[PATCH 2/4] covoar: Use DWARF to map addresses to source files and lines.
Cillian O'Donnell
cpodonnell8 at gmail.com
Sat May 5 20:55:55 UTC 2018
On 5 May 2018 at 21:12, Chris Johns <chrisj at rtems.org> wrote:
> > On 6 May 2018, at 2:44 am, Joel Sherrill <joel at rtems.org> wrote:
> > Looks similar to Cillian's failure. Chris will have to show me where
> libdwarf comes from. It needs to be supplied with RTEMS tools for
> consistency.
> You need to apply the patches against master. I added libdwarf to master
> the other day.
That is applied to current master. I can see that libdwarf patch in the log
but it still has that problem.
> Host packages are not used.
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180505/3bdafecb/attachment-0002.html>
