[PATCH 2/4] covoar: Use DWARF to map addresses to source files and lines.
Sat May 5 21:35:02 UTC 2018
> On 6 May 2018, at 7:04 am, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com> wrote:
>> On 6 May 2018 at 02:25, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
>>> On 5 May 2018 at 21:12, Chris Johns <chrisj at rtems.org> wrote:
>>> > On 6 May 2018, at 2:44 am, Joel Sherrill <joel at rtems.org> wrote:
>>> > Looks similar to Cillian's failure. Chris will have to show me where libdwarf comes from. It needs to be supplied with RTEMS tools for consistency.
>>> You need to apply the patches against master. I added libdwarf to master the other day.
>> That is applied to current master. I can see that libdwarf patch in the log but it still has that
> same here.
Thank you for the fast response.
Do you think a host version is being picked up before the rtemtoolkit one?
Could you please check covoar’s wscript has the libdwarf path added?
Also check waf with -v.
Thanks
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180506/dd71653c/attachment-0002.html>
