Improve coverage analysis toolset
Cillian O'Donnell cpodonnell8 at gmail.com
Fri Mar 16 19:25:57 UTC 2018
Yes this is something more than my build, I'll need someone a bit more
expert in the RSB to step in there. In the meantime, lets just build
couverture-qemu manually so we can see is everything else working.
git clone https://github.com/AdaCore/qemu
cd qemu
./configure --target-list=sparc-softmmu --prefix=$HOME/qemu/install
--disable-docs --disable-virtfs --disable-werror
make
make install
then add the prefix to $PATH in .bashrc as well like before.
export PATH=$HOME/qemu/install/bin:$PATH
Then run rtem-test and see what happens
On 16 March 2018 at 19:13, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> the same error comes when I try to build qemu from the
> RTEMS/rtems-source-builder as well
> is the issue coming from my system ? I'm using fedora 27 64bit
> On 17 Mar 2018 12:39 a.m., "Vijay Kumar Banerjee" <
> vijaykumar9597 at gmail.com> wrote:
>> yes , the same thing happens
>> On 17 Mar 2018 12:13 a.m., "Cillian O'Donnell" <cpodonnell8 at gmail.com>
>> wrote:
>>> If you build regular qemu with the RSB, does the same thing happen?
>>> Try
>>> ../source-builder/sb-set-builder --log=qemu_log.txt
>>> --prefix=$HOME/development/5 devel/qemu
>>> On 16 March 2018 at 16:48, Vijay Kumar Banerjee <
>>>> still the same error
>>>> -- vijay
>>>> On 16 March 2018 at 21:39, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>> wrote:
>>>>> Just checked and the build was failing because one of the patches
>>>>> needed its hash to be updated to sha256. Just pushed that change. The build
>>>>> finishes successfully on my end. Pull that change into couverture-build
>>>>> branch and try it again. I'm not seeing any automake stuff here, so just
>>>>> check that and let me know.
>>>>> On 16 March 2018 at 14:59, Vijay Kumar Banerjee <
>>>>>> building couverture-qemu from rtems-source-builder (
>>>>>> https://github.com/cillianodonnell/rtems-source-builder/tr
>>>>>> ee/couverture-build )
>>>>>> gives error building auromake-1.12.6-x86_64-linux-gnu-1 .
>>>>>> I have attached the error report .
>>>>>> -- vijay
>>>>>> On 15 March 2018 at 19:17, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>> wrote:
>>>>>>> On 15 March 2018 at 12:26, Vijay Kumar Banerjee <
>>>>>>>> It runs with a bunch of errors . I have attached the log file
>>>>>>> Ok, I'm guessing you didn't set up Couverture-Qemu (special version
>>>>>>> of qemu designed for generating extra trace data for coverage analysis).
>>>>>>> That's what those errors are about. I have an RSB build for that.
>>>>>>> https://github.com/cillianodonnell/rtems-source-builder/tree
>>>>>>> /couverture-build
>>>>>>> and the instructions for building it are
>>>>>>> https://devel.rtems.org/wiki/GSoC/2017/coveragetools#Buildin
>>>>>>> gCouverture-QemuwiththeRSB
>>>>>>> I know what the other problem is too. I have a specific environment
>>>>>>> variable defined for the path, sorry I can't even remember putting it
>>>>>>> there, I thought that was automatically generated (probably should be,
>>>>>>> another thing to add to the list :)... ). So wherever you stuck the export
>>>>>>> path for where the rsb built the tools, in .bashrc or whatever you're
>>>>>>> using. Also put something like:
>>>>>>> export PATH=$HOME/development/rtems/5/bin:$PATH
>>>>>>> export PATH=$HOME/development/rtems/test/rtems-tools/build/tester/covoar:$PATH
>>>>>>> or you could just copy covoar into the /bin directory with all the
>>>>>>> other rsb tools gcc and all that, it'll find it either way.
>>>>>>>> -- vijay
>>>>>>>> On 15 March 2018 at 16:58, Cillian O'Donnell <cpodonnell8 at gmail.com
>>>>>>>> > wrote:
>>>>>>>>> Looks good. If you run the samples without coverage is everything
>>>>>>>>> ok?
>>>>>>>>> So removing --coverage and tacking on /samples
>>>>>>>>> $HOME/development/rtems-tools/tester/rtems-test
>>>>>>>>> --rtems-bsp=leon3-qemu --log=log-leon3.log --rtems-tools=$HOME/development/rtems/5
>>>>>>>>> --rtems-builddir=$HOME/development/rtems/kernel/leon3
>>>>>>>>> sparc-rtems5/c/leon3/testsuites/samples
>>>>>>>>> Do the tests run?
>>>>>>>>> On 15 March 2018 at 10:53, Vijay Kumar Banerjee <
>>>>>>>>>> I have attached the output of the ls of that directory
>>>>>>>>>> -- vijay
>>>>>>>>>> On 15 March 2018 at 15:52, Cillian O'Donnell <
>>>>>>>>>> cpodonnell8 at gmail.com> wrote:
>>>>>>>>>>> On 15 March 2018 at 03:58, Vijay Kumar Banerjee <
>>>>>>>>>>>> hello ,
>>>>>>>>>>>> as told by Joel , I started this thread to further discuss the
>>>>>>>>>>>> coverage analysis toolset .
>>>>>>>>>>>> Current status is , I'm trying to builld and run rtems-test
>>>>>>>>>>>> from the coverage-merge branch of the previous GSoC student Cillian .
>>>>>>>>>>>> https://github.com/cillianodonnell/rtems-tools/tree/coverage
>>>>>>>>>>>> -merge
>>>>>>>>>>>> I'm getting an error that says .
>>>>>>>>>>>>  "Covoar not found !"
>>>>>>>>>>> It's supposed to find it in rtems-tools/build/tester/covoar/ If
>>>>>>>>>>> it's in there it should be fine. Can you show me the contents of that
>>>>>>>>>>> directory?
>>>>>>>>>>> cpod at cpod ~/development/rtems/test/rtems-tools/build/tester/covoar
>>>>>>>>>>> $ ls
>>>>>>>>>>>> the Covoar appeared in rtems-tools/tester/covoar .
>>>>>>>>>>>> Vijay
>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>> devel mailing list
>>>>>>>>>>>> devel at rtems.org
>>>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180316/ec6c3040/attachment-0002.html>
