[PATCH] covoar: fixing the extension mismatch in trace file
Sat May 12 21:28:40 UTC 2018
On Sat, May 12, 2018 at 2:42 PM, thelunatic <vijaykumar9597 at gmail.com>
wrote:
Every patch needs an explanation/log message.  Look back through
"git log" for examples.
>  tester/covoar/covoar.cc | 7 ++++---
>  1 file changed, 4 insertions(+), 3 deletions(-)
> diff --git a/tester/covoar/covoar.cc b/tester/covoar/covoar.cc
> index 5bed98f..95dc990 100644
> --- a/tester/covoar/covoar.cc
> +++ b/tester/covoar/covoar.cc
> @@ -185,7 +185,7 @@ int main(
>    Executables                   executablesToAnalyze;
>    Coverage::ExecutableInfo*     executableInfo = NULL;
>    std::string                   executableExtension = "exe";
> -  std::string                   coverageExtension = "cov";
> +  std::string                   coverageExtension = ".cov";
Why did this need a "." but the "exe" one didn't?
>    Coverage::CoverageFormats_t   coverageFormat =
> Coverage::COVERAGE_FORMAT_QEMU;
>    Coverage::CoverageReaderBase* coverageReader = NULL;
>    char*                         executable = NULL;
> @@ -317,11 +317,12 @@ int main(
>          std::cerr << "warning: Unable to read executable: " << argv[i] <<
> std::endl;
>        } else {
>          coverageFileName = argv[i];
> -        coverageFileName.replace(
> +       coverageFileName.append(coverageExtension);
> +     /* coverageFileName.replace(
>            coverageFileName.length() - executableExtension.size(),
>            coverageExtension
If you are replacing this call, then just delete it -- don't comment it out.
>          if (!FileIsReadable( coverageFileName.c_str() )) {
>            std::cerr << "warning: Unable to read coverage file: " <<
> coverageFileName
> 2.14.3
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180512/aabb2c3b/attachment-0002.html>
