How to download the required tar file?
Danxue Huang danxue.huang at gmail.com
Fri May 11 04:01:06 UTC 2018
Hi there,
I got stuck on 2.5 installing a tar file ( I have attached the website
below).
https://docs.rtems.org/branches/master/rsb/quick-start.html#building
The tar file is supposed that I have downloaded in my machine, but there is
not a required .bz2 file "rtems-4.11-sparc-rtems4.11-1.tar.bz2", all my
files ends at .bz2 are as below.
./development/rtems/src/rtems-source-builder/rtems/sources/gmp-5.0.5.tar.bz2
./development/rtems/src/rtems-source-builder/rtems/sources/b
inutils-2.26.tar.bz2
./development/rtems/src/rtems-source-builder/rtems/sources/rtems-tools-
25863503edb513e7501481ff2074c02bf219f519.tar.bz2
inutils-2.30.tar.bz2
./development/rtems/src/rtems-source-builder/rtems/sources/gmp-6.1.0.tar.bz2
./development/rtems/src/rtems-source-builder/rtems/sources/gcc-4.9.3.tar.bz2
./development/rtems/src/rtems-source-builder/rtems/sources/m
pfr-3.0.1.tar.bz2
pfr-3.1.4.tar.bz2
Is there any other way I can download the required tar file? Thank you!
Best,
Dannie
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180510/52b58626/attachment.html>
