[PATCH v2 4/6] dhcpcd: Remove unused dhcpcd shell command
Chris Johns
chrisj at rtems.org
Thu May 3 07:13:40 UTC 2018
On 03/05/2018 16:49, Sebastian Huber wrote:
> -extern rtems_shell_cmd_t rtems_shell_DHCPCD_Command;
-1. I am not bothering to review the remainder of this patch.
This command is useful. I have used it in the past when working with dhcpd. It
is like running a daemon on the command in Unix to debug a problem. This change
hides that.
There is no explanation for this patch and I do not have the time to second
guess a reason.
If the task body in default-network-init.h bothers you why not move it into a
testsuite support file?
