Errors returned while building a SPARC tool set
Danxue Huang danxue.huang at gmail.com
Thu May 10 15:59:13 UTC 2018
Hey Chris,
You are correct that  the disk space of Ubuntu is not large enough since it
is in a VM, I resized the disk space and then problem was solved.
Thank you so much! :D
-Dannie
On Thu, May 10, 2018 at 2:28 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 10/5/18 4:47 am, Danxue Huang wrote:
> > Hi Dr. Johns,
> Hi, please feel free to use Chris. And thanks for the promotion to Dr but
> Joel
> and Gedare are the esteemed doctors :)
> > I just got a new laptop (Windows) and I got stuck on building a SPARC
> tool set
> > using Ubuntu in Virtual Box. To build a SPARC tool set, I use the
> command as below.
> > ../source-builder/sb-set-builder --log=1-sparc.txt
> > --prefix=$HOME/development/rtems config/5/rtems-sparc64.bset
> > Is there anything wrong in it? After I input this command, it kept
> building for
> > an hour but finally returned "Build FAILED", errors returned as follows.
> > error: building sparc-rtems5-gdb-8.0.1-x86_64-linux-gnu-1
> > I also attached l-sparc.txt which is used to build a SPARC tool set, I
> would
> > appreciate that if you can do me a favor to check it.
> I assume this is in a VM because it is Windows. Is that true? Are you
> sharing
> disk space with the Windows host in the VM? This can sometime do weird
> things
> when building the tools.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180510/a331430a/attachment-0002.html>
