[PATCH v2] tester: Add script to generate html coverage report from covoar output
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Thu May 31 20:29:27 UTC 2018
On 1 June 2018 at 01:57, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
> So is it checking whether it's --coverage or --coverage=set1,set2? Are
> those the 2 possibilities your checking?
> Yes, right. :)
> On Thu, 31 May 2018, 20:52 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
> wrote:
>> On 1 June 2018 at 01:19, Gedare Bloom <gedare at rtems.org> wrote:
>>> On Thu, May 31, 2018 at 3:47 PM, Vijay Kumar Banerjee
>>> <vijaykumar9597 at gmail.com> wrote:
>>> > On 1 June 2018 at 01:07, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>> wrote:
>>> >> On 31 May 2018 at 19:07, Vijay Kumar Banerjee <
>>> >> wrote:
>>> >>> Add support in tester to run covoar and generate an html report to
>>> >>> display
>>> >>> the summary of the coverage reports generated from covoar.
>>> >>> Co-authored-by : Cillian O'Donnell <cpodonnell8 at gmail.com>
>>> >>> tester/rt/coverage.py | 379
>>> >>> tester/rt/test.py | 36 ++-
>>> >>> tester/rtems/testing/bsps/leon3-qemu-cov.ini | 3 +-
>>> >>> tester/rtems/testing/coverage/symbol-sets.ini | 36 +++
>>> >>> tester/rtems/testing/qemu.cfg | 4 +-
>>> >>> 5 files changed, 446 insertions(+), 12 deletions(-)
>>> >>> create mode 100644 tester/rt/coverage.py
>>> >>> create mode 100644 tester/rtems/testing/coverage/symbol-sets.ini
>>> >>> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>>> >>> new file mode 100644
>>> >>> index 0000000..25fbb9d
>>> >>> --- /dev/null
>>> >>> +++ b/tester/rt/coverage.py
>>> >>> @@ -0,0 +1,379 @@
>>> >>> +# RTEMS Tools Project (http://www.rtems.org/)
>>> >>> +# Copyright 2014 Krzysztof Miesowicz (krzysztof.miesowicz at gmail.com
>>> >>> +# All rights reserved.
>>> >>> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
>>> >>> +# Redistribution and use in source and binary forms, with or without
>>> >>> +# modification, are permitted provided that the following
>>> conditions are
>>> >>> met:
>>> >>> +# 1. Redistributions of source code must retain the above copyright
>>> >>> notice,
>>> >>> +# this list of conditions and the following disclaimer.
>>> >>> +# 2. Redistributions in binary form must reproduce the above
>>> copyright
>>> >>> notice,
>>> >>> +# this list of conditions and the following disclaimer in the
>>> >>> documentation
>>> >>> +# and/or other materials provided with the distribution.
>>> >>> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>>> CONTRIBUTORS
>>> >>> 'AS IS'
>>> >>> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>>> TO,
>>> >>> THE
>>> >>> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>>> >>> PURPOSE
>>> >>> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>>> CONTRIBUTORS
>>> >>> BE
>>> >>> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY,
>>> OR
>>> >>> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
>>> OF
>>> >>> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>> >>> BUSINESS
>>> >>> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>>> WHETHER
>>> >>> IN
>>> >>> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>> >>> OTHERWISE)
>>> >>> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>>> ADVISED OF
>>> >>> THE
>>> >>> +# POSSIBILITY OF SUCH DAMAGE.
>>> >>> +from rtemstoolkit import error
>>> >>> +from rtemstoolkit import path
>>> >>> +from rtemstoolkit import log
>>> >>> +from rtemstoolkit import execute
>>> >>> +from rtemstoolkit import macros
>>> >>> +from datetime import datetime
>>> >>> +from . import options
>>> >>> +import shutil
>>> >>> +import os
>>> >>> +try:
>>> >>> + import configparser
>>> >>> +except:
>>> >>> + import ConfigParser as configparser
>>> >>> +class summary:
>>> >>> + def __init__(self, p_summary_dir):
>>> >>> + self.summary_file_path = path.join(p_summary_dir,
>>> 'summary.txt')
>>> >>> + self.index_file_path = path.join(p_summary_dir,
>>> 'index.html')
>>> >>> + self.bytes_analyzed = 0
>>> >>> + self.bytes_not_executed = 0
>>> >>> + self.percentage_executed = 0.0
>>> >>> + self.percentage_not_executed = 100.0
>>> >>> + self.ranges_uncovered = 0
>>> >>> + self.branches_uncovered = 0
>>> >>> + self.branches_total = 0
>>> >>> + self.branches_always_taken = 0
>>> >>> + self.branches_never_taken = 0
>>> >>> + self.percentage_branches_covered = 0.0
>>> >>> + self.is_failure = False
>>> >>> + def parse(self):
>>> >>> + if(not path.exists(self.summary_file_path)):
>>> >>> + log.notice('summary file %s does not exist!' %
>>> >>> + self.is_failure = True
>>> >>> + return
>>> >>> + with open(self.summary_file_path,'r') as summary_file:
>>> >>> + self.bytes_analyzed = self._get_next_with_colon(
>>> summary_file)
>>> >>> self._get_next_with_colon(summary_file)
>>> >>> + self.branches_total = self._get_next_with_colon(
>>> summary_file)
>>> >>> self._get_next_without_colon(summary_file)
>>> >>> + if len(self.branches_uncovered) > 0 and
>>> len(self.branches_total)
>>> >>> > 0:
>>> >>> + self.percentage_branches_covered = \
>>> >>> + 1 - (float(self.branches_uncovered) /
>>> >>> float(self.branches_total))
>>> >>> + else:
>>> >>> + return
>>> >>> + def _get_next_with_colon(self, summary_file):
>>> >>> + line = summary_file.readline()
>>> >>> + if ':' in line:
>>> >>> + return line.split(':')[1].strip()
>>> >>> + else:
>>> >>> + return ''
>>> >>> + def _get_next_without_colon(self, summary_file):
>>> >>> + return line.strip().split(' ')[0]
>>> >>> +class report_gen_html:
>>> >>> + def __init__(self, p_symbol_sets_list, build_dir, rtdir):
>>> >>> + self.symbol_sets_list = ['score']
>>> >>> + self.build_dir = build_dir
>>> >>> + self.partial_reports_files = list(["index.html",
>>> "summary.txt"])
>>> >>> + self.number_of_columns = 1
>>> >>> + self.covoar_src_path = path.join(rtdir, 'covoar')
>>> >>> + def _find_partial_reports(self):
>>> >>> + partial_reports = {}
>>> >>> + for symbol_set in self.symbol_sets_list:
>>> >>> + set_summary = summary(path.join(self.build_dir,
>>> "coverage",
>>> >>> + symbol_set))
>>> >>> + set_summary.parse()
>>> >>> + partial_reports[symbol_set] = set_summary
>>> >>> + return partial_reports
>>> >>> + def _prepare_head_section(self):
>>> >>> + head_section = '''
>>> >>> + <head>
>>> >>> + <title>RTEMS coverage report</title>
>>> >>> + <style type="text/css">
>>> >>> + progress[value] {
>>> >>> + -webkit-appearance: none;
>>> >>> + appearance: none;
>>> >>> + width: 150px;
>>> >>> + height: 15px;
>>> >>> + </style>
>>> >>> + </head>'''
>>> >>> + return head_section
>>> >>> + def _prepare_index_content(self, partial_reports):
>>> >>> + header = "<h1> RTEMS coverage analysis report </h1>"
>>> >>> + header += "<h3>Coverage reports by symbols sets:</h3>"
>>> >>> + table = "<table>"
>>> >>> + table += self._header_row()
>>> >>> + for symbol_set in partial_reports:
>>> >>> + table += self._row(symbol_set,
>>> partial_reports[symbol_set])
>>> >>> + table += "</table> </br>"
>>> >>> + timestamp = "Analysis performed on " +
>>> datetime.now().ctime()
>>> >>> + return "<body>\n" + header + table + timestamp + "\n</body>"
>>> >>> + def _row(self, symbol_set, summary):
>>> >>> + row = "<tr>"
>>> >>> + row += "<td>" + symbol_set + "</td>"
>>> >>> + if summary.is_failure:
>>> >>> + row += ' <td colspan="' + str(self.number_of_columns-1)
>>> >>> + + '" style="background-color:red">FAILURE</td>'
>>> >>> + else:
>>> >>> + row += " <td>" + self._link(summary.index_file_
>>> path,"Index")
>>> >>> + + "</td>"
>>> >>> + row += " <td>" +
>>> >>> self._link(summary.summary_file_path,"Summary") \
>>> >>> + + "</td>"
>>> >>> + row += " <td>" + summary.bytes_analyzed + "</td>"
>>> >>> + row += " <td>" + summary.bytes_not_executed + "</td>"
>>> >>> + row += " <td>" + summary.ranges_uncovered + "</td>"
>>> >>> + row += " <td>" + summary.percentage_executed + "%</td>"
>>> >>> + row += " <td>" + summary.percentage_not_executed +
>>> "%</td>"
>>> >>> + row += ' <td><progress value="' +
>>> >>> summary.percentage_executed \
>>> >>> + + '" max="100"></progress></td>'
>>> >>> + row += " <td>" + summary.branches_uncovered + "</td>"
>>> >>> + row += " <td>" + summary.branches_total + "</td>"
>>> >>> + row += " <td> {:.3%}
>>> >>> </td>".format(summary.percentage_branches_covered)
>>> >>> + row += ' <td><progress value="{:.3}"
>>> >>> max="100"></progress></td>'.format(100*summary.percentage_
>>> branches_covered)
>>> >>> + row += "</tr>\n"
>>> >>> + return row
>>> >>> + def _header_row(self):
>>> >>> + row = "<tr>"
>>> >>> + row += "<th> Symbols set name </th>"
>>> >>> + row += "<th> Index file </th>"
>>> >>> + row += "<th> Summary file </th>"
>>> >>> + row += "<th> Bytes analyzed </th>"
>>> >>> + row += "<th> Bytes not executed </th>"
>>> >>> + row += "<th> Uncovered ranges </th>"
>>> >>> + row += "<th> Percentage covered </th>"
>>> >>> + row += "<th> Percentage uncovered </th>"
>>> >>> + row += "<th> Instruction coverage </th>"
>>> >>> + row += "<th> Branches uncovered </th>"
>>> >>> + row += "<th> Branches total </th>"
>>> >>> + row += "<th> Branches covered percentage </th>"
>>> >>> + row += "<th> Branches coverage </th>"
>>> >>> + row += "</tr>\n"
>>> >>> + self.number_of_columns = row.count('<th>')
>>> >>> + return row
>>> >>> + def _link(self, address, text):
>>> >>> + return '<a href="' + address + '">' + text + '</a>'
>>> >>> + def _create_index_file(self, head_section, content):
>>> >>> + with open(path.join(self.build_dir,"report.html"),'w') as
>>> f:
>>> >>> + f.write(head_section)
>>> >>> + f.write(content)
>>> >>> + def generate(self):
>>> >>> + partial_reports = self._find_partial_reports()
>>> >>> + head_section = self._prepare_head_section()
>>> >>> + index_content = self._prepare_index_content(
>>> partial_reports)
>>> >>> + self._create_index_file(head_section,index_content)
>>> >>> + def add_covoar_src_path(self):
>>> >>> + table_js_path = path.join(self.covoar_src_path, 'table.js')
>>> >>> + covoar_css_path = path.join(self.covoar_src_path,
>>> 'covoar.css')
>>> >>> + symbol_set_dir = path.join(self.build_dir, "coverage",
>>> >>> symbol_set)
>>> >>> + html_files = os.listdir(symbol_set_dir)
>>> >>> + for html_file in html_files:
>>> >>> + html_file = path.join(symbol_set_dir, html_file)
>>> >>> + if path.exists(html_file) and 'html' in html_file:
>>> >>> + with open(html_file, 'r') as f:
>>> >>> + file_data = f.read()
>>> >>> + file_data = file_data.replace('table.js',
>>> >>> table_js_path)
>>> >>> + file_data = file_data.replace('covoar.css',
>>> >>> + covoar_css_path)
>>> >>> + with open(html_file, 'w') as f:
>>> >>> + f.write(file_data)
>>> >>> +class build_path_generator(object):
>>> >>> + Generates the build path from the path to executables
>>> >>> + def __init__(self, executables, target):
>>> >>> + self.executables = executables
>>> >>> + self.target = target
>>> >>> + def run(self):
>>> >>> + build_path = '/'
>>> >>> + Path = self.executables[0].split('/')
>>> >>> + for P in Path:
>>> >>> + if P == self.target:
>>> >>> + break;
>>> >>> + else:
>>> >>> + build_path = path.join(build_path, P)
>>> >>> + return build_path
>>> >>> +class symbol_parser(object):
>>> >>> + Parse the symbol sets ini and create custom ini file for covoar
>>> >>> + def __init__(self, symbol_config_path,
>>> >>> + symbol_select_path, coverage_arg, build_dir):
>>> >>> + self.symbol_select_file = symbol_select_path
>>> >>> + self.symbol_file = symbol_config_path
>>> >>> + self.symbol_sets = {}
>>> >>> + self.cov_arg = coverage_arg
>>> >>> + self.ssets = []
>>> >>> + def parse(self):
>>> >>> + config = configparser.ConfigParser()
>>> >>> + try:
>>> >>> + config.read(self.symbol_file)
>>> >>> + if self.cov_arg:
>>> >>> + self.ssets = self.cov_arg.split(',')
>>> >>> + else:
>>> >>> + self.ssets = config.get('symbol-sets',
>>> >>> 'sets').split(',')
>>> >>> + self.ssets = [ sset.encode('utf-8') for sset in
>>> >>> self.ssets]
>>> >>> + for sset in self.ssets:
>>> >>> + lib = path.join(self.build_dir,
>>> >>> + config.get('libraries', sset))
>>> >>> + self.symbol_sets[sset] = lib.encode('utf-8')
>>> >>> + except:
>>> >>> + raise error.general('Symbol set parsing failed')
>>> >>> + def _write_ini(self):
>>> >>> + try:
>>> >>> + sets = ', '.join(self.symbol_sets.keys())
>>> >>> + config.add_section('symbol-sets')
>>> >>> + config.set('symbol-sets', 'sets', sets)
>>> >>> + for key in self.symbol_sets.keys():
>>> >>> + config.add_section(key)
>>> >>> + config.set(key, 'libraries', self.symbol_sets[key])
>>> >>> + with open(self.symbol_select_file, 'w') as conf:
>>> >>> + config.write(conf)
>>> >>> + except:
>>> >>> + raise error.general('write failed')
>>> >>> + def run(self):
>>> >>> + self.parse()
>>> >>> + self._write_ini()
>>> >>> +class covoar(object):
>>> >>> + Covoar runner
>>> >>> + def __init__(self, base_result_dir, config_dir, executables,
>>> >>> explanations_txt):
>>> >>> + self.base_result_dir = base_result_dir
>>> >>> + self.config_dir = config_dir
>>> >>> + self.executables = ' '.join(executables)
>>> >>> + self.explanations_txt = explanations_txt
>>> >>> + self.project_name = 'RTEMS-5'
>>> >>> + def run(self, set_name, symbol_file):
>>> >>> + covoar_result_dir = path.join(self.base_result_dir,
>>> set_name)
>>> >>> + if (not path.exists(covoar_result_dir)):
>>> >>> + path.mkdir(covoar_result_dir)
>>> >>> + if (not path.exists(symbol_file)):
>>> >>> + raise error.general('symbol set file: coverage %s was
>>> not
>>> >>> created for covoar, skipping %s'% (symbol_file, set_name))
>>> >>> + command = ('covoar -S ' + symbol_file
>>> >>> + + ' -O ' + covoar_result_dir
>>> >>> + + ' -E ' + self.explanations_txt
>>> >>> + + ' -p ' + self.project_name + ' ' +
>>> self.executables)
>>> >>> + log.notice('Running covoar for %s' % (set_name))
>>> >>> + print( 'covoar results directory:\n' + covoar_result_dir )
>>> >>> + executor = execute.execute(verbose = True, output =
>>> >>> self.output_handler)
>>> >>> + exit_code = executor.shell(command, cwd=os.getcwd())
>>> >>> + if (exit_code[0] != 0):
>>> >>> + raise error.general('covoar failure exit code: %d' %
>>> >>> (exit_code[0]))
>>> >>> + log.notice('Coverage run for %s finished successfully.' %
>>> >>> (set_name))
>>> >>> + log.notice('------------------
>>> >>> + def output_handler(self, text):
>>> >>> + log.notice('%s' % (text))
>>> >>> +class coverage_run(object):
>>> >>> + Coverage analysis support for rtems-test
>>> >>> + def __init__(self, p_macros, coverage_arg, target):
>>> >>> + Constructor
>>> >>> + self.macros = p_macros
>>> >>> + self.build_dir = self.macros['_cwd']
>>> >>> self.macros.expand(self.macros['cov_explanations'])
>>> >>> + self.test_dir = path.join(self.build_dir, 'coverage')
>>> >>> + if (not path.exists(self.test_dir)):
>>> >>> + path.mkdir(self.test_dir)
>>> >>> + self.rtdir = path.abspath(self.macros['_rtdir'])
>>> >>> + self.rtscripts = self.macros.expand(self.
>>> macros['_rtscripts'])
>>> >>> + self.coverage_config_path = path.join(self.rtscripts,
>>> >>> 'coverage')
>>> >>> + self.symbol_config_path = path.join(self.coverage_
>>> config_path,
>>> >>> + 'symbol-sets.ini')
>>> >>> + self.symbol_select_path = path.join(self.coverage_
>>> config_path,
>>> >>> + 'symbol-select.ini')
>>> >>> + self.executables = None
>>> >>> + self.symbol_sets = []
>>> >>> + self.no_clean = int(self.macros['_no_clean'])
>>> >>> + self.report_format = self.macros['cov_report_format']
>>> >>> + self.coverage_arg = coverage_arg
>>> >>> + def run(self):
>>> >>> + try:
>>> >>> + if self.executables is None:
>>> >>> + raise error.general('no test executables provided.')
>>> >>> + build_dir = build_path_generator(self.executables,
>>> >>> self.target).run()
>>> >>> + parser = symbol_parser(self.symbol_config_path,
>>> >>> + self.symbol_select_path,
>>> >>> + self.coverage_arg,
>>> >>> + build_dir)
>>> >>> + parser.run()
>>> >>> + covoar_runner = covoar(self.test_dir,
>>> >>> + self.executables,
>>> >>> self.explanations_txt)
>>> >>> + covoar_runner.run('score', self.symbol_select_path)
>>> >>> + self._generate_reports();
>>> >>> + self._summarize();
>>> >>> + finally:
>>> >>> + self._cleanup();
>>> >>> + def _generate_reports(self):
>>> >>> + log.notice('Generating reports')
>>> >>> + if self.report_format == 'html':
>>> >>> + report = report_gen_html(self.symbol_sets,
>>> >>> + self.build_dir,
>>> >>> + self.rtdir)
>>> >>> + report.generate()
>>> >>> + report.add_covoar_src_path()
>>> >>> + def _cleanup(self):
>>> >>> + if not self.no_clean:
>>> >>> + log.notice('***Cleaning tempfiles***')
>>> >>> + for exe in self.executables:
>>> >>> + trace_file = exe + '.cov'
>>> >>> + if path.exists(trace_file):
>>> >>> + os.remove(trace_file)
>>> >>> + def _summarize(self):
>>> >>> + log.notice('Coverage analysis finished. You can find
>>> results in
>>> >>> %s' % (self.build_dir))
>>> >>> diff --git a/tester/rt/test.py b/tester/rt/test.py
>>> >>> index f4d9b5c..84dff01 100644
>>> >>> --- a/tester/rt/test.py
>>> >>> +++ b/tester/rt/test.py
>>> >>> @@ -48,12 +48,14 @@ from rtemstoolkit import mailer
>>> >>> from rtemstoolkit import reraise
>>> >>> from rtemstoolkit import stacktraces
>>> >>> from rtemstoolkit import version
>>> >>> +from rtemstoolkit import check
>>> >>> from . import bsps
>>> >>> from . import config
>>> >>> from . import console
>>> >>> from . import report
>>> >>> +from . import coverage
>>> >>> class log_capture(object):
>>> >>> def __init__(self):
>>> >>> @@ -147,7 +149,7 @@ class test_run(object):
>>> >>> def run(self):
>>> >>> self.thread = threading.Thread(target = self.runner,
>>> >>> - name = 'test[%s]' %
>>> >>> path.basename(self.executable))
>>> >>> + name = 'test[%s]' %
>>> >>> self.thread.start()
>>> >>> def is_alive(self):
>>> >>> @@ -214,6 +216,10 @@ def killall(tests):
>>> >>> for test in tests:
>>> >>> test.kill()
>>> >>> +def coverage_run(opts, coverage, executables):
>>> >>> + coverage.executables = executables
>>> >>> + coverage.run()
>>> >>> def run(command_path = None):
>>> >>> import sys
>>> >>> tests = []
>>> >>> @@ -221,15 +227,16 @@ def run(command_path = None):
>>> >>> opts = None
>>> >>> default_exefilter = '*.exe'
>>> >>> try:
>>> >>> - optargs = { '--rtems-tools': 'The path to the RTEMS tools',
>>> >>> - '--rtems-bsp': 'The RTEMS BSP to run the test
>>> on',
>>> >>> - '--user-config': 'Path to your local user
>>> >>> configuration INI file',
>>> >>> - '--report-mode': 'Reporting modes, failures
>>> >>> (default),all,none',
>>> >>> - '--list-bsps': 'List the supported BSPs',
>>> >>> - '--debug-trace': 'Debug trace based on specific
>>> >>> flags',
>>> >>> - '--filter': 'Glob that executables must
>>> match
>>> >>> to run (default: ' +
>>> >>> + optargs = { '--rtems-tools': 'The path to the RTEMS
>>> tools',
>>> >>> + '--rtems-bsp': 'The RTEMS BSP to run the
>>> test
>>> >>> on',
>>> >>> + '--user-config': 'Path to your local user
>>> >>> + '--report-mode': 'Reporting modes, failures
>>> >>> + '--list-bsps': 'List the supported BSPs',
>>> >>> + '--debug-trace': 'Debug trace based on
>>> specific
>>> >>> flags',
>>> >>> + '--filter': 'Glob that executables must
>>> >>> match to run (default: ' +
>>> >>> default_exefilter + ')',
>>> >>> - '--stacktrace': 'Dump a stack trace on a user
>>> >>> termination (^C)' }
>>> >>> + '--stacktrace': 'Dump a stack trace on a
>>> user
>>> >>> termination (^C)',
>>> >>> + '--coverage': 'Perform coverage analysis
>>> of
>>> >>> test executables.'}
>>> >>> mailer.append_options(optargs)
>>> >>> opts = options.load(sys.argv,
>>> >>> optargs = optargs,
>>> >>> @@ -279,6 +286,15 @@ def run(command_path = None):
>>> >>> raise error.general('RTEMS BSP not provided or an
>>> invalid
>>> >>> option')
>>> >>> bsp = config.load(bsp[1], opts)
>>> >>> bsp_config = opts.defaults.expand(opts.defaults['tester'])
>>> >>> + coverage_enabled = opts.find_arg('--coverage')
>>> >>> + if coverage_enabled:
>>> >>> + if len(coverage_enabled) == 2:
>>> >> Is this to check if sets have been provided to --coverage=score,sapi,
>>> that
>>> >> kind of thing? If so the variable name coverage_enabled doesn't make
>>> sense
>>> >> any more. Probably if symbol_sets and if len(symbol_sets) will make
>>> more
>>> >> sense for both cases.
>>> > That's a good point.
>>> > How about changing it to just 'coverage' instead ?
>>> > Because it's still checking whether the option is given or
>>> > not. symbol_sets might create confusion.
>>> > Will that be OK ?
>>> That name might collide with your class object (coverage)?
>> That's actually why I kept it as coverage_enabled.
>> I think we can go for coverage_option (?)
>>> >>> + coverage_runner = coverage.coverage_run(opts.
>>> defaults,
>>> >>> + coverage_enabled[1],
>>> opts.defaults['target'])
>>> >>> + else:
>>> defaults,
>>> >>> 0,
>>> >>> report_mode = opts.find_arg('--report-mode')
>>> >>> if report_mode:
>>> >>> if report_mode[1] != 'failures' and \
>>> >>> @@ -365,6 +381,8 @@ def run(command_path = None):
>>> >>> reports.failures(),
>>> >>> 'Log', '===', ''] + output.get()
>>> >>> mail.send(to_addr, subject, os.linesep.join(body))
>>> >>> + coverage_run(opts, coverage_runner, executables)
>>> >>> except error.general as gerr:
>>> >>> print(gerr)
>>> >>> diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>> >>> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>> >>> index 6b5e7e6..2f89117 100644
>>> >>> --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>> >>> +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>> >>> @@ -31,9 +31,10 @@
>>> >>> # The Leon 3 QEMU BSP
>>> >>> -[leon3-qemu]
>>> >>> +[leon3-qemu-cov]
>>> >>> bsp = leon3-qemu
>>> >>> arch = sparc
>>> >>> +target = sparc-rtems5
>>> >>> tester = %{_rtscripts}/qemu.cfg
>>> >>> bsp_qemu_opts = %{qemu_opts_base} -M leon3_generic
>>> >>> bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
>>> >>> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
>>> >>> b/tester/rtems/testing/coverage/symbol-sets.ini
>>> >>> index 0000000..a2ec7bc
>>> >>> --- /dev/null
>>> >>> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
>>> >>> @@ -0,0 +1,36 @@
>>> >>> +# Copyright 2018 Chris Johns (chrisj at rtems.org)
>>> conditions are
>>> >>> met:
>>> >>> notice,
>>> copyright
>>> >>> notice,
>>> >>> documentation
>>> CONTRIBUTORS
>>> >>> "AS IS"
>>> TO,
>>> >>> THE
>>> >>> PURPOSE
>>> CONTRIBUTORS
>>> >>> BE
>>> OR
>>> OF
>>> >>> BUSINESS
>>> WHETHER
>>> >>> IN
>>> >>> OTHERWISE)
>>> ADVISED OF
>>> >>> THE
>>> >>> +[symbol-sets]
>>> >>> +sets = score,rtems
>>> >>> +[libraries]
>>> >>> +score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>>> >>> +rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>>> >>> diff --git a/tester/rtems/testing/qemu.cfg
>>> >>> b/tester/rtems/testing/qemu.cfg
>>> >>> index bfcd2f5..52a3752 100644
>>> >>> --- a/tester/rtems/testing/qemu.cfg
>>> >>> +++ b/tester/rtems/testing/qemu.cfg
>>> >>> @@ -51,8 +51,8 @@
>>> >>> # Qemu common option patterns.
>>> >>> -#%define qemu_opts_base -no-reboot -monitor none -serial stdio
>>> >>> -nographic
>>> >>> -%define qemu_opts_base -no-reboot -serial null -serial mon:stdio
>>> >>> -nographic
>>> >>> +%define qemu_opts_base -no-reboot -monitor none -serial stdio
>>> >>> -nographic
>>> >>> +#%define qemu_opts_base -no-reboot -serial null -serial mon:stdio
>>> >>> -nographic
>>> >>> %define qemu_opts_no_net -net none
>>> >>> 2.14.3
>>> >>> _______________________________________________
>>> >>> devel mailing list
>>> >>> devel at rtems.org
>>> >>> http://lists.rtems.org/mailman/listinfo/devel
>>> > devel mailing list
>>> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180601/c01b845b/attachment-0001.html>
