Improve coverage analysis toolset
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Fri Mar 16 19:13:50 UTC 2018
the same error comes when I try to build qemu from the
RTEMS/rtems-source-builder as well
is the issue coming from my system ? I'm using fedora 27 64bit
On 17 Mar 2018 12:39 a.m., "Vijay Kumar Banerjee" <vijaykumar9597 at gmail.com>
wrote:
> yes , the same thing happens
> On 17 Mar 2018 12:13 a.m., "Cillian O'Donnell" <cpodonnell8 at gmail.com>
> wrote:
>> If you build regular qemu with the RSB, does the same thing happen?
>> Try
>> ../source-builder/sb-set-builder --log=qemu_log.txt
>> --prefix=$HOME/development/5 devel/qemu
>> On 16 March 2018 at 16:48, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
>> > wrote:
>>> still the same error
>>> -- vijay
>>> On 16 March 2018 at 21:39, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>> wrote:
>>>> Just checked and the build was failing because one of the patches
>>>> needed its hash to be updated to sha256. Just pushed that change. The build
>>>> finishes successfully on my end. Pull that change into couverture-build
>>>> branch and try it again. I'm not seeing any automake stuff here, so just
>>>> check that and let me know.
>>>> On 16 March 2018 at 14:59, Vijay Kumar Banerjee <
>>>> vijaykumar9597 at gmail.com> wrote:
>>>>> building couverture-qemu from rtems-source-builder (
>>>>> https://github.com/cillianodonnell/rtems-source-builder/tr
>>>>> ee/couverture-build )
>>>>> gives error building auromake-1.12.6-x86_64-linux-gnu-1 .
>>>>> I have attached the error report .
>>>>> -- vijay
>>>>> On 15 March 2018 at 19:17, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>> wrote:
>>>>>> On 15 March 2018 at 12:26, Vijay Kumar Banerjee <
>>>>>>> It runs with a bunch of errors . I have attached the log file
>>>>>> Ok, I'm guessing you didn't set up Couverture-Qemu (special version
>>>>>> of qemu designed for generating extra trace data for coverage analysis).
>>>>>> That's what those errors are about. I have an RSB build for that.
>>>>>> https://github.com/cillianodonnell/rtems-source-builder/tree
>>>>>> /couverture-build
>>>>>> and the instructions for building it are
>>>>>> https://devel.rtems.org/wiki/GSoC/2017/coveragetools#Buildin
>>>>>> gCouverture-QemuwiththeRSB
>>>>>> I know what the other problem is too. I have a specific environment
>>>>>> variable defined for the path, sorry I can't even remember putting it
>>>>>> there, I thought that was automatically generated (probably should be,
>>>>>> another thing to add to the list :)... ). So wherever you stuck the export
>>>>>> path for where the rsb built the tools, in .bashrc or whatever you're
>>>>>> using. Also put something like:
>>>>>> export PATH=$HOME/development/rtems/5/bin:$PATH
>>>>>> export PATH=$HOME/development/rtems/test/rtems-tools/build/tester/covoar:$PATH
>>>>>> or you could just copy covoar into the /bin directory with all the
>>>>>> other rsb tools gcc and all that, it'll find it either way.
>>>>>>> -- vijay
>>>>>>> On 15 March 2018 at 16:58, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>> wrote:
>>>>>>>> Looks good. If you run the samples without coverage is everything
>>>>>>>> ok?
>>>>>>>> So removing --coverage and tacking on /samples
>>>>>>>> $HOME/development/rtems-tools/tester/rtems-test
>>>>>>>> --rtems-bsp=leon3-qemu --log=log-leon3.log --rtems-tools=$HOME/development/rtems/5
>>>>>>>> --rtems-builddir=$HOME/development/rtems/kernel/leon3
>>>>>>>> sparc-rtems5/c/leon3/testsuites/samples
>>>>>>>> Do the tests run?
>>>>>>>> On 15 March 2018 at 10:53, Vijay Kumar Banerjee <
>>>>>>>>> I have attached the output of the ls of that directory
>>>>>>>>> -- vijay
>>>>>>>>> On 15 March 2018 at 15:52, Cillian O'Donnell <
>>>>>>>>> cpodonnell8 at gmail.com> wrote:
>>>>>>>>>> On 15 March 2018 at 03:58, Vijay Kumar Banerjee <
>>>>>>>>>>> hello ,
>>>>>>>>>>> as told by Joel , I started this thread to further discuss the
>>>>>>>>>>> coverage analysis toolset .
>>>>>>>>>>> Current status is , I'm trying to builld and run rtems-test from
>>>>>>>>>>> the coverage-merge branch of the previous GSoC student Cillian .
>>>>>>>>>>> https://github.com/cillianodonnell/rtems-tools/tree/coverage
>>>>>>>>>>> -merge
>>>>>>>>>>> I'm getting an error that says .
>>>>>>>>>>> "Covoar not found !"
>>>>>>>>>> It's supposed to find it in rtems-tools/build/tester/covoar/ If
>>>>>>>>>> it's in there it should be fine. Can you show me the contents of that
>>>>>>>>>> directory?
>>>>>>>>>> cpod at cpod ~/development/rtems/test/rtems-tools/build/tester/covoar
>>>>>>>>>> $ ls
>>>>>>>>>>> the Covoar appeared in rtems-tools/tester/covoar .
>>>>>>>>>>> Vijay
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> devel mailing list
>>>>>>>>>>> devel at rtems.org
>>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180317/291878c0/attachment-0002.html>
