[PATCH 2/2] sparc64 niagara, usiii: Remove -D options from cfg file and move to bspopts.h
Mon May 14 20:33:28 UTC 2018
I haven't tested this but what do you think of this?
-RTEMS_BSPOPTS_SET([US3],[usiii],[1])
-RTEMS_BSPOPTS_SET([US3],[*],[])
-RTEMS_BSPOPTS_HELP([US3],
-[If defined, enable UltraSPARC optons for the USIII BSP.])
-RTEMS_BSPOPTS_SET([SUN4U],[usiii],[1])
-RTEMS_BSPOPTS_SET([SUN4U],[*],[])
-RTEMS_BSPOPTS_HELP([SUN4U],
-[If defined, enable SUN model optons for the USIII BSP.])
+AC_DEFINE(US3, 1, [UltraSPARC model option])
+AC_DEFINE(SUN4U, 1, [SUN model option])
On Sun, May 13, 2018 at 11:16 AM, Joel Sherrill <joel at rtems.org> wrote:
> On Sun, May 13, 2018, 10:20 AM Gedare Bloom <gedare at rtems.org> wrote:
>> On Wed, May 9, 2018 at 4:23 PM, Joel Sherrill <joel at rtems.org> wrote:
>> > Updates #3425.
>> >  bsps/sparc64/include/arch/arch.h              |  4 ++++
>> >  bsps/sparc64/include/arch/mm/frame.h          |  4 ++++
>> >  bsps/sparc64/include/arch/mm/mmu.h            |  4 ++++
>> >  bsps/sparc64/include/arch/mm/tlb.h            |  3 +++
>> >  bsps/sparc64/include/arch/mm/tte.h            |  4 ++++
>> >  bsps/sparc64/niagara/config/niagara.cfg       |  2 +-
>> >  bsps/sparc64/usiii/config/usiii.cfg           |  2 +-
>> >  c/src/lib/libbsp/sparc64/niagara/configure.ac |  4 ++++
>> >  c/src/lib/libbsp/sparc64/usiii/configure.ac   | 10 +++++++++-
>> >  9 files changed, 34 insertions(+), 3 deletions(-)
>> > diff --git a/bsps/sparc64/include/arch/arch.h
>> b/bsps/sparc64/include/arch/arch.h
>> > index 5fdd4a2..36aa922 100644
>> > --- a/bsps/sparc64/include/arch/arch.h
>> > +++ b/bsps/sparc64/include/arch/arch.h
>> > @@ -37,10 +37,14 @@
>> >  #ifndef KERN_sparc64_ARCH_H_
>> >  #define KERN_sparc64_ARCH_H_
>> > +#include <bspopts.h>
>> >  #if defined (SUN4U)
>> >  #include <arch/sun4u/arch.h>
>> >  #elif defined (SUN4V)
>> >  #include <arch/sun4v/arch.h>
>> > +#else
>> > +#error "No SUN model defined"
>> >  #endif
>> >  #define ASI_AIUP               0x10    /** Access to primary context
>> with user privileges. */
>> > diff --git a/bsps/sparc64/include/arch/mm/frame.h
>> b/bsps/sparc64/include/arch/mm/frame.h
>> > index fb66e54..2fc17cc 100644
>> > --- a/bsps/sparc64/include/arch/mm/frame.h
>> > +++ b/bsps/sparc64/include/arch/mm/frame.h
>> > @@ -35,10 +35,14 @@
>> >  #ifndef KERN_sparc64_FRAME_H_
>> >  #define KERN_sparc64_FRAME_H_
>> >  #if defined (SUN4U)
>> >  #include <arch/mm/sun4u/frame.h>
>> >  #include <arch/mm/sun4v/frame.h>
>> > +#else
>> >  #endif
>> >  #endif
>> > diff --git a/bsps/sparc64/include/arch/mm/mmu.h
>> b/bsps/sparc64/include/arch/mm/mmu.h
>> > index 1d445f2..aab143f 100644
>> > --- a/bsps/sparc64/include/arch/mm/mmu.h
>> > +++ b/bsps/sparc64/include/arch/mm/mmu.h
>> > @@ -35,10 +35,14 @@
>> >  #ifndef KERN_sparc64_MMU_H_
>> >  #define KERN_sparc64_MMU_H_
>> >  #if defined (SUN4U)
>> >  #include <arch/mm/sun4u/mmu.h>
>> >  #include <arch/mm/sun4v/mmu.h>
>> > +#else
>> >  #endif
>> > diff --git a/bsps/sparc64/include/arch/mm/tlb.h
>> b/bsps/sparc64/include/arch/mm/tlb.h
>> > index 4adf26c..7a6b85d 100644
>> > --- a/bsps/sparc64/include/arch/mm/tlb.h
>> > +++ b/bsps/sparc64/include/arch/mm/tlb.h
>> > @@ -35,11 +35,14 @@
>> >  #ifndef KERN_sparc64_TLB_H_
>> >  #define KERN_sparc64_TLB_H_
>> >  #if defined (SUN4U)
>> >  #include <arch/mm/sun4u/tlb.h>
>> >  #include <arch/mm/sun4v/tlb.h>
>> > +#else
>> >  #endif
>> >  #endif
>> > diff --git a/bsps/sparc64/include/arch/mm/tte.h
>> b/bsps/sparc64/include/arch/mm/tte.h
>> > index f0b746e..10a672b 100644
>> > --- a/bsps/sparc64/include/arch/mm/tte.h
>> > +++ b/bsps/sparc64/include/arch/mm/tte.h
>> > @@ -35,10 +35,14 @@
>> >  #ifndef KERN_sparc64_TTE_H_
>> >  #define KERN_sparc64_TTE_H_
>> >  #if defined (SUN4U)
>> >  #include <arch/mm/sun4u/tte.h>
>> >  #include <arch/mm/sun4v/tte.h>
>> > +#else
>> >  #endif
>> >  #endif
>> > diff --git a/bsps/sparc64/niagara/config/niagara.cfg
>> b/bsps/sparc64/niagara/config/niagara.cfg
>> > index 2fd8973..bfa73aa 100644
>> > --- a/bsps/sparc64/niagara/config/niagara.cfg
>> > +++ b/bsps/sparc64/niagara/config/niagara.cfg
>> > @@ -7,7 +7,7 @@ RTEMS_CPU=sparc64
>> >  #  This contains the compiler options necessary to select the CPU model
>> >  #  and (hopefully) optimize for it.
>> > -CPU_CFLAGS = -mcpu=niagara -DSUN4V
>> > +CPU_CFLAGS = -mcpu=niagara
>> >  # optimize flag: typically -g -O2
>> >  CFLAGS_OPTIMIZE_V = -g -O2
>> > diff --git a/bsps/sparc64/usiii/config/usiii.cfg
>> b/bsps/sparc64/usiii/config/usiii.cfg
>> > index b9fad21..ee1c508 100644
>> > --- a/bsps/sparc64/usiii/config/usiii.cfg
>> > +++ b/bsps/sparc64/usiii/config/usiii.cfg
>> > -CPU_CFLAGS = -mcpu=ultrasparc3 -DUS3 -DSUN4U
>> > +CPU_CFLAGS = -mcpu=ultrasparc3
>> > diff --git a/c/src/lib/libbsp/sparc64/niagara/configure.ac
>> b/c/src/lib/libbsp/sparc64/niagara/configure.ac
>> > index ced7e12..f8e9687 100644
>> > --- a/c/src/lib/libbsp/sparc64/niagara/configure.ac
>> > +++ b/c/src/lib/libbsp/sparc64/niagara/configure.ac
>> > @@ -10,6 +10,10 @@ RTEMS_CANONICAL_TARGET_CPU
>> >  AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
>> >  RTEMS_BSP_CONFIGURE
>> > +RTEMS_BSPOPTS_SET([SUN4V],[niagara],[1])
>> > +RTEMS_BSPOPTS_SET([SUN4V],[*],[])
>> > +RTEMS_BSPOPTS_HELP([SUN4V],
>> > +[If defined, enable SUN model optons for the Niagara model.])
>> >  RTEMS_BSP_CLEANUP_OPTIONS
>> > diff --git a/c/src/lib/libbsp/sparc64/usiii/configure.ac
>> b/c/src/lib/libbsp/sparc64/usiii/configure.ac
>> > index 4244055..c99d938 100644
>> > --- a/c/src/lib/libbsp/sparc64/usiii/configure.ac
>> > +++ b/c/src/lib/libbsp/sparc64/usiii/configure.ac
>> > @@ -10,13 +10,21 @@ RTEMS_CANONICAL_TARGET_CPU
>> >  RTEMS_BSP_CONFIGURE
>> >  RTEMS_BSPOPTS_SET([SIMSPARC_FAST_IDLE],[*],[])
>> >  RTEMS_BSPOPTS_HELP([SIMSPARC_FAST_IDLE],
>> >  [If defined, speed up the clock ticks while the idle task is running so
>> >  time spent in the idle task is minimized.  This significantly reduces
>> >  the wall time required to execute the RTEMS test suites.])
>> > +RTEMS_BSPOPTS_SET([US3],[usiii],[1])
>> > +RTEMS_BSPOPTS_SET([US3],[*],[])
>> > +RTEMS_BSPOPTS_HELP([US3],
>> > +[If defined, enable UltraSPARC optons for the USIII BSP.])
>> > +RTEMS_BSPOPTS_SET([SUN4U],[usiii],[1])
>> > +RTEMS_BSPOPTS_SET([SUN4U],[*],[])
>> > +RTEMS_BSPOPTS_HELP([SUN4U],
>> > +[If defined, enable SUN model optons for the USIII BSP.])
>> These are not really "optional" defines. It doesn't make sense for
>> example to compile an ultrasparc3 BSP without the SUN4U define. I
>> don't really know if this matters.
> Feel free to change it to whatever autoconf magic forces the setting
> without providing an override option.
>> > 1.8.3.1
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180514/49e128df/attachment-0002.html>
