Fwd: GDB fails to build with Python 3.7
Tue May 29 12:44:55 UTC 2018
Is this the Ubuntu issue reported?
---------- Forwarded message ---------
Date: Tue, May 29, 2018, 6:38 AM
Subject: GDB fails to build with Python 3.7
To: <gdb at sourceware.org>
Currently GDB fails to build with Python 3.7
https://bugs.python.org/issue33470
This is because we use an internal Python API:
#ifdef IS_PY3K
  gdb_module = PyModule_Create (&python_GdbModuleDef);
  /* Add _gdb module to the list of known built-in modules.  */
  _PyImport_FixupBuiltin (gdb_module, "_gdb");
#else
  gdb_module = Py_InitModule ("_gdb", python_GdbMethods);
#endif
(the _PyImport_FixupBuiltin in python.c).
This internal API has been changed. According to the advice of the Python
maintainers we should never have used it in the first place. I didn't
add this (at least I don't think I did!), so I'm asking whomever
authored that code to please change it to be 3.7 compatible. I'm not
sure what the code achieves so I'm reluctant to touch it in case of
breakages on platforms I don't have easily access to.
Cheers
Phil
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180529/144cbfd4/attachment.html>
