[PATCH v2 4/6] dhcpcd: Remove unused dhcpcd shell command
Thu May 3 06:49:49 UTC 2018
 libbsd.py                               |  6 -----
 rtemsbsd/include/rtems/netcmds-config.h |  2 --
 rtemsbsd/rtems/rtems-bsd-shell-dhcpcd.c | 40 ---------------------------------
 3 files changed, 48 deletions(-)
 delete mode 100644 rtemsbsd/rtems/rtems-bsd-shell-dhcpcd.c
diff --git a/libbsd.py b/libbsd.py
index 801873ed6..a62581faa 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -4587,12 +4587,6 @@ class dhcpcd(builder.Module):
             mm.generator['source']('-D__FreeBSD__ -DTHERE_IS_NO_FORK -DMASTER_ONLY -DINET -DINET6')
-        self.addRTEMSSourceFiles(
-                'rtems/rtems-bsd-shell-dhcpcd.c',
-            mm.generator['source']()
 # MDNS Responder
diff --git a/rtemsbsd/include/rtems/netcmds-config.h b/rtemsbsd/include/rtems/netcmds-config.h
index 4af43231f..ecb4f56a7 100644
--- a/rtemsbsd/include/rtems/netcmds-config.h
+++ b/rtemsbsd/include/rtems/netcmds-config.h
@@ -33,8 +33,6 @@ extern rtems_shell_cmd_t rtems_shell_IFCONFIG_Command;
 extern rtems_shell_cmd_t rtems_shell_ROUTE_Command;
 extern rtems_shell_cmd_t rtems_shell_NETSTAT_Command;
-extern rtems_shell_cmd_t rtems_shell_DHCPCD_Command;
 extern rtems_shell_cmd_t rtems_shell_HOSTNAME_Command;
 extern rtems_shell_cmd_t rtems_shell_TCPDUMP_Command;
diff --git a/rtemsbsd/rtems/rtems-bsd-shell-dhcpcd.c b/rtemsbsd/rtems/rtems-bsd-shell-dhcpcd.c
deleted file mode 100644
index 248937489..000000000
--- a/rtemsbsd/rtems/rtems-bsd-shell-dhcpcd.c
+++ /dev/null
@@ -1,40 +0,0 @@
- * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
- *  embedded brains GmbH
- *  Dornierstr. 4
- *  82178 Puchheim
- *  Germany
- *  <rtems at embedded-brains.de>
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- *    notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- *    notice, this list of conditions and the following disclaimer in the
- *    documentation and/or other materials provided with the distribution.
- * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
- * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
- * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
- * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
- * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
- * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
-#include <rtems/netcmds-config.h>
-#include <machine/rtems-bsd-commands.h>
-rtems_shell_cmd_t rtems_shell_DHCPCD_Command = {
-  .name = "dhcpcd",
-  .usage = "dhcpcd [args]",
-  .topic = "net",
-  .command = rtems_bsd_command_dhcpcd
2.12.3
