[PATCH v2 4/6] dhcpcd: Remove unused dhcpcd shell command
Fri May 4 01:11:16 UTC 2018
On 03/05/2018 17:42, Sebastian Huber wrote:
> On 03/05/18 09:27, Chris Johns wrote:
>> On 03/05/2018 17:20, Sebastian Huber wrote:
>>> On 03/05/18 09:13, Chris Johns wrote:
>>>> On 03/05/2018 16:49, Sebastian Huber wrote:
>>>>> -extern rtems_shell_cmd_t rtems_shell_DHCPCD_Command;
>>>> -1. I am not bothering to review the remainder of this patch.
>>>> This command is useful. I have used it in the past when working with dhcpd. It
>>>> is like running a daemon on the command in Unix to debug a problem. This change
>>>> hides that.
>>> This command is not useful.
>> It is for debugging.
>> Doing this makes debugging harder. In time we may solve the global issue however
>> until then it is still useful.
>>> I guess it worked only by accident.
>> User beware.
>>> The dhcpcd uses
>>> several global variables which are not cleaned up or properly re-initialized.
>> A patch to let it only be used once would fix that.
>> It works on a first pass time and if debugging we have no ^C so it does not
>> matter.
> I can keep the command and simply call rtems_dhcpcd_start() in it.
Keeping the command is important, making it better is good. It is useful playing
with the options and settings for the client which I have done a few times.
