[PATCH v2] tester: Add script to generate html coverage report from covoar output
Joel Sherrill
joel at rtems.org
Thu May 31 22:10:35 UTC 2018
On Thu, May 31, 2018 at 4:57 PM, Vijay Kumar Banerjee <
vijaykumar9597 at gmail.com> wrote:
> On 1 June 2018 at 02:50, Joel Sherrill <joel at rtems.org> wrote:
>> On Thu, May 31, 2018 at 4:15 PM, Cillian O'Donnell <cpodonnell8 at gmail.com
>> > wrote:
>>> On Thu, 31 May 2018, 22:03 Vijay Kumar Banerjee, <
>>>> On 1 June 2018 at 02:14, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>> wrote:
>>>>> There is now a seperate bsp config for coverage, leon3-qemu-cov. That
>>>>> is enough to trigger coverage now and --coverage could be reserved for
>>>>> picking sets, probably renamed to --coverage-sets=... Or require sets to be
>>>>> chosen --coverage-sets=all or specific sets --coverage-sets=score,sapi,cor
>>>>> e
>>>>> Actually the idea of having separate bsp configs for cov
>>>> in each of the bsps will create a lot of files. The intention is
>>>> to make it simple for the user. just adding --coverage
>>>> should run coverage analysis. There's a plan to include
>>>> the 'coverage' section into the bsp ini file, and hence the user
>>>> wouldn't
>>>> have to keep switching the bsp config files.
>>> Actually that's exactly the way I had it working before Chris' recent
>>> changes, he had a look at the way it's working and chose to create seperate
>>> bsp config files. That may be the way he'd prefer. This was before the
>>> --coverage option had another use other than triggering coverage, so his
>>> thoughts may have changed on it.
>> Chris should comment on the separate ini files. I think that might have
>> been
>> driven by couverture vs regular qemu before couverture was available from
>> the RSB.
>> Okay, we wait for Chris to comment on it then.
>> I think it would be nice to have --coverage and if the BSP ini file
>> doesn't support
>> coverage, give an error.
> Is the set option in the Python and processed by covoar in a way that still
>> lets covoar be used on something besides RTEMS?
> yes, it is totally handled by the script to 'feed' covoar with the
> options,
> without changing the way it works.
> I have a question/doubt.
> By adding separate bsp config for cov. Are we not assuming that
> the provided bsp ini supports coverage ?
I think having two leon3 configurations like we do now is temporary
just to have something that works. Any changes to the coverage
version don't impact the baseline.
I am hoping Chris has an idea to unified these. :)
>>>> The idea of modifying it to --coverage-sets=all ;
>>>> --coverage-sets=set1,set2,set3..... can surely be implemented
>>>> in place of --coverage ; --coverage=set1,set2....
>>>>> On Thu, 31 May 2018, 21:29 Vijay Kumar Banerjee, <
>>>>>> On 1 June 2018 at 01:57, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>> wrote:
>>>>>>> So is it checking whether it's --coverage or --coverage=set1,set2?
>>>>>>> Are those the 2 possibilities your checking?
>>>>>>> Yes, right. :)
>>>>>>> On Thu, 31 May 2018, 20:52 Vijay Kumar Banerjee, <
>>>>>>>> On 1 June 2018 at 01:19, Gedare Bloom <gedare at rtems.org> wrote:
>>>>>>>>> On Thu, May 31, 2018 at 3:47 PM, Vijay Kumar Banerjee
>>>>>>>>> <vijaykumar9597 at gmail.com> wrote:
>>>>>>>>> > On 1 June 2018 at 01:07, Cillian O'Donnell <
>>>>>>>>> cpodonnell8 at gmail.com> wrote:
>>>>>>>>> >> On 31 May 2018 at 19:07, Vijay Kumar Banerjee <
>>>>>>>>> >> wrote:
>>>>>>>>> >>> Add support in tester to run covoar and generate an html
>>>>>>>>> report to
>>>>>>>>> >>> display
>>>>>>>>> >>> the summary of the coverage reports generated from covoar.
>>>>>>>>> >>> Co-authored-by : Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>>>> >>> tester/rt/coverage.py | 379
>>>>>>>>> >>> tester/rt/test.py | 36 ++-
>>>>>>>>> >>> tester/rtems/testing/bsps/leon3-qemu-cov.ini | 3 +-
>>>>>>>>> >>> tester/rtems/testing/coverage/symbol-sets.ini | 36 +++
>>>>>>>>> >>> tester/rtems/testing/qemu.cfg | 4 +-
>>>>>>>>> >>> 5 files changed, 446 insertions(+), 12 deletions(-)
>>>>>>>>> >>> create mode 100644 tester/rt/coverage.py
>>>>>>>>> >>> create mode 100644 tester/rtems/testing/coverage/
>>>>>>>>> symbol-sets.ini
>>>>>>>>> >>> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>>>>>>>>> >>> new file mode 100644
>>>>>>>>> >>> index 0000000..25fbb9d
>>>>>>>>> >>> --- /dev/null
>>>>>>>>> >>> +++ b/tester/rt/coverage.py
>>>>>>>>> >>> @@ -0,0 +1,379 @@
>>>>>>>>> >>> +# RTEMS Tools Project (http://www.rtems.org/)
>>>>>>>>> >>> +# Copyright 2014 Krzysztof Miesowicz (
>>>>>>>>> krzysztof.miesowicz at gmail.com)
>>>>>>>>> >>> +# All rights reserved.
>>>>>>>>> >>> +# This file is part of the RTEMS Tools package in
>>>>>>>>> 'rtems-tools'.
>>>>>>>>> >>> +# Redistribution and use in source and binary forms, with or
>>>>>>>>> without
>>>>>>>>> >>> +# modification, are permitted provided that the following
>>>>>>>>> conditions are
>>>>>>>>> >>> met:
>>>>>>>>> >>> +# 1. Redistributions of source code must retain the above
>>>>>>>>> copyright
>>>>>>>>> >>> notice,
>>>>>>>>> >>> +# this list of conditions and the following disclaimer.
>>>>>>>>> >>> +# 2. Redistributions in binary form must reproduce the above
>>>>>>>>> copyright
>>>>>>>>> >>> notice,
>>>>>>>>> >>> +# this list of conditions and the following disclaimer in the
>>>>>>>>> >>> documentation
>>>>>>>>> >>> +# and/or other materials provided with the distribution.
>>>>>>>>> >>> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>>>>>>>>> CONTRIBUTORS
>>>>>>>>> >>> 'AS IS'
>>>>>>>>> >>> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
>>>>>>>>> LIMITED TO,
>>>>>>>>> >>> THE
>>>>>>>>> >>> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>>>>>>>>> PARTICULAR
>>>>>>>>> >>> PURPOSE
>>>>>>>>> >>> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>>>>>>>>> CONTRIBUTORS
>>>>>>>>> >>> BE
>>>>>>>>> >>> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
>>>>>>>>> EXEMPLARY, OR
>>>>>>>>> >>> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
>>>>>>>>> PROCUREMENT OF
>>>>>>>>> >>> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
>>>>>>>>> PROFITS; OR
>>>>>>>>> >>> BUSINESS
>>>>>>>>> >>> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
>>>>>>>>> LIABILITY, WHETHER
>>>>>>>>> >>> IN
>>>>>>>>> >>> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>>>>>>>> >>> OTHERWISE)
>>>>>>>>> >>> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>>>>>>>>> ADVISED OF
>>>>>>>>> >>> THE
>>>>>>>>> >>> +# POSSIBILITY OF SUCH DAMAGE.
>>>>>>>>> >>> +from rtemstoolkit import error
>>>>>>>>> >>> +from rtemstoolkit import path
>>>>>>>>> >>> +from rtemstoolkit import log
>>>>>>>>> >>> +from rtemstoolkit import execute
>>>>>>>>> >>> +from rtemstoolkit import macros
>>>>>>>>> >>> +from datetime import datetime
>>>>>>>>> >>> +from . import options
>>>>>>>>> >>> +import shutil
>>>>>>>>> >>> +import os
>>>>>>>>> >>> +try:
>>>>>>>>> >>> + import configparser
>>>>>>>>> >>> +except:
>>>>>>>>> >>> + import ConfigParser as configparser
>>>>>>>>> >>> +class summary:
>>>>>>>>> >>> + def __init__(self, p_summary_dir):
>>>>>>>>> >>> + self.summary_file_path = path.join(p_summary_dir,
>>>>>>>>> 'summary.txt')
>>>>>>>>> >>> + self.index_file_path = path.join(p_summary_dir,
>>>>>>>>> 'index.html')
>>>>>>>>> >>> + self.bytes_analyzed = 0
>>>>>>>>> >>> + self.bytes_not_executed = 0
>>>>>>>>> >>> + self.percentage_executed = 0.0
>>>>>>>>> >>> + self.percentage_not_executed = 100.0
>>>>>>>>> >>> + self.ranges_uncovered = 0
>>>>>>>>> >>> + self.branches_uncovered = 0
>>>>>>>>> >>> + self.branches_total = 0
>>>>>>>>> >>> + self.branches_always_taken = 0
>>>>>>>>> >>> + self.branches_never_taken = 0
>>>>>>>>> >>> + self.percentage_branches_covered = 0.0
>>>>>>>>> >>> + self.is_failure = False
>>>>>>>>> >>> + def parse(self):
>>>>>>>>> >>> + if(not path.exists(self.summary_file_path)):
>>>>>>>>> >>> + log.notice('summary file %s does not exist!' %
>>>>>>>>> >>> + self.is_failure = True
>>>>>>>>> >>> + return
>>>>>>>>> >>> + with open(self.summary_file_path,'r') as
>>>>>>>>> summary_file:
>>>>>>>>> self._get_next_with_colon(summary_file)
>>>>>>>>> >>> self._get_next_without_colon(summary_file)
>>>>>>>>> >>> + if len(self.branches_uncovered) > 0 and
>>>>>>>>> len(self.branches_total)
>>>>>>>>> >>> > 0:
>>>>>>>>> >>> + self.percentage_branches_covered = \
>>>>>>>>> >>> + 1 - (float(self.branches_uncovered) /
>>>>>>>>> >>> float(self.branches_total))
>>>>>>>>> >>> + else:
>>>>>>>>> >>> + return
>>>>>>>>> >>> + def _get_next_with_colon(self, summary_file):
>>>>>>>>> >>> + line = summary_file.readline()
>>>>>>>>> >>> + if ':' in line:
>>>>>>>>> >>> + return line.split(':')[1].strip()
>>>>>>>>> >>> + else:
>>>>>>>>> >>> + return ''
>>>>>>>>> >>> + def _get_next_without_colon(self, summary_file):
>>>>>>>>> >>> + return line.strip().split(' ')[0]
>>>>>>>>> >>> +class report_gen_html:
>>>>>>>>> >>> + def __init__(self, p_symbol_sets_list, build_dir, rtdir):
>>>>>>>>> >>> + self.symbol_sets_list = ['score']
>>>>>>>>> >>> + self.build_dir = build_dir
>>>>>>>>> >>> + self.partial_reports_files = list(["index.html",
>>>>>>>>> "summary.txt"])
>>>>>>>>> >>> + self.number_of_columns = 1
>>>>>>>>> >>> + self.covoar_src_path = path.join(rtdir, 'covoar')
>>>>>>>>> >>> + def _find_partial_reports(self):
>>>>>>>>> >>> + partial_reports = {}
>>>>>>>>> >>> + for symbol_set in self.symbol_sets_list:
>>>>>>>>> >>> + set_summary = summary(path.join(self.build_dir,
>>>>>>>>> "coverage",
>>>>>>>>> >>> + symbol_set))
>>>>>>>>> >>> + set_summary.parse()
>>>>>>>>> >>> + partial_reports[symbol_set] = set_summary
>>>>>>>>> >>> + return partial_reports
>>>>>>>>> >>> + def _prepare_head_section(self):
>>>>>>>>> >>> + head_section = '''
>>>>>>>>> >>> + <head>
>>>>>>>>> >>> + <title>RTEMS coverage report</title>
>>>>>>>>> >>> + <style type="text/css">
>>>>>>>>> >>> + progress[value] {
>>>>>>>>> >>> + -webkit-appearance: none;
>>>>>>>>> >>> + appearance: none;
>>>>>>>>> >>> + width: 150px;
>>>>>>>>> >>> + height: 15px;
>>>>>>>>> >>> + </style>
>>>>>>>>> >>> + </head>'''
>>>>>>>>> >>> + return head_section
>>>>>>>>> >>> + def _prepare_index_content(self, partial_reports):
>>>>>>>>> >>> + header = "<h1> RTEMS coverage analysis report </h1>"
>>>>>>>>> >>> + header += "<h3>Coverage reports by symbols sets:</h3>"
>>>>>>>>> >>> + table = "<table>"
>>>>>>>>> >>> + table += self._header_row()
>>>>>>>>> >>> + for symbol_set in partial_reports:
>>>>>>>>> >>> + table += self._row(symbol_set,
>>>>>>>>> partial_reports[symbol_set])
>>>>>>>>> >>> + table += "</table> </br>"
>>>>>>>>> >>> + timestamp = "Analysis performed on " +
>>>>>>>>> datetime.now().ctime()
>>>>>>>>> >>> + return "<body>\n" + header + table + timestamp +
>>>>>>>>> "\n</body>"
>>>>>>>>> >>> + def _row(self, symbol_set, summary):
>>>>>>>>> >>> + row = "<tr>"
>>>>>>>>> >>> + row += "<td>" + symbol_set + "</td>"
>>>>>>>>> >>> + if summary.is_failure:
>>>>>>>>> >>> + row += ' <td colspan="' +
>>>>>>>>> str(self.number_of_columns-1) \
>>>>>>>>> >>> + + '" style="background-color:red">FAILURE</td>'
>>>>>>>>> >>> + else:
>>>>>>>>> >>> + row += " <td>" + self._link(summary.index_file_
>>>>>>>>> path,"Index")
>>>>>>>>> >>> + + "</td>"
>>>>>>>>> >>> + row += " <td>" +
>>>>>>>>> >>> self._link(summary.summary_file_path,"Summary") \
>>>>>>>>> >>> + + "</td>"
>>>>>>>>> >>> + row += " <td>" + summary.bytes_analyzed + "</td>"
>>>>>>>>> >>> + row += " <td>" + summary.bytes_not_executed +
>>>>>>>>> "</td>"
>>>>>>>>> >>> + row += " <td>" + summary.ranges_uncovered +
>>>>>>>>> "</td>"
>>>>>>>>> >>> + row += " <td>" + summary.percentage_executed +
>>>>>>>>> "%</td>"
>>>>>>>>> >>> + row += " <td>" + summary.percentage_not_executed
>>>>>>>>> + "%</td>"
>>>>>>>>> >>> + row += ' <td><progress value="' +
>>>>>>>>> >>> summary.percentage_executed \
>>>>>>>>> >>> + + '" max="100"></progress></td>'
>>>>>>>>> >>> + row += " <td>" + summary.branches_uncovered +
>>>>>>>>> "</td>"
>>>>>>>>> >>> + row += " <td>" + summary.branches_total + "</td>"
>>>>>>>>> >>> + row += " <td> {:.3%}
>>>>>>>>> >>> </td>".format(summary.percentage_branches_covered)
>>>>>>>>> >>> + row += ' <td><progress value="{:.3}"
>>>>>>>>> >>> max="100"></progress></td>'.format(100*summary.percentage_br
>>>>>>>>> anches_covered)
>>>>>>>>> >>> + row += "</tr>\n"
>>>>>>>>> >>> + return row
>>>>>>>>> >>> + def _header_row(self):
>>>>>>>>> >>> + row = "<tr>"
>>>>>>>>> >>> + row += "<th> Symbols set name </th>"
>>>>>>>>> >>> + row += "<th> Index file </th>"
>>>>>>>>> >>> + row += "<th> Summary file </th>"
>>>>>>>>> >>> + row += "<th> Bytes analyzed </th>"
>>>>>>>>> >>> + row += "<th> Bytes not executed </th>"
>>>>>>>>> >>> + row += "<th> Uncovered ranges </th>"
>>>>>>>>> >>> + row += "<th> Percentage covered </th>"
>>>>>>>>> >>> + row += "<th> Percentage uncovered </th>"
>>>>>>>>> >>> + row += "<th> Instruction coverage </th>"
>>>>>>>>> >>> + row += "<th> Branches uncovered </th>"
>>>>>>>>> >>> + row += "<th> Branches total </th>"
>>>>>>>>> >>> + row += "<th> Branches covered percentage </th>"
>>>>>>>>> >>> + row += "<th> Branches coverage </th>"
>>>>>>>>> >>> + row += "</tr>\n"
>>>>>>>>> >>> + self.number_of_columns = row.count('<th>')
>>>>>>>>> >>> + return row
>>>>>>>>> >>> + def _link(self, address, text):
>>>>>>>>> >>> + return '<a href="' + address + '">' + text + '</a>'
>>>>>>>>> >>> + def _create_index_file(self, head_section, content):
>>>>>>>>> >>> + with open(path.join(self.build_dir,"report.html"),'w')
>>>>>>>>> as f:
>>>>>>>>> >>> + f.write(head_section)
>>>>>>>>> >>> + f.write(content)
>>>>>>>>> >>> + def generate(self):
>>>>>>>>> >>> + partial_reports = self._find_partial_reports()
>>>>>>>>> >>> + head_section = self._prepare_head_section()
>>>>>>>>> >>> + index_content = self._prepare_index_content(pa
>>>>>>>>> rtial_reports)
>>>>>>>>> >>> + self._create_index_file(head_section,index_content)
>>>>>>>>> >>> + def add_covoar_src_path(self):
>>>>>>>>> >>> + table_js_path = path.join(self.covoar_src_path,
>>>>>>>>> 'table.js')
>>>>>>>>> >>> + covoar_css_path = path.join(self.covoar_src_path,
>>>>>>>>> 'covoar.css')
>>>>>>>>> >>> + symbol_set_dir = path.join(self.build_dir,
>>>>>>>>> "coverage",
>>>>>>>>> >>> symbol_set)
>>>>>>>>> >>> + html_files = os.listdir(symbol_set_dir)
>>>>>>>>> >>> + for html_file in html_files:
>>>>>>>>> >>> + html_file = path.join(symbol_set_dir,
>>>>>>>>> html_file)
>>>>>>>>> >>> + if path.exists(html_file) and 'html' in
>>>>>>>>> html_file:
>>>>>>>>> >>> + with open(html_file, 'r') as f:
>>>>>>>>> >>> + file_data = f.read()
>>>>>>>>> >>> + file_data = file_data.replace('table.js',
>>>>>>>>> >>> table_js_path)
>>>>>>>>> >>> + file_data = file_data.replace('covoar.css'
>>>>>>>>> covoar_css_path)
>>>>>>>>> >>> + with open(html_file, 'w') as f:
>>>>>>>>> >>> + f.write(file_data)
>>>>>>>>> >>> +class build_path_generator(object):
>>>>>>>>> >>> + Generates the build path from the path to executables
>>>>>>>>> >>> + def __init__(self, executables, target):
>>>>>>>>> >>> + self.executables = executables
>>>>>>>>> >>> + self.target = target
>>>>>>>>> >>> + def run(self):
>>>>>>>>> >>> + build_path = '/'
>>>>>>>>> >>> + Path = self.executables[0].split('/')
>>>>>>>>> >>> + for P in Path:
>>>>>>>>> >>> + if P == self.target:
>>>>>>>>> >>> + break;
>>>>>>>>> >>> + else:
>>>>>>>>> >>> + build_path = path.join(build_path, P)
>>>>>>>>> >>> + return build_path
>>>>>>>>> >>> +class symbol_parser(object):
>>>>>>>>> >>> + Parse the symbol sets ini and create custom ini file for
>>>>>>>>> covoar
>>>>>>>>> >>> + def __init__(self, symbol_config_path,
>>>>>>>>> >>> + symbol_select_path, coverage_arg, build_dir):
>>>>>>>>> >>> + self.symbol_select_file = symbol_select_path
>>>>>>>>> >>> + self.symbol_file = symbol_config_path
>>>>>>>>> >>> + self.symbol_sets = {}
>>>>>>>>> >>> + self.cov_arg = coverage_arg
>>>>>>>>> >>> + self.ssets = []
>>>>>>>>> >>> + def parse(self):
>>>>>>>>> >>> + config = configparser.ConfigParser()
>>>>>>>>> >>> + try:
>>>>>>>>> >>> + config.read(self.symbol_file)
>>>>>>>>> >>> + if self.cov_arg:
>>>>>>>>> >>> + self.ssets = self.cov_arg.split(',')
>>>>>>>>> >>> + else:
>>>>>>>>> >>> + self.ssets = config.get('symbol-sets',
>>>>>>>>> >>> 'sets').split(',')
>>>>>>>>> >>> + self.ssets = [ sset.encode('utf-8') for sset
>>>>>>>>> in
>>>>>>>>> >>> self.ssets]
>>>>>>>>> >>> + for sset in self.ssets:
>>>>>>>>> >>> + lib = path.join(self.build_dir,
>>>>>>>>> >>> + config.get('libraries', sset))
>>>>>>>>> >>> + self.symbol_sets[sset] = lib.encode('utf-8')
>>>>>>>>> >>> + except:
>>>>>>>>> >>> + raise error.general('Symbol set parsing failed')
>>>>>>>>> >>> + def _write_ini(self):
>>>>>>>>> >>> + try:
>>>>>>>>> >>> + sets = ', '.join(self.symbol_sets.keys())
>>>>>>>>> >>> + config.add_section('symbol-sets')
>>>>>>>>> >>> + config.set('symbol-sets', 'sets', sets)
>>>>>>>>> >>> + for key in self.symbol_sets.keys():
>>>>>>>>> >>> + config.add_section(key)
>>>>>>>>> >>> + config.set(key, 'libraries',
>>>>>>>>> self.symbol_sets[key])
>>>>>>>>> >>> + with open(self.symbol_select_file, 'w') as conf:
>>>>>>>>> >>> + config.write(conf)
>>>>>>>>> >>> + except:
>>>>>>>>> >>> + raise error.general('write failed')
>>>>>>>>> >>> + def run(self):
>>>>>>>>> >>> + self.parse()
>>>>>>>>> >>> + self._write_ini()
>>>>>>>>> >>> +class covoar(object):
>>>>>>>>> >>> + Covoar runner
>>>>>>>>> >>> + def __init__(self, base_result_dir, config_dir,
>>>>>>>>> executables,
>>>>>>>>> >>> explanations_txt):
>>>>>>>>> >>> + self.base_result_dir = base_result_dir
>>>>>>>>> >>> + self.config_dir = config_dir
>>>>>>>>> >>> + self.executables = ' '.join(executables)
>>>>>>>>> >>> + self.explanations_txt = explanations_txt
>>>>>>>>> >>> + self.project_name = 'RTEMS-5'
>>>>>>>>> >>> + def run(self, set_name, symbol_file):
>>>>>>>>> >>> + covoar_result_dir = path.join(self.base_result_dir,
>>>>>>>>> set_name)
>>>>>>>>> >>> + if (not path.exists(covoar_result_dir)):
>>>>>>>>> >>> + path.mkdir(covoar_result_dir)
>>>>>>>>> >>> + if (not path.exists(symbol_file)):
>>>>>>>>> >>> + raise error.general('symbol set file: coverage %s
>>>>>>>>> was not
>>>>>>>>> >>> created for covoar, skipping %s'% (symbol_file, set_name))
>>>>>>>>> >>> + command = ('covoar -S ' + symbol_file
>>>>>>>>> >>> + + ' -O ' + covoar_result_dir
>>>>>>>>> >>> + + ' -E ' + self.explanations_txt
>>>>>>>>> >>> + + ' -p ' + self.project_name + ' ' +
>>>>>>>>> self.executables)
>>>>>>>>> >>> + log.notice('Running covoar for %s' % (set_name))
>>>>>>>>> >>> + print( 'covoar results directory:\n' +
>>>>>>>>> covoar_result_dir )
>>>>>>>>> >>> + executor = execute.execute(verbose = True, output =
>>>>>>>>> >>> self.output_handler)
>>>>>>>>> >>> + exit_code = executor.shell(command, cwd=os.getcwd())
>>>>>>>>> >>> + if (exit_code[0] != 0):
>>>>>>>>> >>> + raise error.general('covoar failure exit code:
>>>>>>>>> %d' %
>>>>>>>>> >>> (exit_code[0]))
>>>>>>>>> >>> + log.notice('Coverage run for %s finished
>>>>>>>>> successfully.' %
>>>>>>>>> >>> (set_name))
>>>>>>>>> >>> + log.notice('------------------
>>>>>>>>> >>> + def output_handler(self, text):
>>>>>>>>> >>> + log.notice('%s' % (text))
>>>>>>>>> >>> +class coverage_run(object):
>>>>>>>>> >>> + Coverage analysis support for rtems-test
>>>>>>>>> >>> + def __init__(self, p_macros, coverage_arg, target):
>>>>>>>>> >>> + Constructor
>>>>>>>>> >>> + self.macros = p_macros
>>>>>>>>> >>> + self.build_dir = self.macros['_cwd']
>>>>>>>>> >>> self.macros.expand(self.macros['cov_explanations'])
>>>>>>>>> >>> + self.test_dir = path.join(self.build_dir, 'coverage')
>>>>>>>>> >>> + if (not path.exists(self.test_dir)):
>>>>>>>>> >>> + path.mkdir(self.test_dir)
>>>>>>>>> >>> + self.rtdir = path.abspath(self.macros['_rtdir'])
>>>>>>>>> >>> + self.rtscripts = self.macros.expand(self.macros
>>>>>>>>> ['_rtscripts'])
>>>>>>>>> >>> + self.coverage_config_path = path.join(self.rtscripts,
>>>>>>>>> >>> 'coverage')
>>>>>>>>> >>> + self.symbol_config_path =
>>>>>>>>> path.join(self.coverage_config_path,
>>>>>>>>> >>> + 'symbol-sets.ini')
>>>>>>>>> >>> + self.symbol_select_path =
>>>>>>>>> 'symbol-select.ini')
>>>>>>>>> >>> + self.executables = None
>>>>>>>>> >>> + self.symbol_sets = []
>>>>>>>>> >>> + self.no_clean = int(self.macros['_no_clean'])
>>>>>>>>> >>> + self.report_format = self.macros['cov_report_format']
>>>>>>>>> >>> + self.coverage_arg = coverage_arg
>>>>>>>>> >>> + def run(self):
>>>>>>>>> >>> + try:
>>>>>>>>> >>> + if self.executables is None:
>>>>>>>>> >>> + raise error.general('no test executables
>>>>>>>>> provided.')
>>>>>>>>> >>> + build_dir = build_path_generator(self.exec
>>>>>>>>> utables,
>>>>>>>>> >>> self.target).run()
>>>>>>>>> >>> + parser = symbol_parser(self.symbol_config_path,
>>>>>>>>> >>> + self.symbol_select_path,
>>>>>>>>> >>> + self.coverage_arg,
>>>>>>>>> >>> + build_dir)
>>>>>>>>> >>> + parser.run()
>>>>>>>>> >>> + covoar_runner = covoar(self.test_dir,
>>>>>>>>> >>> + self.executables,
>>>>>>>>> >>> self.explanations_txt)
>>>>>>>>> >>> + covoar_runner.run('score',
>>>>>>>>> self.symbol_select_path)
>>>>>>>>> >>> + self._generate_reports();
>>>>>>>>> >>> + self._summarize();
>>>>>>>>> >>> + finally:
>>>>>>>>> >>> + self._cleanup();
>>>>>>>>> >>> + def _generate_reports(self):
>>>>>>>>> >>> + log.notice('Generating reports')
>>>>>>>>> >>> + if self.report_format == 'html':
>>>>>>>>> >>> + report = report_gen_html(self.symbol_sets,
>>>>>>>>> >>> + self.build_dir,
>>>>>>>>> >>> + self.rtdir)
>>>>>>>>> >>> + report.generate()
>>>>>>>>> >>> + report.add_covoar_src_path()
>>>>>>>>> >>> + def _cleanup(self):
>>>>>>>>> >>> + if not self.no_clean:
>>>>>>>>> >>> + log.notice('***Cleaning tempfiles***')
>>>>>>>>> >>> + for exe in self.executables:
>>>>>>>>> >>> + trace_file = exe + '.cov'
>>>>>>>>> >>> + if path.exists(trace_file):
>>>>>>>>> >>> + os.remove(trace_file)
>>>>>>>>> >>> + def _summarize(self):
>>>>>>>>> >>> + log.notice('Coverage analysis finished. You can find
>>>>>>>>> results in
>>>>>>>>> >>> %s' % (self.build_dir))
>>>>>>>>> >>> diff --git a/tester/rt/test.py b/tester/rt/test.py
>>>>>>>>> >>> index f4d9b5c..84dff01 100644
>>>>>>>>> >>> --- a/tester/rt/test.py
>>>>>>>>> >>> +++ b/tester/rt/test.py
>>>>>>>>> >>> @@ -48,12 +48,14 @@ from rtemstoolkit import mailer
>>>>>>>>> >>> from rtemstoolkit import reraise
>>>>>>>>> >>> from rtemstoolkit import stacktraces
>>>>>>>>> >>> from rtemstoolkit import version
>>>>>>>>> >>> +from rtemstoolkit import check
>>>>>>>>> >>> from . import bsps
>>>>>>>>> >>> from . import config
>>>>>>>>> >>> from . import console
>>>>>>>>> >>> from . import report
>>>>>>>>> >>> +from . import coverage
>>>>>>>>> >>> class log_capture(object):
>>>>>>>>> >>> def __init__(self):
>>>>>>>>> >>> @@ -147,7 +149,7 @@ class test_run(object):
>>>>>>>>> >>> def run(self):
>>>>>>>>> >>> self.thread = threading.Thread(target = self.runner,
>>>>>>>>> >>> - name = 'test[%s]' %
>>>>>>>>> >>> path.basename(self.executable))
>>>>>>>>> >>> + name = 'test[%s]' %
>>>>>>>>> >>> self.thread.start()
>>>>>>>>> >>> def is_alive(self):
>>>>>>>>> >>> @@ -214,6 +216,10 @@ def killall(tests):
>>>>>>>>> >>> for test in tests:
>>>>>>>>> >>> test.kill()
>>>>>>>>> >>> +def coverage_run(opts, coverage, executables):
>>>>>>>>> >>> + coverage.executables = executables
>>>>>>>>> >>> + coverage.run()
>>>>>>>>> >>> def run(command_path = None):
>>>>>>>>> >>> import sys
>>>>>>>>> >>> tests = []
>>>>>>>>> >>> @@ -221,15 +227,16 @@ def run(command_path = None):
>>>>>>>>> >>> opts = None
>>>>>>>>> >>> default_exefilter = '*.exe'
>>>>>>>>> >>> try:
>>>>>>>>> >>> - optargs = { '--rtems-tools': 'The path to the RTEMS
>>>>>>>>> tools',
>>>>>>>>> >>> - '--rtems-bsp': 'The RTEMS BSP to run
>>>>>>>>> the test on',
>>>>>>>>> >>> - '--user-config': 'Path to your local user
>>>>>>>>> >>> configuration INI file',
>>>>>>>>> >>> - '--report-mode': 'Reporting modes,
>>>>>>>>> failures
>>>>>>>>> >>> (default),all,none',
>>>>>>>>> >>> - '--list-bsps': 'List the supported
>>>>>>>>> BSPs',
>>>>>>>>> >>> - '--debug-trace': 'Debug trace based on
>>>>>>>>> specific
>>>>>>>>> >>> flags',
>>>>>>>>> >>> - '--filter': 'Glob that executables
>>>>>>>>> must match
>>>>>>>>> >>> to run (default: ' +
>>>>>>>>> >>> + optargs = { '--rtems-tools': 'The path to the
>>>>>>>>> RTEMS tools',
>>>>>>>>> >>> + '--rtems-bsp': 'The RTEMS BSP to run
>>>>>>>>> the test
>>>>>>>>> >>> on',
>>>>>>>>> >>> + '--user-config': 'Path to your local
>>>>>>>>> user
>>>>>>>>> >>> + '--report-mode': 'Reporting modes,
>>>>>>>>> failures
>>>>>>>>> >>> + '--list-bsps': 'List the supported
>>>>>>>>> BSPs',
>>>>>>>>> >>> + '--debug-trace': 'Debug trace based on
>>>>>>>>> specific
>>>>>>>>> >>> flags',
>>>>>>>>> >>> + '--filter': 'Glob that
>>>>>>>>> executables must
>>>>>>>>> >>> match to run (default: ' +
>>>>>>>>> >>> default_exefilter + ')',
>>>>>>>>> >>> - '--stacktrace': 'Dump a stack trace on a
>>>>>>>>> user
>>>>>>>>> >>> termination (^C)' }
>>>>>>>>> >>> + '--stacktrace': 'Dump a stack trace
>>>>>>>>> on a user
>>>>>>>>> >>> termination (^C)',
>>>>>>>>> >>> + '--coverage': 'Perform coverage
>>>>>>>>> analysis of
>>>>>>>>> >>> test executables.'}
>>>>>>>>> >>> mailer.append_options(optargs)
>>>>>>>>> >>> opts = options.load(sys.argv,
>>>>>>>>> >>> optargs = optargs,
>>>>>>>>> >>> @@ -279,6 +286,15 @@ def run(command_path = None):
>>>>>>>>> >>> raise error.general('RTEMS BSP not provided or an
>>>>>>>>> invalid
>>>>>>>>> >>> option')
>>>>>>>>> >>> bsp = config.load(bsp[1], opts)
>>>>>>>>> >>> bsp_config = opts.defaults.expand(opts.defa
>>>>>>>>> ults['tester'])
>>>>>>>>> >>> + coverage_enabled = opts.find_arg('--coverage')
>>>>>>>>> >>> + if coverage_enabled:
>>>>>>>>> >>> + if len(coverage_enabled) == 2:
>>>>>>>>> >> Is this to check if sets have been provided to
>>>>>>>>> --coverage=score,sapi, that
>>>>>>>>> >> kind of thing? If so the variable name coverage_enabled doesn't
>>>>>>>>> make sense
>>>>>>>>> >> any more. Probably if symbol_sets and if len(symbol_sets) will
>>>>>>>>> make more
>>>>>>>>> >> sense for both cases.
>>>>>>>>> > That's a good point.
>>>>>>>>> > How about changing it to just 'coverage' instead ?
>>>>>>>>> > Because it's still checking whether the option is given or
>>>>>>>>> > not. symbol_sets might create confusion.
>>>>>>>>> > Will that be OK ?
>>>>>>>>> That name might collide with your class object (coverage)?
>>>>>>>> That's actually why I kept it as coverage_enabled.
>>>>>>>> I think we can go for coverage_option (?)
>>>>>>>>> >>> + coverage_runner =
>>>>>>>>> coverage.coverage_run(opts.defaults,
>>>>>>>>> coverage_enabled[1],
>>>>>>>>> opts.defaults['target'])
>>>>>>>>> >>> + else:
>>>>>>>>> >>> + coverage_runner =
>>>>>>>>> >>> 0,
>>>>>>>>> >>> report_mode = opts.find_arg('--report-mode')
>>>>>>>>> >>> if report_mode:
>>>>>>>>> >>> if report_mode[1] != 'failures' and \
>>>>>>>>> >>> @@ -365,6 +381,8 @@ def run(command_path = None):
>>>>>>>>> >>> reports.failures(),
>>>>>>>>> >>> 'Log', '===', ''] + output.get()
>>>>>>>>> >>> mail.send(to_addr, subject, os.linesep.join(body))
>>>>>>>>> >>> + coverage_run(opts, coverage_runner, executables)
>>>>>>>>> >>> except error.general as gerr:
>>>>>>>>> >>> print(gerr)
>>>>>>>>> >>> diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>>>>> >>> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>>>>> >>> index 6b5e7e6..2f89117 100644
>>>>>>>>> >>> --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>>>>> >>> +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>>>>> >>> @@ -31,9 +31,10 @@
>>>>>>>>> >>> # The Leon 3 QEMU BSP
>>>>>>>>> >>> -[leon3-qemu]
>>>>>>>>> >>> +[leon3-qemu-cov]
>>>>>>>>> >>> bsp = leon3-qemu
>>>>>>>>> >>> arch = sparc
>>>>>>>>> >>> +target = sparc-rtems5
>>>>>>>>> >>> tester = %{_rtscripts}/qemu.cfg
>>>>>>>>> >>> bsp_qemu_opts = %{qemu_opts_base} -M leon3_generic
>>>>>>>>> >>> bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
>>>>>>>>> >>> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
>>>>>>>>> >>> b/tester/rtems/testing/coverage/symbol-sets.ini
>>>>>>>>> >>> index 0000000..a2ec7bc
>>>>>>>>> >>> --- /dev/null
>>>>>>>>> >>> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
>>>>>>>>> >>> @@ -0,0 +1,36 @@
>>>>>>>>> >>> +# Copyright 2018 Chris Johns (chrisj at rtems.org)
>>>>>>>>> 'rtems-tools'.
>>>>>>>>> without
>>>>>>>>> conditions are
>>>>>>>>> >>> met:
>>>>>>>>> copyright
>>>>>>>>> >>> notice,
>>>>>>>>> copyright
>>>>>>>>> >>> notice,
>>>>>>>>> >>> documentation
>>>>>>>>> CONTRIBUTORS
>>>>>>>>> >>> "AS IS"
>>>>>>>>> LIMITED TO,
>>>>>>>>> >>> THE
>>>>>>>>> PARTICULAR
>>>>>>>>> >>> PURPOSE
>>>>>>>>> CONTRIBUTORS
>>>>>>>>> >>> BE
>>>>>>>>> EXEMPLARY, OR
>>>>>>>>> PROCUREMENT OF
>>>>>>>>> PROFITS; OR
>>>>>>>>> >>> BUSINESS
>>>>>>>>> LIABILITY, WHETHER
>>>>>>>>> >>> IN
>>>>>>>>> >>> OTHERWISE)
>>>>>>>>> ADVISED OF
>>>>>>>>> >>> THE
>>>>>>>>> >>> +[symbol-sets]
>>>>>>>>> >>> +sets = score,rtems
>>>>>>>>> >>> +[libraries]
>>>>>>>>> >>> +score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>>>>>>>>> >>> +rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>>>>>>>>> >>> diff --git a/tester/rtems/testing/qemu.cfg
>>>>>>>>> >>> b/tester/rtems/testing/qemu.cfg
>>>>>>>>> >>> index bfcd2f5..52a3752 100644
>>>>>>>>> >>> --- a/tester/rtems/testing/qemu.cfg
>>>>>>>>> >>> +++ b/tester/rtems/testing/qemu.cfg
>>>>>>>>> >>> @@ -51,8 +51,8 @@
>>>>>>>>> >>> # Qemu common option patterns.
>>>>>>>>> >>> -#%define qemu_opts_base -no-reboot -monitor none -serial
>>>>>>>>> stdio
>>>>>>>>> >>> -nographic
>>>>>>>>> >>> -%define qemu_opts_base -no-reboot -serial null -serial
>>>>>>>>> mon:stdio
>>>>>>>>> >>> -nographic
>>>>>>>>> >>> +%define qemu_opts_base -no-reboot -monitor none -serial
>>>>>>>>> stdio
>>>>>>>>> >>> -nographic
>>>>>>>>> >>> +#%define qemu_opts_base -no-reboot -serial null -serial
>>>>>>>>> mon:stdio
>>>>>>>>> >>> -nographic
>>>>>>>>> >>> %define qemu_opts_no_net -net none
>>>>>>>>> >>> 2.14.3
>>>>>>>>> >>> _______________________________________________
>>>>>>>>> >>> devel mailing list
>>>>>>>>> >>> devel at rtems.org
>>>>>>>>> >>> http://lists.rtems.org/mailman/listinfo/devel
>>>>>>>>> > devel mailing list
>>>>>>>>> > devel at rtems.org
>>> devel mailing list
>>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180531/2b6ad018/attachment-0001.html>
