How to download the required tar file?
Danxue Huang danxue.huang at gmail.com
Fri May 11 17:03:13 UTC 2018
Chris,
I have managed to build the tools, but I got another question about
testing. I am supposed to have a "testsuites" folder in my machine from the
instruction but I did not find it. So I make a "test.exe" file by myself,
the output of running "test.exe" is as below.
dannie at dannie-VirtualBox:~/development/rtems/4.11/sparc-rtems4.11$
sparc-rtems4.11-gdb test.exe
GNU gdb (GDB) 7.9
Copyright (C) 2015 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "--host=x86_64-linux-gnu
--target=sparc-rtems4.11".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
"/home/dannie/development/rtems/4.11/sparc-rtems4.11/test.exe": not in
executable format: File format not recognized
(gdb) tar sim
Connected to the simulator.
(gdb) load
No executable file specified.
Use the "file" or "exec-file" command.
(gdb) r
Starting program:
warning: No executable file specified.
warning: No program loaded.
[Inferior 1 (process 42000) exited normally]
(gdb) quit
Now I think the gdb session is working, but the "test.exe" is not
executable since it is coded by myself (there are bugs in it). Is there any
way I can get the testing files?
Thank you so much!
-Dannie
On Fri, May 11, 2018 at 12:07 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 11/5/18 4:01 pm, Danxue Huang wrote:
> > Hi there,
> > I got stuck on 2.5 installing a tar file ( I have attached the website
> below).
> You can skip that section. It does not really belong in the Quick Start
> chapter.
> > https://docs.rtems.org/branches/master/rsb/quick-start.html#building
> > <https://docs.rtems.org/branches/master/rsb/quick-start.html#building>
> > The tar file is supposed that I have downloaded in my machine, but there
> is not
> > a required .bz2 file "rtems-4.11-sparc-rtems4.11-1.tar.bz2", all my
> files ends
> > at .bz2 are as below.
> > ./development/rtems/src/rtems-source-builder/rtems/sources/
> gmp-5.0.5.tar.bz2
> binutils-2.26.tar.bz2
> > ./development/rtems/src/rtems-source-builder/rtems/sources/rtems-tools-
> 25863503edb513e7501481ff2074c02bf219f519.tar.bz2
> binutils-2.30.tar.bz2
> gmp-6.1.0.tar.bz2
> gcc-4.9.3.tar.bz2
> mpfr-3.0.1.tar.bz2
> mpfr-3.1.4.tar.bz2
> > Is there any other way I can download the required tar file? Thank you!
> You should not needed it.
> Have you managed to build the tools?
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180511/89007104/attachment-0002.html>
