Mon Mar 12 12:40:44 UTC 2018
Agreed. I'll look into fixing CPU_Interrupt_frame up as time permits.
Appreciate the help and follow-ups, thanks!
On Mon, Mar 12, 2018 at 6:06 PM Sebastian Huber <
> On 12/03/18 13:32, Amaan Cheval wrote:
> > I originally sent this patch with the intent of merely ridding the i386
> > targets of compiler errors, for anyone interested in looking into SMP
> > issues on the arch.
> > Do you believe that I should look into fixing i386's incomplete SMP
> > context-switch support for this patch too, or would that be okay as a
> > follow-up later, given that it seems like there's more incompleteness
> > regarding SMP for i386?
> A compile-time error is a good hint that it is broken. I think this is
> more user friendly compared to having to debug a run-time error which
> takes place only under certain conditions.
