rtems-tools: coverage covoar GSoC merge
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Thu May 3 15:22:54 UTC 2018
Hello,
I want to ask some things about the project to get a clear understanding of
the objectives/milestones and current status of the project. I also seek
advice on my Tasks/obectives.
1. The covoar has been updated to read symbols from the library and the
next milestone is to remove covoar's dependancy on the external tools,
which Chris is working on . ( Is that correct? )
2. after it is done , the next step,I think, would be to update the
coverage.py and test.py with the changes in covoar.
While the Covoar is being updated, shall I be looking into the
documentations and read the code to gain better understanding? Do you
suggest me to work on some specific task ?
Please suggest resources to gain better understanding of how coverage
analysis works/supposed to work with the rtems tester. (I can even try
updating the documentations with some help, this will also help me get
better understanding ).
Thank you.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180503/ebde53dd/attachment.html>
