Query regarding disk cache in RTEMS
Udit agarwal
dev.madaari at gmail.com
Thu May 17 13:13:35 UTC 2018
Hi all,
I was looking at the internal working of a benchmark and the way it
disables cache for direct IO operations, needed to benchmark storage device
drivers. I have a small query regarding how cache is organized in RTEMS:
Usually data transfer model is something like:
Application address space --> Page cache --> Write-back cache --> storage
device
is this model valid for RTEMS too?
Moreover, in FreeBSD/Linux, O_DIRECT flag is used with the file descriptor
to bypass write-back cache. do we have something like that in RTEMS? AFAIK,
In RTEMS, libblock is used to transfer data to the storage device. So,
configuring it like:
> #define CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS 0
should disable the cache? or is there any other setting that should be
tweaked?
Regards,
Udit
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180517/f7e8a029/attachment.html>
