[PATCH] Rework to minimize and eventually eliminate RTEMS use of bsp_specs
    Amaan Cheval
    amaan.cheval at gmail.com
    Fri May 18 06:38:55 UTC 2018
I just compiled my local fixed copy (adding rtems.h back in) and
there's good news! With the patch, the x86_64 compile stub works with
a blank bsp_specs file!
On Fri, May 18, 2018 at 12:59 AM, Amaan Cheval <amaan.cheval at gmail.com> wrote:
> Hey!
> Thanks so much for sharing this, it's quite useful to put your earlier
> email[1] about minimzing the bsp_specs in context.
> From looking ahead a bit without testing (still compiling), the patch
> may need an ENDFILE_SPEC definition as well for "crtend.o" (it defines
> __TMC_END__ which crtbegin.o has left undefined for eg.) and possibly
> "crtn.o", at least to eliminate the x86_64 port's bsp_specs entirely
> (see here[2]).
Just noticed that ENDFILE_SPEC already includes crtend in i386elf.h,
so there's no need for this change.
> I've also left some comments inline below.
> +1 on upstreaming this into GCC (making sure it also backports to 7.3
> for simplicity, so we don't need to write a 7.3-specific patch for the
> RSB as well) with a few additons (at least for the x86_64 target, to
> try to have an empty bsp_specs to begin with).
> [1] https://lists.rtems.org/pipermail/devel/2018-May/021430.html
> [2] https://github.com/AmaanC/rtems-gsoc18/blob/ac/daily-01-compile-stub/bsps/x86_64/amd64/start/bsp_specs
> On Wed, May 16, 2018 at 8:46 PM, Joel Sherrill <joel at rtems.org> wrote:
>>  gcc/config.gcc                |  2 +-
>>  gcc/config/arm/rtems.h        |  4 ++++
>>  gcc/config/bfin/rtems.h       |  4 ++++
>>  gcc/config/i386/rtemself.h    |  6 +++++-
>>  gcc/config/i386/rtemself64.h  | 39 +++++++++++++++++++++++++++++++++++++++
>>  gcc/config/m68k/rtemself.h    |  4 ++++
>>  gcc/config/microblaze/rtems.h |  4 ++++
>>  gcc/config/mips/rtems.h       |  4 ++++
>>  gcc/config/moxie/rtems.h      |  4 ++++
>>  gcc/config/nios2/rtems.h      |  4 ++++
>>  gcc/config/riscv/rtems.h      |  4 ++++
>>  gcc/config/rs6000/rtems.h     |  5 +++++
>>  gcc/config/rtems.h            |  6 +++++-
>>  gcc/config/sh/rtems.h         |  4 ++++
>>  gcc/config/sh/rtemself.h      |  4 ++++
>>  gcc/config/sparc/rtemself.h   |  4 ++++
>>  gcc/config/v850/rtems.h       |  4 ++++
>>  17 files changed, 103 insertions(+), 3 deletions(-)
>>  create mode 100644 gcc/config/i386/rtemself64.h
>> diff --git a/gcc/config.gcc b/gcc/config.gcc
>> index d509800..de27e5c 100644
>> --- a/gcc/config.gcc
>> +++ b/gcc/config.gcc
>> @@ -1499,7 +1499,7 @@ x86_64-*-elf*)
>>         tm_file="${tm_file} i386/unix.h i386/att.h dbxelf.h elfos.h newlib-stdint.h i386/i386elf.h i386/x86-64.h"
>>  x86_64-*-rtems*)
>> -       tm_file="${tm_file} i386/unix.h i386/att.h dbxelf.h elfos.h newlib-stdint.h i386/i386elf.h i386/x86-64.h i386/rtemself.h rtems.h"
>> +       tm_file="${tm_file} i386/unix.h i386/att.h dbxelf.h elfos.h newlib-stdint.h i386/i386elf.h i386/x86-64.h i386/rtemself64.h"
> In rebasing with upstream, this commit must have silently mistakenly
> also dropped rtems.h (which my patch earlier added to support the
> -qrtems, -qnolinkcmds, etc. flags).
>>  i[34567]86-*-rdos*)
>>      tm_file="${tm_file} i386/unix.h i386/att.h dbxelf.h elfos.h newlib-stdint.h i386/i386elf.h i386/rdos.h"
>> diff --git a/gcc/config/arm/rtems.h b/gcc/config/arm/rtems.h
>> index 1123f4a..e79ce90 100644
>> --- a/gcc/config/arm/rtems.h
>> +++ b/gcc/config/arm/rtems.h
>> @@ -34,3 +34,7 @@
>>      } while (0)
>>  #define ARM_DEFAULT_SHORT_ENUMS false
>> +#undef STARTFILE_SPEC
>> +#define STARTFILE_SPEC "\
>> +%{!nostdlib: %{!qrtems: crt0.o%s} crti.o%s crtbegin.o%s}"
>> diff --git a/gcc/config/bfin/rtems.h b/gcc/config/bfin/rtems.h
>> index 6a9a41f..28a69b9 100644
>> --- a/gcc/config/bfin/rtems.h
>> +++ b/gcc/config/bfin/rtems.h
>> @@ -31,3 +31,7 @@
>>        builtin_assert ("system=rtems");         \
>>    while (0)
>> diff --git a/gcc/config/i386/rtemself.h b/gcc/config/i386/rtemself.h
>> index 65e8dad..3a09354 100644
>> --- a/gcc/config/i386/rtemself.h
>> +++ b/gcc/config/i386/rtemself.h
>> @@ -1,4 +1,4 @@
>> -/* Definitions for rtems targeting an ix86 using ELF.
>> +/* Definitions for rtems targeting an x86_64 using ELF.
> I think you meant to have this comment in rtemself64.h, which says
> ix86 currently?
>>     Copyright (C) 1996-2018 Free Software Foundation, Inc.
>>     Contributed by Joel Sherrill (joel at OARcorp.com).
>> @@ -33,3 +33,7 @@
>>    while (0)
>> +%{!nostdlib: %{!qrtems: crt0.o%s} crtbegin.o%s}"
>> diff --git a/gcc/config/i386/rtemself64.h b/gcc/config/i386/rtemself64.h
>> new file mode 100644
>> index 0000000..34e5937
>> --- /dev/null
>> +++ b/gcc/config/i386/rtemself64.h
>> @@ -0,0 +1,39 @@
>> +/* Definitions for rtems targeting an ix86 using ELF.
> See above.
>> +   Copyright (C) 1996-2018 Free Software Foundation, Inc.
>> +   Contributed by Joel Sherrill (joel at OARcorp.com).
>> +   This file is part of GCC.
>> +   GCC is free software; you can redistribute it and/or modify it
>> +   under the terms of the GNU General Public License as published
>> +   by the Free Software Foundation; either version 3, or (at your
>> +   option) any later version.
>> +   GCC is distributed in the hope that it will be useful, but WITHOUT
>> +   ANY WARRANTY; without even the implied warranty of MERCHANTABILITY
>> +   or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public
>> +   License for more details.
>> +   Under Section 7 of GPL version 3, you are granted additional
>> +   permissions described in the GCC Runtime Library Exception, version
>> +   3.1, as published by the Free Software Foundation.
>> +   You should have received a copy of the GNU General Public License and
>> +   a copy of the GCC Runtime Library Exception along with this program;
>> +   see the files COPYING3 and COPYING.RUNTIME respectively.  If not, see
>> +   <http://www.gnu.org/licenses/>.  */
>> +/* Specify predefined symbols in preprocessor.  */
>> +#define TARGET_OS_CPP_BUILTINS()               \
>> +  do                                           \
>> +       builtin_define ("__rtems__");           \
>> +       builtin_define ("__USE_INIT_FINI__");   \
>> +       builtin_assert ("system=rtems");        \
>> +  while (0)
>> diff --git a/gcc/config/m68k/rtemself.h b/gcc/config/m68k/rtemself.h
>> index e18a06e..6f31aa5 100644
>> --- a/gcc/config/m68k/rtemself.h
>> +++ b/gcc/config/m68k/rtemself.h
>> @@ -36,3 +36,7 @@
>>    while (0)
>> diff --git a/gcc/config/microblaze/rtems.h b/gcc/config/microblaze/rtems.h
>> index 5f23321..fc8914c 100644
>> --- a/gcc/config/microblaze/rtems.h
>> +++ b/gcc/config/microblaze/rtems.h
>> @@ -35,3 +35,7 @@
>>    %{mbig-endian:-EB --oformat=elf32-microblaze} \
>>    %{mlittle-endian:-EL --oformat=elf32-microblazeel} \
>>    %{mxl-gp-opt:%{G*}} %{!mxl-gp-opt: -G 0}"
>> diff --git a/gcc/config/mips/rtems.h b/gcc/config/mips/rtems.h
>> index 66e00bf..6e96853 100644
>> --- a/gcc/config/mips/rtems.h
>> +++ b/gcc/config/mips/rtems.h
>> @@ -37,3 +37,7 @@ do {                                  \
>>  #undef MIPS_DEFAULT_GVALUE
>>  #define MIPS_DEFAULT_GVALUE 0
>> diff --git a/gcc/config/moxie/rtems.h b/gcc/config/moxie/rtems.h
>> index bc28d6e..6c79063 100644
>> --- a/gcc/config/moxie/rtems.h
>> +++ b/gcc/config/moxie/rtems.h
>> @@ -38,3 +38,7 @@
>>  #undef PTRDIFF_TYPE
>>  #undef WCHAR_TYPE
>>  #undef WCHAR_TYPE_SIZE
>> diff --git a/gcc/config/nios2/rtems.h b/gcc/config/nios2/rtems.h
>> index b4a6082..f6eedf6 100644
>> --- a/gcc/config/nios2/rtems.h
>> +++ b/gcc/config/nios2/rtems.h
>>     This is done so RTEMS targets have Thread Local Storage like Linux.  */
>>  #define TARGET_LINUX_ABI 1
>> diff --git a/gcc/config/riscv/rtems.h b/gcc/config/riscv/rtems.h
>> index 231b6a0..a9d1e01 100644
>> --- a/gcc/config/riscv/rtems.h
>> +++ b/gcc/config/riscv/rtems.h
>> @@ -29,3 +29,7 @@
>>      } while (0)
>> diff --git a/gcc/config/rs6000/rtems.h b/gcc/config/rs6000/rtems.h
>> index 54ddcb4..20a4ffa 100644
>> --- a/gcc/config/rs6000/rtems.h
>> +++ b/gcc/config/rs6000/rtems.h
>> @@ -72,6 +72,11 @@
>>    while (0)
>> +%{!nostdlib: %{!qrtems: crt0.o%s} ecrti.o%s crtbegin.o%s}"
>>  /* Copy and paste from linux64.h and freebsd64.h */
>>  #undef RELOCATABLE_NEEDS_FIXUP
>>  #define RELOCATABLE_NEEDS_FIXUP \
>> diff --git a/gcc/config/rtems.h b/gcc/config/rtems.h
>> index dcea95c..9a0619c 100644
>> --- a/gcc/config/rtems.h
>> +++ b/gcc/config/rtems.h
>> @@ -30,11 +30,15 @@
>>   * Dummy start/end specification to let linker work as
>>   * needed by autoconf scripts using this compiler.
>> +#if 0
>> -#define STARTFILE_SPEC "crt0.o%s"
>> +#define STARTFILE_SPEC "%{!qrtems: crt0.o%s}"
>> +#endif
>> +#if 0
>>  #undef ENDFILE_SPEC
>>  #define ENDFILE_SPEC   ""
>> +#endif
>>   * Some targets do not set up LIB_SPECS, override it, here.
>> diff --git a/gcc/config/sh/rtems.h b/gcc/config/sh/rtems.h
>> index d2f2b2a..f699151 100644
>> --- a/gcc/config/sh/rtems.h
>> +++ b/gcc/config/sh/rtems.h
>> @@ -29,3 +29,7 @@
>>    builtin_define( "__rtems__" );               \
>>    builtin_assert( "system=rtems" );            \
>>  } while (0)
>> diff --git a/gcc/config/sh/rtemself.h b/gcc/config/sh/rtemself.h
>> index 6a67b49..85f26b0 100644
>> --- a/gcc/config/sh/rtemself.h
>> +++ b/gcc/config/sh/rtemself.h
>> @@ -29,3 +29,7 @@
>>  } while (0)
>> diff --git a/gcc/config/sparc/rtemself.h b/gcc/config/sparc/rtemself.h
>> index e4b52d8..7c5bf43 100644
>> --- a/gcc/config/sparc/rtemself.h
>> +++ b/gcc/config/sparc/rtemself.h
>> @@ -38,3 +38,7 @@
>>  /* Use the default */
>>  #undef LINK_GCC_C_SEQUENCE_SPEC
>> diff --git a/gcc/config/v850/rtems.h b/gcc/config/v850/rtems.h
>> index b20b2c3..1b56649 100644
>> --- a/gcc/config/v850/rtems.h
>> +++ b/gcc/config/v850/rtems.h
>> @@ -39,3 +39,7 @@
>>  %{!mv850es:%{!mv850e1:%{mv*:-mv%*}} \
>>  %{m8byte-align:-m8byte-align} \
>>  %{mgcc-abi:-mgcc-abi}}"
>> 1.8.3.1
>> devel mailing list
>> devel at rtems.org
