[GSoC] Tracing
Vidushi Vashishth reachvidu at gmail.com
Tue May 29 15:40:12 UTC 2018
Hi!
Just updating that I have sent a patch which fixes the trace buffer
generation. I am now able to generate trace buffers for the fileio sample
testcase. I will begin work on CTF conversion now.
Thanks,
Vidushi
On Tue, May 29, 2018 at 1:00 PM, Vidushi Vashishth <reachvidu at gmail.com>
wrote:
> Hey Sebastian!
> Yes I have been working on the trace linker the past week. It is outdated
> and needs improvements. A lot of my work depends on me fixing the trace
> linker. I had informed about this last week during the meeting. I thought I
> would update you as soon as I make progress. Nevertheless the following is
> the status of my work:
> 1) Identified problems with the trace linker and working on a patch which
> would fix the trace buffer generation. Using the fileio sample as a
> testcase. I talked to Chris regarding the problems I was facing in the
> process yesterday and am getting close to finishing it.
> 2) Collected all the relevant wiki documentation page links about the
> tracing system which would be removed once the user manual is updated.
> 3) Installed babeltrace on mac and linux environments and understood its
> working. Once the trace linker is fixed and starts generating trace data it
> would be fed into babeltrace to convert it into CTF.
> That's about it.
> Best,
> Vidushi
> On Tue, May 29, 2018 at 12:37 PM, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> Hello Vidushi,
>> I though you agreed to send a regular status report on Monday? Do you
>> still work on the project?
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> <https://maps.google.com/?q=Dornierstr.+4,+D-82178+Puchheim,+Germany&entry=gmail&source=g>
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180529/16c477f2/attachment-0002.html>
