[PATCH v2 4/6] dhcpcd: Remove unused dhcpcd shell command
Thu May 3 07:20:22 UTC 2018
On 03/05/18 09:13, Chris Johns wrote:
> On 03/05/2018 16:49, Sebastian Huber wrote:
>> -extern rtems_shell_cmd_t rtems_shell_DHCPCD_Command;
> -1. I am not bothering to review the remainder of this patch.
> This command is useful. I have used it in the past when working with dhcpd. It
> is like running a daemon on the command in Unix to debug a problem. This change
> hides that.
This command is not useful. I guess it worked only by accident. The
dhcpcd uses several global variables which are not cleaned up or
properly re-initialized. The dhcpcd command is not supposed to return to
the caller. A running dhcpcd client could be controlled via a special
socket, but his is not properly implemented/ported to RTEMS.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
