Error in Trace-buffering example
Joel Sherrill
joel at rtems.org
Sun Mar 18 16:44:29 UTC 2018
On Mar 18, 2018 6:48 AM, "Vidushi Vashishth" <reachvidu at gmail.com> wrote:
Hello!
I am hoping to apply to Gsoc'18 for the runtime tracing project. I am
following the RTEMS tracing documentation [1] and have been trying to run
the fileio trace sample to familiarise with how traces are generated. I
have set the rtems-path to the installed BSP erc32 in the fileio-trace.ini.
The directory structure of my set up is the same as provided in the User
manual. However while trying to link the fileio.exe I get a few errors:
Command:
sparc-rtems5-gcc -Bsparc-rtems5/erc32/lib/ -specs bsp_specs -qrtems \
-mcpu=cypress -O2 -g -ffunction-sections -fdata-sections -Wall \
-Wmissing-prototypes -Wimplicit-function-declaration
-Wstrict-prototypes \
-Wnested-externs -Wl,--gc-sections -mcpu=cypress \
-o sparc-rtems5/c/erc32/testsuites/samples/fileio/fileio.exe
sparc-rtems5/c/erc32/testsuites/samples/fileio/init.o
The -B option should have a full path not a partial one. The $prefix used
when building the BSP is missing.
Did you use a full path? Is there an argument missing to the invocation?
Error:
*sparc-rtems5-gcc:* *error: *bsp_specs: No such file or director
Command:
rtems-tld -C fileio-trace.ini -W fileio-wrapper --
-Bsparc-rtems5/erc32/lib/ -specs bsp_specs -qrtems -mcpu=cypress -O2 -g
-ffunction-sections -fdata-sections -Wall -Wmissing-prototypes
-Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs
-Wl,--gc-sections -mcpu=cypress -o sparc-rtems5/c/erc32/
testsuites/samples/fileio/fileio.exe sparc-rtems5/c/erc32/
Error:
error: /development/rtems/kernel/erc32: Invalid RTEMS path
I am in quite a fix. My directory structure seems okay. Would appreciate
some insight.
References:
[1] https://devel.rtems.org/wiki/Developer/Tracing/Trace_Buffering
Best,
Vidushi
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180318/34077c87/attachment-0002.html>
