How to download the required tar file?
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Fri May 11 17:57:03 UTC 2018
Hello Dannie,
I guess you're looking for the testsuites direcotry under the build
directory.
It can be found somewhere like this
$HOME/development/rtems/kernel/erc32/sparc-rtems5/c/erc32/testsuites
If you're looking for the c code then you can find it under the RTEMS_ROOT
directory.
In my set up the root directory is here:
$HOME/development/rtems/kernel/rtems/testsuites
You can refer to this link to understand the directory structure properly .
https://docs.rtems.org/branches/master/develenv/directory.html
Hopefully it was helpful.
regards,
Vijay
PS: Apologies to Chris, if it was disrespectful to respond to a question
that was addressed to him. I certainly didn't mean any disrespect.
On 11 May 2018 at 22:33, Danxue Huang <danxue.huang at gmail.com> wrote:
> Chris,
> I have managed to build the tools, but I got another question about
> testing. I am supposed to have a "testsuites" folder in my machine from the
> instruction but I did not find it. So I make a "test.exe" file by myself,
> the output of running "test.exe" is as below.
> dannie at dannie-VirtualBox:~/development/rtems/4.11/sparc-rtems4.11$
> sparc-rtems4.11-gdb test.exe
> GNU gdb (GDB) 7.9
> Copyright (C) 2015 Free Software Foundation, Inc.
> License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.h
> tml>
> This is free software: you are free to change and redistribute it.
> There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
> and "show warranty" for details.
> This GDB was configured as "--host=x86_64-linux-gnu
> --target=sparc-rtems4.11".
> Type "show configuration" for configuration details.
> For bug reporting instructions, please see:
> <http://www.gnu.org/software/gdb/bugs/>.
> Find the GDB manual and other documentation resources online at:
> <http://www.gnu.org/software/gdb/documentation/>.
> For help, type "help".
> Type "apropos word" to search for commands related to "word"...
> "/home/dannie/development/rtems/4.11/sparc-rtems4.11/test.exe": not in
> executable format: File format not recognized
> (gdb) tar sim
> Connected to the simulator.
> (gdb) load
> No executable file specified.
> Use the "file" or "exec-file" command.
> (gdb) r
> Starting program:
> warning: No executable file specified.
> warning: No program loaded.
> [Inferior 1 (process 42000) exited normally]
> (gdb) quit
> Now I think the gdb session is working, but the "test.exe" is not
> executable since it is coded by myself (there are bugs in it). Is there any
> way I can get the testing files?
> Thank you so much!
> -Dannie
> On Fri, May 11, 2018 at 12:07 AM, Chris Johns <chrisj at rtems.org> wrote:
>> On 11/5/18 4:01 pm, Danxue Huang wrote:
>> > Hi there,
>> > I got stuck on 2.5 installing a tar file ( I have attached the website
>> below).
>> You can skip that section. It does not really belong in the Quick Start
>> chapter.
>> > https://docs.rtems.org/branches/master/rsb/quick-start.html#building
>> > <https://docs.rtems.org/branches/master/rsb/quick-start.html#building>
>> > The tar file is supposed that I have downloaded in my machine, but
>> there is not
>> > a required .bz2 file "rtems-4.11-sparc-rtems4.11-1.tar.bz2", all my
>> files ends
>> > at .bz2 are as below.
>> > ./development/rtems/src/rtems-source-builder/rtems/sources/g
>> mp-5.0.5.tar.bz2
>> > ./development/rtems/src/rtems-source-builder/rtems/sources/b
>> inutils-2.26.tar.bz2
>> > ./development/rtems/src/rtems-source-builder/rtems/sources/r
>> tems-tools-25863503edb513e7501481ff2074c02bf219f519.tar.bz2
>> inutils-2.30.tar.bz2
>> mp-6.1.0.tar.bz2
>> cc-4.9.3.tar.bz2
>> > ./development/rtems/src/rtems-source-builder/rtems/sources/m
>> pfr-3.0.1.tar.bz2
>> pfr-3.1.4.tar.bz2
>> > Is there any other way I can download the required tar file? Thank you!
>> You should not needed it.
>> Have you managed to build the tools?
>> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180511/653b3968/attachment-0002.html>
