[PATCH] x86_64/gcc: Have gcc build crti.o and crtn.o
Amaan Cheval amaan.cheval at gmail.com
Mon May 14 09:06:31 UTC 2018
Hey, Chris! Just thought I'd remind you of this pending patch in case
it slipped through the cracks. Let me know if you'd like any changes!
On Tue, May 8, 2018 at 11:23 PM, Amaan Cheval <amaan.cheval at gmail.com> wrote:
> The original commit in GCC's repo is here:
> https://gcc.gnu.org/git/?p=gcc.git;a=commitdiff;h=ab55f7db3694293e4799d58f7e1a556c0eae863a
> We need this to be able to use crti.o and crtn.o in the bsp_specs file for the
> port, and therefore provide missing symbols like "_fini" which RTEMS assumes are
> defined in:
> ./cpukit/libcsupport/src/newlibc_exit.c
>  rtems/config/5/rtems-x86_64.bset | 6 ++++++
>  1 file changed, 6 insertions(+)
> diff --git a/rtems/config/5/rtems-x86_64.bset b/rtems/config/5/rtems-x86_64.bset
> index 951ae85..9b92538 100644
> --- a/rtems/config/5/rtems-x86_64.bset
> +++ b/rtems/config/5/rtems-x86_64.bset
> @@ -8,4 +8,10 @@
>  %patch add gcc --rsb-file=gcc-99c7ae16793d88d7c16c692fb468ab308cb4d12d.patch https://gcc.gnu.org/git/?p=gcc.git;a=blobdiff_plain;f=gcc/config.gcc;h=99c7ae16793d88d7c16c692fb468ab308cb4d12d;hp=ae19655bf328e29ea4f00966b5060967684a7f1b;hb=602fa1e9d3ea5e87d4d6e17e3e91fc2647e42da3;hpb=7ea6a6472d360c634a00358dbaab2e236e785367
>  %hash sha512 gcc-99c7ae16793d88d7c16c692fb468ab308cb4d12d.patch ed519aacb199be54bce514bd6745cf532d66250f0163e8be6b6e630d83ec1a68e086467320f589191dce3a7638bdc867663f38dfc569ee2f27c6b686c040130f
> +# Have gcc build crti.o and crtn.o
> +%patch add gcc --rsb-file=gcc-f8fd78279d353f6959e75ac25571c1b7b2dec110.patch https://gcc.gnu.org/git/?p=gcc.git;a=blobdiff_plain;f=libgcc/config.host;h=f8fd78279d353f6959e75ac25571c1b7b2dec110;hp=11b4acaff55e00ee6bd3c182e9da5dc597ac57c4;hb=ab55f7db3694293e4799d58f7e1a556c0eae863a;hpb=344c180cca810c50f38fd545bb9a102fb39306b7
> +%hash sha512 gcc-f8fd78279d353f6959e75ac25571c1b7b2dec110.patch aef76f9d45a53096a021521375fc302a907f78545cc57683a7a00ec61608b8818115720f605a6b1746f479c8568963b380138520e259cbb9e8951882c2f1567f
>  %include 5/rtems-default.bset
> 2.13.0
