[PATCH 2/4] covoar: Use DWARF to map addresses to source files and lines.
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sat May 5 21:04:02 UTC 2018
On 6 May 2018 at 02:25, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
> On 5 May 2018 at 21:12, Chris Johns <chrisj at rtems.org> wrote:
>> > On 6 May 2018, at 2:44 am, Joel Sherrill <joel at rtems.org> wrote:
>> > Looks similar to Cillian's failure. Chris will have to show me where
>> libdwarf comes from. It needs to be supplied with RTEMS tools for
>> consistency.
>> You need to apply the patches against master. I added libdwarf to master
>> the other day.
> That is applied to current master. I can see that libdwarf patch in the
> log but it still has that
same here.
problem.
>> Host packages are not used.
>> Chris
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180506/f42e495b/attachment-0002.html>
