[PATCH v2 4/6] dhcpcd: Remove unused dhcpcd shell command
Thu May 3 07:42:23 UTC 2018
On 03/05/18 09:27, Chris Johns wrote:
> On 03/05/2018 17:20, Sebastian Huber wrote:
>> On 03/05/18 09:13, Chris Johns wrote:
>>> On 03/05/2018 16:49, Sebastian Huber wrote:
>>>> -extern rtems_shell_cmd_t rtems_shell_DHCPCD_Command;
>>> -1. I am not bothering to review the remainder of this patch.
>>> This command is useful. I have used it in the past when working with dhcpd. It
>>> is like running a daemon on the command in Unix to debug a problem. This change
>>> hides that.
>> This command is not useful.
> It is for debugging.
> Doing this makes debugging harder. In time we may solve the global issue however
> until then it is still useful.
>> I guess it worked only by accident.
> User beware.
>> The dhcpcd uses
>> several global variables which are not cleaned up or properly re-initialized.
> A patch to let it only be used once would fix that.
> It works on a first pass time and if debugging we have no ^C so it does not matter.
I can keep the command and simply call rtems_dhcpcd_start() in it.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
