[PATCH] covoar: Fix build path checks for multiple executables.
Cillian O'Donnell cpodonnell8 at gmail.com
Mon May 14 19:26:21 UTC 2018
 tester/covoar/covoar.cc | 10 +++-------
 1 file changed, 3 insertions(+), 7 deletions(-)
diff --git a/tester/covoar/covoar.cc b/tester/covoar/covoar.cc
index 5c87402..c6b0589 100644
--- a/tester/covoar/covoar.cc
+++ b/tester/covoar/covoar.cc
@@ -75,7 +75,7 @@ static void createBuildPath(Executables& executablesToAnalyze,
         if (buildPrefix.empty()) {
           buildPrefix = *pri;
         } else {
-          if (buildBSP != *pri) {
+          if (buildPrefix != *pri) {
             fail = "executable build prefix does not match: " + buildPrefix;
             break;
@@ -97,7 +97,7 @@ static void createBuildPath(Executables& executablesToAnalyze,
         if (buildPath.empty()) {
           buildPath = thisBuildPath;
         } else {
+          if (buildPath != thisBuildPath) {
             fail = "executable build path does not match: " + buildPath;
@@ -316,11 +316,7 @@ int main(
         std::cerr << "warning: Unable to read executable: " << argv[i] << std::endl;
       } else {
         coverageFileName = argv[i];
-        coverageFileName.replace(
-          coverageFileName.length() - executableExtension.size(),
-          coverageExtension
+        coverageFileName.append( "." + coverageExtension );
         if (!FileIsReadable( coverageFileName.c_str() )) {
           std::cerr << "warning: Unable to read coverage file: " << coverageFileName
2.7.4
