[PATCH 0/1] posixtimer01 test questions and patch
Martin Erik Werner martinerikwerner.aac at gmail.com
Mon May 28 06:35:34 UTC 2018
Hi,
(Re-ping regarding previous mail.)
Does anyone have an idea regarding if the psxtimer01 test can be
expected to report a time difference as described below, or if this is
something that is not expected and should be treated as a valid test
failure?
(Please also see related patch.)
Martin Erik Werner <martinerikwerner.aac at gmail.com>
ÅAC Microtec AB | Clyde Space Ltd.
On Tue, 2018-05-15 at 11:21 +0200, Martin Erik Werner wrote:
> When running the testsuites/psxtests/psxtimer01/ tests on our or1k
> board, I've noticed a common 10ms (one clock tick) time difference when
> measuring the re-armed time value in task A and C, which causes the
> posixtimer01 test to report failure:
> if (sigwait(&set,&received_sig) == -1) {
>   perror ("Error in sigwait\n");
> if (timer_gettime(timer_id, &timerdata) == -1) {
>   perror ("Error in timer_gettime\n");
>   rtems_test_exit(0);
> if (! _Timespec_Equal_to( &timerdata.it_value, &my_period )){
>   perror ("Error in Task A timer_gettime\n");
> Given that this time value check is disabled in task B:
> #if 0
>       *  It is not an error if they are not equal.  A clock tick could occur
>       *  and thus they are close but not equal.  Can we test for this?
>      if ( !_Timespec_Equal_to( &timerdata.it_value, &my_period) ){
>        printf( "NOT EQUAL %d:%d != %d:%d\n",
>           timerdata.it_value.tv_sec,
>           timerdata.it_value.tv_nsec,
>           my_period.tv_sec,
>           my_period.tv_nsec
>        rtems_test_exit(0);
> #endif
> does this check still belong as a certain failure in task A and C?
> I've made a modification to the failure printout in order to avoid using unset
> errno, and to provide information about the time difference, which might be
> interesting, if these checks are still valid as certain failures:
> Martin Erik Werner (1):
>   Fix and extend error message in posix timer test
>  testsuites/psxtests/psxtimer01/psxtimer.c | 14 ++++++++++++--
>  1 file changed, 12 insertions(+), 2 deletions(-)
