[PATCH] Rework to minimize and eventually eliminate RTEMS use of bsp_specs
    Joel Sherrill
    joel at rtems.org
    Fri May 18 13:30:05 UTC 2018
On Fri, May 18, 2018 at 1:38 AM, Amaan Cheval <amaan.cheval at gmail.com>
wrote:
> I just compiled my local fixed copy (adding rtems.h back in) and
> there's good news! With the patch, the x86_64 compile stub works with
> a blank bsp_specs file!
Awesome!
Can you send me your changes as a patch? I am thinking I need to make
sure we agree on what the gcc master for x86_64-rtems looks like.
Apparently I owe committing a patch to add i386/rtemself64.h since it is
missing on the master. And the comment is wrong.  What else?
On Fri, May 18, 2018 at 12:59 AM, Amaan Cheval <amaan.cheval at gmail.com>
> wrote:
> > Hey!
> > Thanks so much for sharing this, it's quite useful to put your earlier
> > email[1] about minimzing the bsp_specs in context.
> > From looking ahead a bit without testing (still compiling), the patch
> > may need an ENDFILE_SPEC definition as well for "crtend.o" (it defines
> > __TMC_END__ which crtbegin.o has left undefined for eg.) and possibly
> > "crtn.o", at least to eliminate the x86_64 port's bsp_specs entirely
> > (see here[2]).
> Just noticed that ENDFILE_SPEC already includes crtend in i386elf.h,
> so there's no need for this change.
> > I've also left some comments inline below.
> > +1 on upstreaming this into GCC (making sure it also backports to 7.3
> > for simplicity, so we don't need to write a 7.3-specific patch for the
> > RSB as well) with a few additons (at least for the x86_64 target, to
> > try to have an empty bsp_specs to begin with).
> > [1] https://lists.rtems.org/pipermail/devel/2018-May/021430.html
> > [2] https://github.com/AmaanC/rtems-gsoc18/blob/ac/daily-01-
> compile-stub/bsps/x86_64/amd64/start/bsp_specs
> > On Wed, May 16, 2018 at 8:46 PM, Joel Sherrill <joel at rtems.org> wrote:
> >>  gcc/config.gcc                |  2 +-
> >>  gcc/config/arm/rtems.h        |  4 ++++
> >>  gcc/config/bfin/rtems.h       |  4 ++++
> >>  gcc/config/i386/rtemself.h    |  6 +++++-
> >>  gcc/config/i386/rtemself64.h  | 39 ++++++++++++++++++++++++++++++
> >>  gcc/config/m68k/rtemself.h    |  4 ++++
> >>  gcc/config/microblaze/rtems.h |  4 ++++
> >>  gcc/config/mips/rtems.h       |  4 ++++
> >>  gcc/config/moxie/rtems.h      |  4 ++++
> >>  gcc/config/nios2/rtems.h      |  4 ++++
> >>  gcc/config/riscv/rtems.h      |  4 ++++
> >>  gcc/config/rs6000/rtems.h     |  5 +++++
> >>  gcc/config/rtems.h            |  6 +++++-
> >>  gcc/config/sh/rtems.h         |  4 ++++
> >>  gcc/config/sh/rtemself.h      |  4 ++++
> >>  gcc/config/sparc/rtemself.h   |  4 ++++
> >>  gcc/config/v850/rtems.h       |  4 ++++
> >>  17 files changed, 103 insertions(+), 3 deletions(-)
> >>  create mode 100644 gcc/config/i386/rtemself64.h
> >> diff --git a/gcc/config.gcc b/gcc/config.gcc
> >> index d509800..de27e5c 100644
> >> --- a/gcc/config.gcc
> >> +++ b/gcc/config.gcc
> >> @@ -1499,7 +1499,7 @@ x86_64-*-elf*)
> >>         tm_file="${tm_file} i386/unix.h i386/att.h dbxelf.h elfos.h
> newlib-stdint.h i386/i386elf.h i386/x86-64.h"
> >>  x86_64-*-rtems*)
> >> -       tm_file="${tm_file} i386/unix.h i386/att.h dbxelf.h elfos.h
> newlib-stdint.h i386/i386elf.h i386/x86-64.h i386/rtemself.h rtems.h"
> >> +       tm_file="${tm_file} i386/unix.h i386/att.h dbxelf.h elfos.h
> newlib-stdint.h i386/i386elf.h i386/x86-64.h i386/rtemself64.h"
> > In rebasing with upstream, this commit must have silently mistakenly
> > also dropped rtems.h (which my patch earlier added to support the
> > -qrtems, -qnolinkcmds, etc. flags).
> >>  i[34567]86-*-rdos*)
> newlib-stdint.h i386/i386elf.h i386/rdos.h"
> >> diff --git a/gcc/config/arm/rtems.h b/gcc/config/arm/rtems.h
> >> index 1123f4a..e79ce90 100644
> >> --- a/gcc/config/arm/rtems.h
> >> +++ b/gcc/config/arm/rtems.h
> >> @@ -34,3 +34,7 @@
> >>      } while (0)
> >>  #define ARM_DEFAULT_SHORT_ENUMS false
> >> +#undef STARTFILE_SPEC
> >> +#define STARTFILE_SPEC "\
> >> +%{!nostdlib: %{!qrtems: crt0.o%s} crti.o%s crtbegin.o%s}"
> >> diff --git a/gcc/config/bfin/rtems.h b/gcc/config/bfin/rtems.h
> >> index 6a9a41f..28a69b9 100644
> >> --- a/gcc/config/bfin/rtems.h
> >> +++ b/gcc/config/bfin/rtems.h
> >> @@ -31,3 +31,7 @@
> >>        builtin_assert ("system=rtems");         \
> >>    while (0)
> >> diff --git a/gcc/config/i386/rtemself.h b/gcc/config/i386/rtemself.h
> >> index 65e8dad..3a09354 100644
> >> --- a/gcc/config/i386/rtemself.h
> >> +++ b/gcc/config/i386/rtemself.h
> >> @@ -1,4 +1,4 @@
> >> -/* Definitions for rtems targeting an ix86 using ELF.
> >> +/* Definitions for rtems targeting an x86_64 using ELF.
> > I think you meant to have this comment in rtemself64.h, which says
> > ix86 currently?
> >>     Copyright (C) 1996-2018 Free Software Foundation, Inc.
> >>     Contributed by Joel Sherrill (joel at OARcorp.com).
> >> @@ -33,3 +33,7 @@
> >>    while (0)
> >> +%{!nostdlib: %{!qrtems: crt0.o%s} crtbegin.o%s}"
> >> diff --git a/gcc/config/i386/rtemself64.h b/gcc/config/i386/rtemself64.h
> >> new file mode 100644
> >> index 0000000..34e5937
> >> --- /dev/null
> >> +++ b/gcc/config/i386/rtemself64.h
> >> @@ -0,0 +1,39 @@
> >> +/* Definitions for rtems targeting an ix86 using ELF.
> > See above.
> >> +   Copyright (C) 1996-2018 Free Software Foundation, Inc.
> >> +   Contributed by Joel Sherrill (joel at OARcorp.com).
> >> +   This file is part of GCC.
> >> +   GCC is free software; you can redistribute it and/or modify it
> >> +   under the terms of the GNU General Public License as published
> >> +   by the Free Software Foundation; either version 3, or (at your
> >> +   option) any later version.
> >> +   GCC is distributed in the hope that it will be useful, but WITHOUT
> >> +   ANY WARRANTY; without even the implied warranty of MERCHANTABILITY
> >> +   or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public
> >> +   License for more details.
> >> +   Under Section 7 of GPL version 3, you are granted additional
> >> +   permissions described in the GCC Runtime Library Exception, version
> >> +   3.1, as published by the Free Software Foundation.
> >> +   You should have received a copy of the GNU General Public License
> and
> >> +   a copy of the GCC Runtime Library Exception along with this program;
> >> +   see the files COPYING3 and COPYING.RUNTIME respectively.  If not,
> see
> >> +   <http://www.gnu.org/licenses/>.  */
> >> +/* Specify predefined symbols in preprocessor.  */
> >> +#define TARGET_OS_CPP_BUILTINS()               \
> >> +  do                                           \
> >> +       builtin_define ("__rtems__");           \
> >> +       builtin_define ("__USE_INIT_FINI__");   \
> >> +       builtin_assert ("system=rtems");        \
> >> +  while (0)
> >> diff --git a/gcc/config/m68k/rtemself.h b/gcc/config/m68k/rtemself.h
> >> index e18a06e..6f31aa5 100644
> >> --- a/gcc/config/m68k/rtemself.h
> >> +++ b/gcc/config/m68k/rtemself.h
> >> @@ -36,3 +36,7 @@
> >>    while (0)
> >> diff --git a/gcc/config/microblaze/rtems.h
> b/gcc/config/microblaze/rtems.h
> >> index 5f23321..fc8914c 100644
> >> --- a/gcc/config/microblaze/rtems.h
> >> +++ b/gcc/config/microblaze/rtems.h
> >> @@ -35,3 +35,7 @@
> >>    %{mbig-endian:-EB --oformat=elf32-microblaze} \
> >>    %{mlittle-endian:-EL --oformat=elf32-microblazeel} \
> >>    %{mxl-gp-opt:%{G*}} %{!mxl-gp-opt: -G 0}"
> >> diff --git a/gcc/config/mips/rtems.h b/gcc/config/mips/rtems.h
> >> index 66e00bf..6e96853 100644
> >> --- a/gcc/config/mips/rtems.h
> >> +++ b/gcc/config/mips/rtems.h
> >> @@ -37,3 +37,7 @@ do {                                  \
> >>  #undef MIPS_DEFAULT_GVALUE
> >>  #define MIPS_DEFAULT_GVALUE 0
> >> diff --git a/gcc/config/moxie/rtems.h b/gcc/config/moxie/rtems.h
> >> index bc28d6e..6c79063 100644
> >> --- a/gcc/config/moxie/rtems.h
> >> +++ b/gcc/config/moxie/rtems.h
> >> @@ -38,3 +38,7 @@
> >>  #undef PTRDIFF_TYPE
> >>  #undef WCHAR_TYPE
> >>  #undef WCHAR_TYPE_SIZE
> >> diff --git a/gcc/config/nios2/rtems.h b/gcc/config/nios2/rtems.h
> >> index b4a6082..f6eedf6 100644
> >> --- a/gcc/config/nios2/rtems.h
> >> +++ b/gcc/config/nios2/rtems.h
> >>     This is done so RTEMS targets have Thread Local Storage like
> Linux.  */
> >>  #define TARGET_LINUX_ABI 1
> >> diff --git a/gcc/config/riscv/rtems.h b/gcc/config/riscv/rtems.h
> >> index 231b6a0..a9d1e01 100644
> >> --- a/gcc/config/riscv/rtems.h
> >> +++ b/gcc/config/riscv/rtems.h
> >> @@ -29,3 +29,7 @@
> >>      } while (0)
> >> diff --git a/gcc/config/rs6000/rtems.h b/gcc/config/rs6000/rtems.h
> >> index 54ddcb4..20a4ffa 100644
> >> --- a/gcc/config/rs6000/rtems.h
> >> +++ b/gcc/config/rs6000/rtems.h
> >> @@ -72,6 +72,11 @@
> >>    while (0)
> >> +%{!nostdlib: %{!qrtems: crt0.o%s} ecrti.o%s crtbegin.o%s}"
> >>  /* Copy and paste from linux64.h and freebsd64.h */
> >>  #undef RELOCATABLE_NEEDS_FIXUP
> >>  #define RELOCATABLE_NEEDS_FIXUP \
> >> diff --git a/gcc/config/rtems.h b/gcc/config/rtems.h
> >> index dcea95c..9a0619c 100644
> >> --- a/gcc/config/rtems.h
> >> +++ b/gcc/config/rtems.h
> >> @@ -30,11 +30,15 @@
> >>   * Dummy start/end specification to let linker work as
> >>   * needed by autoconf scripts using this compiler.
> >> +#if 0
> >> -#define STARTFILE_SPEC "crt0.o%s"
> >> +#define STARTFILE_SPEC "%{!qrtems: crt0.o%s}"
> >> +#endif
> >> +#if 0
> >>  #undef ENDFILE_SPEC
> >>  #define ENDFILE_SPEC   ""
> >> +#endif
> >>   * Some targets do not set up LIB_SPECS, override it, here.
> >> diff --git a/gcc/config/sh/rtems.h b/gcc/config/sh/rtems.h
> >> index d2f2b2a..f699151 100644
> >> --- a/gcc/config/sh/rtems.h
> >> +++ b/gcc/config/sh/rtems.h
> >> @@ -29,3 +29,7 @@
> >>    builtin_define( "__rtems__" );               \
> >>    builtin_assert( "system=rtems" );            \
> >>  } while (0)
> >> diff --git a/gcc/config/sh/rtemself.h b/gcc/config/sh/rtemself.h
> >> index 6a67b49..85f26b0 100644
> >> --- a/gcc/config/sh/rtemself.h
> >> +++ b/gcc/config/sh/rtemself.h
> >> @@ -29,3 +29,7 @@
> >>  } while (0)
> >> diff --git a/gcc/config/sparc/rtemself.h b/gcc/config/sparc/rtemself.h
> >> index e4b52d8..7c5bf43 100644
> >> --- a/gcc/config/sparc/rtemself.h
> >> +++ b/gcc/config/sparc/rtemself.h
> >> @@ -38,3 +38,7 @@
> >>  /* Use the default */
> >>  #undef LINK_GCC_C_SEQUENCE_SPEC
> >> diff --git a/gcc/config/v850/rtems.h b/gcc/config/v850/rtems.h
> >> index b20b2c3..1b56649 100644
> >> --- a/gcc/config/v850/rtems.h
> >> +++ b/gcc/config/v850/rtems.h
> >> @@ -39,3 +39,7 @@
> >>  %{!mv850es:%{!mv850e1:%{mv*:-mv%*}} \
> >>  %{m8byte-align:-m8byte-align} \
> >>  %{mgcc-abi:-mgcc-abi}}"
> >> 1.8.3.1
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180518/195e8b69/attachment-0002.html>
