[PATCH 2/2] sparc64 niagara, usiii: Remove -D options from cfg file and move to bspopts.h
    Gedare Bloom
    gedare at rtems.org
    Tue May 15 12:59:25 UTC 2018
I have no problem with it, but it must be tested :) Just a
compile-only check is fine.
On Mon, May 14, 2018 at 4:33 PM, Joel Sherrill <joel at rtems.org> wrote:
> I haven't tested this but what do you think of this?
> -RTEMS_BSPOPTS_SET([US3],[usiii],[1])
> -RTEMS_BSPOPTS_SET([US3],[*],[])
> -RTEMS_BSPOPTS_HELP([US3],
> -[If defined, enable UltraSPARC optons for the USIII BSP.])
> -RTEMS_BSPOPTS_SET([SUN4U],[usiii],[1])
> -RTEMS_BSPOPTS_SET([SUN4U],[*],[])
> -RTEMS_BSPOPTS_HELP([SUN4U],
> -[If defined, enable SUN model optons for the USIII BSP.])
> +AC_DEFINE(US3, 1, [UltraSPARC model option])
> +AC_DEFINE(SUN4U, 1, [SUN model option])
> On Sun, May 13, 2018 at 11:16 AM, Joel Sherrill <joel at rtems.org> wrote:
>> On Sun, May 13, 2018, 10:20 AM Gedare Bloom <gedare at rtems.org> wrote:
>>> On Wed, May 9, 2018 at 4:23 PM, Joel Sherrill <joel at rtems.org> wrote:
>>> > Updates #3425.
>>> >  bsps/sparc64/include/arch/arch.h              |  4 ++++
>>> >  bsps/sparc64/include/arch/mm/frame.h          |  4 ++++
>>> >  bsps/sparc64/include/arch/mm/mmu.h            |  4 ++++
>>> >  bsps/sparc64/include/arch/mm/tlb.h            |  3 +++
>>> >  bsps/sparc64/include/arch/mm/tte.h            |  4 ++++
>>> >  bsps/sparc64/niagara/config/niagara.cfg       |  2 +-
>>> >  bsps/sparc64/usiii/config/usiii.cfg           |  2 +-
>>> >  c/src/lib/libbsp/sparc64/niagara/configure.ac |  4 ++++
>>> >  c/src/lib/libbsp/sparc64/usiii/configure.ac   | 10 +++++++++-
>>> >  9 files changed, 34 insertions(+), 3 deletions(-)
>>> > diff --git a/bsps/sparc64/include/arch/arch.h
>>> > b/bsps/sparc64/include/arch/arch.h
>>> > index 5fdd4a2..36aa922 100644
>>> > --- a/bsps/sparc64/include/arch/arch.h
>>> > +++ b/bsps/sparc64/include/arch/arch.h
>>> > @@ -37,10 +37,14 @@
>>> >  #ifndef KERN_sparc64_ARCH_H_
>>> >  #define KERN_sparc64_ARCH_H_
>>> > +#include <bspopts.h>
>>> >  #if defined (SUN4U)
>>> >  #include <arch/sun4u/arch.h>
>>> >  #elif defined (SUN4V)
>>> >  #include <arch/sun4v/arch.h>
>>> > +#else
>>> > +#error "No SUN model defined"
>>> >  #endif
>>> >  #define ASI_AIUP               0x10    /** Access to primary context
>>> > with user privileges. */
>>> > diff --git a/bsps/sparc64/include/arch/mm/frame.h
>>> > b/bsps/sparc64/include/arch/mm/frame.h
>>> > index fb66e54..2fc17cc 100644
>>> > --- a/bsps/sparc64/include/arch/mm/frame.h
>>> > +++ b/bsps/sparc64/include/arch/mm/frame.h
>>> > @@ -35,10 +35,14 @@
>>> >  #ifndef KERN_sparc64_FRAME_H_
>>> >  #define KERN_sparc64_FRAME_H_
>>> >  #if defined (SUN4U)
>>> >  #include <arch/mm/sun4u/frame.h>
>>> >  #include <arch/mm/sun4v/frame.h>
>>> > +#else
>>> >  #endif
>>> >  #endif
>>> > diff --git a/bsps/sparc64/include/arch/mm/mmu.h
>>> > b/bsps/sparc64/include/arch/mm/mmu.h
>>> > index 1d445f2..aab143f 100644
>>> > --- a/bsps/sparc64/include/arch/mm/mmu.h
>>> > +++ b/bsps/sparc64/include/arch/mm/mmu.h
>>> > @@ -35,10 +35,14 @@
>>> >  #ifndef KERN_sparc64_MMU_H_
>>> >  #define KERN_sparc64_MMU_H_
>>> >  #if defined (SUN4U)
>>> >  #include <arch/mm/sun4u/mmu.h>
>>> >  #include <arch/mm/sun4v/mmu.h>
>>> > +#else
>>> >  #endif
>>> > diff --git a/bsps/sparc64/include/arch/mm/tlb.h
>>> > b/bsps/sparc64/include/arch/mm/tlb.h
>>> > index 4adf26c..7a6b85d 100644
>>> > --- a/bsps/sparc64/include/arch/mm/tlb.h
>>> > +++ b/bsps/sparc64/include/arch/mm/tlb.h
>>> > @@ -35,11 +35,14 @@
>>> >  #ifndef KERN_sparc64_TLB_H_
>>> >  #define KERN_sparc64_TLB_H_
>>> >  #if defined (SUN4U)
>>> >  #include <arch/mm/sun4u/tlb.h>
>>> >  #include <arch/mm/sun4v/tlb.h>
>>> > +#else
>>> >  #endif
>>> >  #endif
>>> > diff --git a/bsps/sparc64/include/arch/mm/tte.h
>>> > b/bsps/sparc64/include/arch/mm/tte.h
>>> > index f0b746e..10a672b 100644
>>> > --- a/bsps/sparc64/include/arch/mm/tte.h
>>> > +++ b/bsps/sparc64/include/arch/mm/tte.h
>>> > @@ -35,10 +35,14 @@
>>> >  #ifndef KERN_sparc64_TTE_H_
>>> >  #define KERN_sparc64_TTE_H_
>>> >  #if defined (SUN4U)
>>> >  #include <arch/mm/sun4u/tte.h>
>>> >  #include <arch/mm/sun4v/tte.h>
>>> > +#else
>>> >  #endif
>>> >  #endif
>>> > diff --git a/bsps/sparc64/niagara/config/niagara.cfg
>>> > b/bsps/sparc64/niagara/config/niagara.cfg
>>> > index 2fd8973..bfa73aa 100644
>>> > --- a/bsps/sparc64/niagara/config/niagara.cfg
>>> > +++ b/bsps/sparc64/niagara/config/niagara.cfg
>>> > @@ -7,7 +7,7 @@ RTEMS_CPU=sparc64
>>> >  #  This contains the compiler options necessary to select the CPU
>>> > model
>>> >  #  and (hopefully) optimize for it.
>>> > -CPU_CFLAGS = -mcpu=niagara -DSUN4V
>>> > +CPU_CFLAGS = -mcpu=niagara
>>> >  # optimize flag: typically -g -O2
>>> >  CFLAGS_OPTIMIZE_V = -g -O2
>>> > diff --git a/bsps/sparc64/usiii/config/usiii.cfg
>>> > b/bsps/sparc64/usiii/config/usiii.cfg
>>> > index b9fad21..ee1c508 100644
>>> > --- a/bsps/sparc64/usiii/config/usiii.cfg
>>> > +++ b/bsps/sparc64/usiii/config/usiii.cfg
>>> > model
>>> > -CPU_CFLAGS = -mcpu=ultrasparc3 -DUS3 -DSUN4U
>>> > +CPU_CFLAGS = -mcpu=ultrasparc3
>>> > diff --git a/c/src/lib/libbsp/sparc64/niagara/configure.ac
>>> > b/c/src/lib/libbsp/sparc64/niagara/configure.ac
>>> > index ced7e12..f8e9687 100644
>>> > --- a/c/src/lib/libbsp/sparc64/niagara/configure.ac
>>> > +++ b/c/src/lib/libbsp/sparc64/niagara/configure.ac
>>> > @@ -10,6 +10,10 @@ RTEMS_CANONICAL_TARGET_CPU
>>> >  AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
>>> >  RTEMS_BSP_CONFIGURE
>>> > +RTEMS_BSPOPTS_SET([SUN4V],[niagara],[1])
>>> > +RTEMS_BSPOPTS_SET([SUN4V],[*],[])
>>> > +RTEMS_BSPOPTS_HELP([SUN4V],
>>> > +[If defined, enable SUN model optons for the Niagara model.])
>>> >  RTEMS_BSP_CLEANUP_OPTIONS
>>> > diff --git a/c/src/lib/libbsp/sparc64/usiii/configure.ac
>>> > b/c/src/lib/libbsp/sparc64/usiii/configure.ac
>>> > index 4244055..c99d938 100644
>>> > --- a/c/src/lib/libbsp/sparc64/usiii/configure.ac
>>> > +++ b/c/src/lib/libbsp/sparc64/usiii/configure.ac
>>> > @@ -10,13 +10,21 @@ RTEMS_CANONICAL_TARGET_CPU
>>> >  RTEMS_BSP_CONFIGURE
>>> >  RTEMS_BSPOPTS_SET([SIMSPARC_FAST_IDLE],[*],[])
>>> >  RTEMS_BSPOPTS_HELP([SIMSPARC_FAST_IDLE],
>>> >  [If defined, speed up the clock ticks while the idle task is running
>>> > so
>>> >  time spent in the idle task is minimized.  This significantly reduces
>>> >  the wall time required to execute the RTEMS test suites.])
>>> > +RTEMS_BSPOPTS_SET([US3],[usiii],[1])
>>> > +RTEMS_BSPOPTS_SET([US3],[*],[])
>>> > +RTEMS_BSPOPTS_HELP([US3],
>>> > +[If defined, enable UltraSPARC optons for the USIII BSP.])
>>> > +RTEMS_BSPOPTS_SET([SUN4U],[usiii],[1])
>>> > +RTEMS_BSPOPTS_SET([SUN4U],[*],[])
>>> > +RTEMS_BSPOPTS_HELP([SUN4U],
>>> > +[If defined, enable SUN model optons for the USIII BSP.])
>>> These are not really "optional" defines. It doesn't make sense for
>>> example to compile an ultrasparc3 BSP without the SUN4U define. I
>>> don't really know if this matters.
>> Feel free to change it to whatever autoconf magic forces the setting
>> without providing an override option.
>>> > 1.8.3.1
>>> > _______________________________________________
>>> > devel mailing list
>>> > devel at rtems.org
>>> > http://lists.rtems.org/mailman/listinfo/devel
