[PATCH] Added Getentropy() support to beagle BSP
Udit agarwal dev.madaari at gmail.com
Thu Mar 15 07:21:40 UTC 2018
On Thu, Mar 15, 2018 at 11:34 AM, Sebastian Huber <
> On 15/03/18 05:56, Udit agarwal wrote:
>> +/* TRNG Register */
>> +/* RNG base address */
> Is the module name TRNG or RNG?
It's TRNG. I'll correct this.
> +#define RNG_BASE 0x48310000
>> +/* RNG clock control */
>> +#define CM_PER_RNG_CLKCTRL (AM335X_CM_PER_ADDR | (9 << 4))
> This define is probably not for the TRNG register block. Should it move
> the corresponding register block?
This define is to enable clock for TRNG module by setting the bit in the
main clock register. Should i place this define with other CM definitions?
> +/* rng module clock status bits */
>> +#define AM335X_CLK_RNG_BIT_MASK (0x30000)
>> +/* Offset from RNG base for output ready flag */
>> +#define RNG_STATUS_RDY (1u <<  0)
>> +/* Offset from RNG base for FRO related error */
>> +#define RNG_STATUS_ERR (1u <<  1)
>> +/* Offset from RNG base for clock status */
>> +#define RNG_STATUS_CLK (1u << 31)
> Are these offsets or bits?
I should have probably marked them as mask bits.
> +/* enable module */
>> +#define AM335X_RNG_ENABLE (1 << 10)
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180315/661310a6/attachment-0002.html>
